Moon Stopping Velocity & Impact Force: How Long Would It Take?
In summary, the velocity of the moon just before hitting the Earth would be 9.8 km/s and the force of impact would depend on the deceleration of the moon. It would take a tremendous force to stop the moon and the time it would take for the moon to hit the Earth would be a little under 5 days. The Earth's velocity would not affect the impact, but the type of surface it hits could affect the force of impact. Air resistance may also play a role in decelerating the moon.
sskakam
If the moon was to be stopped, what would its velocity be just before hitting the earth? Also, if you could throw in the force of the impact, that would be great too. And another thing, how long would it take?
Astronomy news on Phys.org
It would take a tremendous force to stop the moon. If you have a tremendous force at your disposal, why are you still so interested in some other force?
Trying to figure out the effects of the moon falling on the earth. Not just general "big explosion happens," but the physics of it. I'm thinking it wouldn't be too fast, maybe a couple of km/s, but I could be wrong. Would you set the potential energy equal to the kinetic energy and solve for v?
velocity = 9.8 Km/sec
force of impact: depends on the deceleration on impact
Time = a little under 5 days.
Thanks a lot Janus, but could you please show how you got those numbers?
If we wanted to get maximum speed, would the speed of the Earth affect it? Let's say the moon stops in front of the Earth's orbit, so the Earth would be moving towards the moon while the moon falls to the earth.
Your talking about to relative velocities here. The Moons relative to the Earth and the Earth relative to the sun. So yes, If the moon stopped completely, (relative to the Earth and the sun) directly in line with the Earth's trajectory, the Earth would slam into the moon in about 3.6 hours, using average distances and velocities respectfully.
This however is obviously a crude approximation as it does not take into consideration other relative velocities (solar system, milky way etc...)
What does "stopped completely (relative to the Earth and the sun)" mean?
I think that would mean that it's velocity looks like it's 0 viewed from the earth/sun, but it's still moving relative to the universe. I think everything's moving within the universe.
So it would make a noticible difference if the Earth moved into the impact rather than if the moon was on the other side and fell while catching up to the earth? Or would these relative velocities make no difference?
But the Earth has a different velocity from the sun... I don't see how the moon can be stationary relative to both.
As for your question, I don't believe it would make any difference if the moon stated stationary relative to the Earth.
I believe I misunderstood sskakam's question. I apologize. For some reason I visualized the moon orbiting the Earth until it's orbit intersected the Earth's orbital path around the sun, at which point the moons velocity relative to the sun became 0. This constitutes my earlier response of the Earth continuing to speed along (in orbit) at 29 kp/s toward a now stationary moon, impacting in about 3.6 hours.
Apparently you meant the moons orbital velocity around Earth becomes 0 as its orbit intersects the earth/sun orbital path. In this case It would not make a difference whether the moon was "catching up" or leading the Earth in respect to its orbital velocity around the sun. If you consider that once the moon stops, in respect to its Earth orbit. Its velocity becomes 0 relative to earth, thus the before mentioned gravitation scenario (speed, impact force/time) between the earth/moon system would not be affected by the moons position relative to earth.
I get 9.8 km/s for a perigee drop and 9.9 km/s for an apogee drop. This is in good agreement with Janus' answer. I numerically simulated it.
Thanks for your replies.
Going back to the force of impact, he said it depends on deceleration. What would be decelerating it? I would think that air friction would be negligable since the moon is so massive. Is there another decelerating force here or am I am I just wrong about ignoring air resistance?
I found this neat website that calculates earth-impact effects (http://www.lpl.arizona.edu/impacteffects/) and it says that the force would be about 3.67 x 10^30 Joules. However this website limits the distance between the Earth and the object at half the Earth's circumference (about 20,000 m). I don't know if that affects it much, but 10^30 J is quite a blow.
One minute it's going 9.8 km/s. Shortly later, its velocity is 0. So it decelerated from 9.8 to 0 over some amount of time. This is not an easy problem. Consider dropping a glass on the floor. If you drop it on carpet it does not break. If you drop it on a hardwood floor, it might break. If you drop it on tile, it definitely breaks. The difference is that on carpet, it takes longer to go from impact velocity to 0 hence a lower acceleration than on tile or hardwood. The larger the acceleration, the larger the force since Force = mass * acceleration.
This is the concept behind air-bags. They want your acceleration to be spread out over a longer period of time, so they give you something soft to crash into rather than something hard. That way it lessens the force.
How "soft" is the Earth? How soft is the Moon?
Rather than force, it might make more sense to ask about energy.
Ah ha, gotcha. So the force would change whether it landed on land or sea, and different types of rock and such. Thanks a lot for all your replies. Helped a bunch.
Wouldn't it be reasonable to treat the Moon and Earth as spheres of uniform density for something like this. I mean, whether it landed on land or sea, I'll be calling out of work that day. And I think the malls will be closed. Except for Starbuck's.
Casey
Is this counting the fact that, at the Moon's distance, g is nowhere near 9.8m/s^2?
Using the JPL impact calculator I get:
Energy:10^13 Megatons
Transient crater: 2660 miles diameter with 939 miles depth
Final crater: 7920 miles diameter with 3.16 miles depth
Paradoxically, the Earth loses negligible mass, nor are orbit or inclination altered appreciably (despite having inexplicably transformed from a sphere to a lopsided dumbbell)
Whether you go to work or not that day, to compute the force you still need to provide some sort of math that describes the rate of decceleration.
That's a good tip. When the Moon drops from the sky, run for Starbucks :)
Yes.
9.8 km/s^2 has nothing to do with 9.8 km/s, unless the fall time were 1 second. The Moon's initial acceleration towards Earth would be very small (G*6e24*1.0123/384000000^2 = 0.0000027 km/s^2).
As I watched the simulation, I kept thinking "Janus is wrong... Janus is wrong". The Moon was moving way too slow, even after it crossed geosychronous altitude, for me to think it had a chance to build to 9.8. But as it got close to Earth's surface, Earth's gravity started pulling big time. At surface-to-surface contact, it was ~9.8- 9.9.
The numerical method relies on the facts that:
* The Moon starts with 0.0 km/s of velocity relative to Earth and at a distance (D) of either lunar perigee, lunar apogee, or somewhere inbetween..
* And that acceleration due to Earth's gravity at that moment will be G(M+m)/D^2.
* And that after delta t (t=time), this acceleration will produce a velocity of v(t)
* And that after delta t, this velocity will produce a change of position of d(v,delta t).
* And that acceleration due to Earths gravity at the new distance will be G(M+m)^newD^2
* And that as delta t is made smaller and smaller, the simulated answer will asymptotically approach the true answer
* And that a delta t of 1 second is sufficient enough to get an answer correct to > 0.1 km/s, while spending less than 2 minutes of computer time.
* And if you make the computer repeat this process again and again until D < (Earth Radii + Moon Radii), you will have numerically computed v and t.
1. How does the velocity of the moon affect the impact force?
The velocity of the moon does not directly affect the impact force. The impact force is determined by the mass and speed of the object (in this case, the moon) as well as the medium it is impacting. However, the velocity of the moon does play a role in determining how long it takes for the moon to come to a complete stop after impact.
2. How long would it take for the moon to stop after impact?
The time it takes for the moon to stop after impact would depend on various factors such as the mass and velocity of the moon, the medium it is impacting, and the angle of impact. Without considering these factors, the average time it would take for the moon to come to a complete stop after impact is estimated to be around 5-6 hours.
3. Can the moon's impact force be calculated?
Yes, the impact force of the moon can be calculated using the formula F=ma, where F is the force, m is the mass, and a is the acceleration. The mass of the moon is known, and the acceleration can be calculated using the change in velocity and the time it takes for the moon to come to a complete stop after impact.
4. How does the medium the moon is impacting affect the stopping time?
The medium that the moon is impacting can greatly affect the stopping time. For example, if the moon were to impact a solid object like a planet, it would take longer for it to come to a complete stop compared to if it were to impact a liquid or gas medium. This is because the resistance and friction of a solid medium is greater than that of a liquid or gas.
5. What are the potential consequences of the moon stopping?
The consequences of the moon stopping would be catastrophic. Since the moon plays a crucial role in stabilizing the Earth's rotation and tides, its sudden stop would greatly affect the Earth's climate, weather patterns, and ecosystems. It would also result in extreme changes in the length of our days and nights, and potentially lead to disastrous natural disasters.
  • Astronomy and Astrophysics
  • Aerospace Engineering
  • Classical Physics
  • Classical Physics
