DollarBill
- 44
Determine dy/dx when
y*sin(x2)=5
y*2xcos(x2) dx/dx + sin(x2)*1 dy/dx = 0
2xy cos(x2)*dy/dx = -sin(x2)
dy/dx = -sin(x2) / 2xy cos(x2)
dy/dx = -2xy tan(x2)
Implicit differentiation is a mathematical technique used to find the derivative of an equation that is not explicitly written in terms of one variable. It involves treating one variable as a function of the other variable and using the chain rule to find the derivative.
Regular differentiation is used to find the derivative of a function that is written explicitly in terms of one variable. Implicit differentiation is used when the equation is not written explicitly in terms of one variable, and it allows us to find the derivative of a function when both variables are present in the equation.
The steps for performing implicit differentiation are:
Trigonometric functions are often present in equations that require implicit differentiation. When differentiating trigonometric functions, we use the chain rule and the derivatives of the trigonometric functions themselves, which can be found in a table of derivatives.
You can check your answer by substituting the values of the variables back into the original equation. If the resulting equation is true, then your answer is correct. You can also use a graphing calculator to graph both the original equation and your derivative and see if they match up.
