Archimedes Principle to determine height of continental crust
In summary, our instructor told us that we can use Archimedes Principle to calculate the thickness of continental crust beneath a certain coastal geographical point (at sea level and not accounting for post glacial rebound effects). Data given:Water depth to the abyssal plain: 5000mThickness of abyssal oceanic crust: 10000mDensity of continental crust: 2800 kg/m3Density of oceanic crust: 3000 kg/m3Density of mantle: 3300 kg/m3Density of water: 1000 kg/m3Using the equation:In summary, our instructor told us that we can use Archimedes Principle to calculate the thickness of continental crust
kmam
I'm taking an introductory geology class and am having big trouble with the math questions, as it's been many many years since I last took math classes.
I am to use Archimedes Principle to calculate the thickness of continental crust beneath a certain coastal geographical point (at sea level and not accounting for post glacial rebound effects).
Data given:
Our course material does not include any formula for Archimedes Principle, just a brief description of how it works. So, I've googled to find a formula, but really am having a hard time understanding what it is I'm looking at. I have the basic formula, but I'm not seeing how I should use it to get what I need: Apparent immersed weight=weight-weight of displaced fluid.
I understand that the fluid here is the mantle, with density given for it, and of course the cont. crust density appears relevant, but that's about as far as I can get with this! And I don't understand why there is data for oceanic crust, water depth and density of water...
I'm assuming there are some other formulas involved in this calculation. I know thickness can be calculated from Volume=height*length*width. But nothing in the data seems to hint at length or width...?? aaah, this is so confusing, I don't know where to begin even. Any hints or tips will be greatly appreciated.
Why not take a volume which is 1m x 1m x height in metres? I'm guessing you should consider that floating on magma is a column of continent, and alongside that is a column of ocean and sea floor. If these columns were not displacing the same weight of magma, then one would sink and the other rise until equilibrium was achieved. Or something like that.
well it's not clear for me but i'll try to help:
the one u’ve found(immersed weight=weight-weight of displaced fluid) is used in case the body is not floating totaly immersed well it’s not the case because
density of the body(continental crust: 2800 kg/m3) less than that of the fluid(mantle: 3300 kg/m3)
so in that case the right one is: Fg = Fp weight of floating body (↓) = boyant force (↑)
thickness means height so try using this:
Fg = Fp
rs g Vs = rl g Vi ……………….. V=Ah
rs g As hs = rl g Ai hi …………..As=Ai
rs g hs = rl g hi
where: - rs density of the floating body ( ~ continental crust)
- g accn due to gravity (9.8)
- Vs volume of floating body ( ~ continental crust) As its area hs its height
- rl density of the liquid where the body floats
- Vi the volume under water of the water(~mantle)
Try , ask , and please explain more the question,I no nothing about geology
did you get to know how to solve the problem Kmam? I am doing the same course now and got stuck in the same question.
gunillaserin@hotmail.com
Hello. I am on the same course, and was searching for the answer to the same question. In case anyone else is looking for it in the future, here is a picture and the equation to use:
https://dl.dropboxusercontent.com/u/8908063/equation.png
[mirror: http://i.imgur.com/q5Ejoqe.png]
Note, that in this particular quetsion, zh does not exist as we're assuming we're at sea level. So just remove zh from the equation all together and you'll be fine :)
You begin with the equation:
zc.ρc = zw.ρw + zo.ρo + [zc-(zh + zw + zo)].ρm
First, you rearrange the equation so that zc is on its left hand side as follows:
zc.ρc = zw.ρw + zo.ρo + zc.ρm -(zh + zw + zo).ρm
zc.ρc - zc.ρm = zw.ρw + zo.ρo -(zh + zw + zo).ρm
zc.[ρc - ρm] = zw.ρw + zo.ρo -(zh + zw + zo).ρm
zc = [zw.ρw + zo.ρo -(zh + zw + zo).ρm]/[ρc - ρm]
Then you subsitute the values you were given for thickness and density.
Then you solve the equation!
Cheers!
1. What is Archimedes Principle and how does it relate to determining the height of continental crust?
Archimedes Principle states that the buoyant force on an object immersed in a fluid is equal to the weight of the fluid displaced by the object. This principle is used in determining the height of continental crust because the crust is floating on the denser mantle, and therefore displaces a certain amount of mantle material.
2. How does the density of continental crust affect the application of Archimedes Principle?
The density of continental crust is an important factor in applying Archimedes Principle. Continental crust is typically less dense than the mantle, so it will displace a larger volume of mantle material. This means that the height of continental crust can be determined by measuring the amount of mantle material displaced.
3. What tools or techniques are used to measure the displacement of mantle material by continental crust?
Various techniques can be used to measure the displacement of mantle material by continental crust. Some examples include seismic reflection and refraction, gravity measurements, and satellite imaging. These methods can provide data on the density and thickness of the crust and mantle, which can be used to calculate the height of the continental crust.
4. How accurate is using Archimedes Principle to determine the height of continental crust?
The accuracy of using Archimedes Principle to determine the height of continental crust depends on the accuracy of the data collected and the assumptions made in the calculations. Different techniques may also have varying levels of accuracy. Overall, this method can provide a good estimate of the height of continental crust but may not be entirely precise.
5. What are some limitations of using Archimedes Principle in determining the height of continental crust?
One limitation of using Archimedes Principle is that it assumes the crust and mantle have uniform density and thickness, which may not always be the case. Additionally, the presence of structures such as mountain ranges or deep basins can complicate the calculations. It is also important to consider potential errors in data collection and analysis when using this method.
  • General Math
  • Other Physics Topics
10K
