Fundamental matrices in inhomogenous problems?
In summary, fundamental matrices are used to solve systems of ODEs, providing a general solution regardless of the initial value of the particular solution. The constants of integration can be determined from initial conditions in the case of a 0 initial value, but must be solved for in other cases.
pivoxa15
2,255
It seems to be the case that fundamental matrices are only used when the particular solution has an initial value of 0. Since the integral for the inhomogenous term is from (t. to t) where t. is initial value. So when t=t. the inhomogenous term must be 0. But there are cases when the particlular solution may not have an intitial value of 0 which means those situations cannot be dealt with by Fundamental matrices method of solving ODEs. But I always had the impression that they could solve any systems of ODEs.
Fundamental matrices can indeed solve any system of ODEs, regardless of the particular solution having an initial value of 0 or not. The fundamental matrix provides a general solution to a system of linear ODEs, and the particular solution can be found by solving for the constants of integration. The only difference between the case where the particular solution has an initial value of 0 and when it does not is that in the former case, the constants of integration can be easily determined from the initial condition, while in the latter case, the constants must be found by solving the system of equations given by the initial conditions.
Fundamental matrices can certainly be used to solve inhomogeneous problems, even when the particular solution does not have an initial value of 0. The key is to use the fundamental matrix to find the general solution, and then use the initial conditions to find the particular solution. In other words, the fundamental matrix provides the building blocks for finding the solution, but the initial conditions are still necessary to fully determine the particular solution.
In some cases, the inhomogeneous term may be 0 at the initial value, but this is not always the case. For example, consider the ODE y'' + y = sin(t), with initial conditions y(0) = a and y'(0) = b. The inhomogeneous term is not 0 at t=0, but we can still use the fundamental matrix to find the general solution y(t) = c1*cos(t) + c2*sin(t) + sin(t)/2. Then, using the initial conditions, we can solve for c1 and c2 and obtain the particular solution y(t) = a*cos(t) + (b+1)*sin(t)/2.
So while it may be true that the inhomogeneous term must be 0 at the initial value for the particular solution to have an initial value of 0, this does not mean that fundamental matrices cannot be used to solve inhomogeneous problems. They are still a powerful tool for solving systems of ODEs, and can handle a variety of initial conditions and inhomogeneous terms.
1. What is the purpose of using fundamental matrices in inhomogeneous problems?
Fundamental matrices are used to solve systems of inhomogeneous differential equations. They provide a way to find a particular solution to a system of equations by incorporating the initial conditions of the system.
2. How do fundamental matrices differ from other types of matrices?
Fundamental matrices are unique in that they represent the general solution to a system of differential equations, rather than just a specific solution. They also incorporate initial conditions and can be used to solve both homogeneous and inhomogeneous problems.
3. How are fundamental matrices related to the concept of linear independence?
Fundamental matrices are based on the concept of linear independence. In order for a set of vectors to form a fundamental matrix, they must be linearly independent. This means that none of the vectors can be expressed as a linear combination of the others.
4. Can fundamental matrices be used to solve non-linear systems of equations?
No, fundamental matrices can only be used to solve linear systems of equations. Non-linear systems require different methods for finding solutions.
5. What are some real-world applications of fundamental matrices in inhomogeneous problems?
Fundamental matrices have many applications in fields such as engineering, physics, and economics. They can be used to model systems with changing parameters, such as population growth or chemical reactions, and to predict future behavior based on initial conditions.
  • Differential Equations
