Vestibular function is hard for me. Please help
In summary: In the case of the head, the inertia of the endolymph keeps it from rotating too quickly, so it requires more force to make it rotate.
sameeralord
662
Vestibular function is hard for me. Please help!
Hello everyone,
[PLAIN]http://thalamus.wustl.edu/course/aud9.gif
When you turn your head in the plane of the canal, the inertia of the endolymph causes it to slosh against the cupula, deflecting the hair cells. Now, if you were to keep turning in circles, eventually the fluid would catch up with the canal, and there would be no more pressure on the cupula. If you stopped spinning, the moving fluid would slosh up against a suddenly still cupula, and you would feel as though you were turning in the other direction. This is the explanation for the phenomenon you discovered when you were 5.
First of all I don't understand the pic. Why is the endolymph moving in opposite direction to the movement of head, shouldn't it move the same way. How is inertia involved in this and what is the paragraph saying.
Thanks :smile:
I think the picture represents a horizontal plane in your head?
By the inertia of the endolymph, it keeps still while the head rotates. Just like a bucket with water. If you suddenly start to rotate the bucket, the water stays still inside. It doesn't start to rotate. But relative to the bucket walls, one can say that the fluid is rotating in the opposite direction. That's what the arrows are supposed to signify in the picture.
When the head rotates, the endolymph fluid and the copula collide, causing a pressure. This pressure is sensed by the brain, talling it that the head is rotating.
I'm no biologist, so there is a fair amount of uncertainty here, to put it mildly...
Thanks torquil, that was a great answer :smile: , much better than the explantion I noted before. I understood everything, how relatively water moves in other direction, but I have simple question since my physics is not good. When you rotate the water bucket, why does water stay still. Is it because you are only rotating the bucket and not the water, so water remains still. If you move it hard though water would also move right. I understood all the rest of the explantion though.
To get things to start rotating, like the water in the bucket, you need to act on it with a force. In the bucket example, not much force will be acted upon the water from the inner wall of the bucket since there is not much friction between it and the water, and the water viscocity is low. The water can slide relative to the inner bucket surface quite effortlessly, so therefore it takes a while of rotating the bucket until the water also rotates significantly, since the force that tries to make the water rotate is small.
Hello there,
I understand that vestibular function can be difficult to understand, but let me try to break it down for you. The vestibular system is responsible for our sense of balance and spatial orientation. It is located in the inner ear and consists of three semicircular canals filled with a fluid called endolymph.
The picture you see shows the three semicircular canals and the endolymph inside them. When you turn your head, the inertia of the endolymph causes it to move in the opposite direction of your head movement. This movement of fluid causes the cupula, a gelatinous structure inside the canals, to bend and stimulate hair cells. These hair cells then send signals to the brain, which helps us maintain our balance and sense of direction.
Now, when you keep turning your head in circles, the fluid eventually catches up with the canal and there is no longer any pressure on the cupula. This is why you may feel like you are no longer turning. And when you suddenly stop spinning, the fluid sloshes against the cupula that is now still, causing you to feel like you are turning in the opposite direction.
I hope this helps to clarify things for you. If you have any further questions, please don't hesitate to ask. Understanding the vestibular system can be challenging, but it is an important aspect of our daily lives. Keep exploring and learning!
1. What is vestibular function?
Vestibular function refers to the sensory system in our inner ear that helps us maintain balance and spatial orientation.
2. What are the symptoms of vestibular dysfunction?
Some common symptoms include dizziness, vertigo, loss of balance, and nausea. You may also experience difficulty with spatial awareness and coordination.
3. What causes vestibular dysfunction?
Vestibular dysfunction can be caused by a variety of factors, including inner ear infections, head injuries, certain medications, and aging. In some cases, the cause may be unknown.
4. How is vestibular dysfunction diagnosed?
A doctor or specialist will typically perform a series of tests, such as a physical exam, hearing tests, and balance assessments, to diagnose vestibular dysfunction.
5. What are the treatment options for vestibular dysfunction?
Treatment options may include medications, physical therapy, and vestibular rehabilitation exercises. In some cases, surgery may be necessary. It is important to work closely with a doctor or specialist to determine the best treatment plan for your specific condition.
  • Other Physics Topics
  • General Discussion
  • Quantum Interpretations and Foundations
  • Classical Physics
  • STEM Academic Advising
