Starting initial value problems when terms are expressed only in x
In summary: B=1/2...Therefore x(t)= (1/2...)(e^2t)+(1/2...)(e^-2t)does this seem correct?Yes, this is correct. You could also use the general solution of the second order homogeneous differential equation with constant coefficients: x(t)=e^mt(A cos(wt)+B sin(wt)). The characteristic equation is m^2-4=0, the solutions are m=±2. The general solution is x(t)=e2t(A cos(2t)+B sin(2t)). x(0)=A=1, x'(0)=2A+0B=0. A=0.
metalscot
How should I go about starting the following two problems
solve the following initial value problems
x''-4x=0 ; x(0)=1, x'(0)=0
and
x''-4x'+4x=0 ; x(0)=1, x'(0)=0
Should i use a general solution with the basis m^2-4=0 for problem one and m^2-4x+4=0 for the second?
and
Yes, if you meant the solutions in form exp(mt), and m^2-4m+4=0 for the second problem.
ehild
ehild
Thanks ehild, do I then use x=1 and and t=0 to find constant A and x'=1 and t=0 to find constant B for both questions?
The general solution is x=A exp(m1t)+B exp(m2t). Use t=0 x=1 to get one equation for A and B, and t=0, x'=0 in x'(t) to get the other equation for A and B. You get two equations, with two unknown, solve for A and B.
ehild
ehild
Working through my first problem x''-4x=0 ; x(0)=1 x'(0)=0
solutions m=+/-2i
so complex solution (e^2it, e^-2it)
since (cos2t, sin2t)
x(t)=Acos2t-Bsin2t
For x(0)=1
1=A-0
so
A=1
x'(t)= -2Asin2t-2Bcos2t
for x'(0)=0
0=0-2B
so
B=0
therefore
x(t)=cos2t
The solutions of the characteristic equation m^2-4=0 are real m=±2.
ehild
ehild
Im sorry ehild I am confused by this, does this mean that my A and B constants are correct making x(t) = cos2t a solution?
cos(2t) and sin(2t) are not solutions.
ehild
If one solution to the characteristic equation of a linear differential equation with constant, real, coeficients is the complex number a+ bi, then [itex]y= e^{at}cos(bt)[/itex] and [itex]e^{at}sin(bt)[/itex] are solutions.
In particular, if the real number a (+ 0i) is a root then a solution is [itex]y= e^{at}[/itex].
If the imaginary number 0+ bi is a root then two solutions are cos(bt) and sin(bt). (Of course, complex, including imaginary, roots of an equation with real coefficients always come in conjugate pairs: [itex]a\pm bi[/itex].)
Which case applies here?
the real number is a root, so my solution must be in the form y= e^{at}[/itex]. ?
metalscot said:
the real number is a root, so my solution must be in the form [itex]y= e^{at}[/itex]. ?
Yes, and you have two values for the exponent, the solutions of your characteristic equation m^2-4=0. You have written that already, but you said that the solutions are 2i and -2i, which is wrong. m^2-4=0 is equivalent m^2=4. What are the roots?
ehild
ehild
does the above not mean that -2 and 2 are roots?
So that then m1 and m2 are -2and 2?
Yes, 2 and -2 are the roots.
You got the characteristic equation originally by assuming that the solution of the differential equation x''-4x=0 is of the form x(t)=emt.
The second derivative is x''(t)=m2emt.
Substituting x(t) and x''(t) back into the DE, you get
m2emt-4emt=0,
factoring out the exponent :
(m2-4)emt=0, which can be true for all t if
m2-4 =0.
This is true for m=2 and m=-2, so the solutions of the DE can be written really in the form of x(t)=emt, and we have two independent solutions, x1(t)=e2t and x2(t)=e-2t.
The general solution is a linear combination of these two functions,
x(t)=Ae2t+Be-2t.
Find A and B so that x(0)=1 and x'(0)=0.
ehild
m2emt-4emt=0,
m2-4 =0.
x(t)=Ae2t+Be-2t.
ehild
I think ehild I have finally arrived at the correct solution
when x(t) = Ae^2t + Be^-2t
x(0)=1
Ae^2t + Be^-2t=1
and x'(0)=0
2Ae^2t - 2Be^2t =0
so with simultaneous equations A = 1/2 AND B = 1/2
I arrive at
x(t)=1/2 e^2t + 1/2 e^-2t
I hope you can tell me this is correct?
Yes, it is correct. Nice work! Now solve the other problem.
ehild
ehild
Thank you ehild. I believe I have now managed the other problem, can you confirm the solution to be x(t) = e^2t - 2te^2t
I really appreciate all the help you have given me.
Good, it is the solution! But use parentheses in the exponent!
ehild
Hi,
I too am trying to solve the second of your problems.
I have used the characteristic equation to find ou that m = 2
I have then used the general solution:
x(t) = Ae^m0t + Bte^m0t
This has given me the following:
x(0) = Ae^2t + Bte^2t = 1
Ae^2(0) + B(0)e^2(0) = 1
A(1) + B(0)(1) = 1
A + 0 = 1
Therfore A = 1
For B:
x'(0) = 2Ae^2t + 2Bte^2t = 0
This is where I am getting confused. Plugging in the 0 value for t:
2Ae^2(0) + 2B(0)e^2(0) = 0
2A(1) + 2B(0)(1) = 0
As A = 1
2(1)(1) + 2B(0)(1) = 0
2 + 2B(0)(1) = 0
2B(0)(1) = -2
Now from your final answer I see that A = 1 and B = -2 to give x(t) = e^2t - 2te^2t
When I multiply out the RHS of the above equation does B remain even though it has been multiplied by zero? I can't see this as in the equation to solve A as 1 the B side equals 0 and the sum is the same. I am sure I am missing something obvious but the more I look at it the more clouded it becomes!
ollyfinn said:
Hi,
A(1) + B(0)(1) = 1
A + 0 = 1
Therfore A = 1
For B:
x'(0) = 2Ae^(2t) + 2Bte^(2t) = 0
x(t) = Ae^(2t) + Bte^(2t)
The second term is a product of t and e^(2t), apply the product rule!
x'(t) = 2Ae^(2t) + 2Bte^(2t)+Be^(2t).
ehild
Aah that's it! Thank you very much for your help.
1. What is an initial value problem?
An initial value problem is a mathematical problem that involves finding a function or equation that satisfies a given set of conditions or constraints. These conditions often include an initial value, which is the value of the function at a specific point or time.
2. How are initial value problems related to terms expressed in x?
Initial value problems often involve functions or equations that are expressed in terms of a variable, such as x. This variable represents the independent variable in the problem and is used to determine the value of the function at different points or times.
3. Can initial value problems be solved without knowing the initial value?
No, the initial value is a crucial part of an initial value problem and is necessary for finding the solution. Without the initial value, the problem is considered incomplete and cannot be solved.
4. What are some common methods for solving initial value problems when terms are expressed only in x?
Some common methods for solving initial value problems include the separation of variables, using Euler's method, and using Laplace transforms. Each method may be more or less suitable depending on the specific problem and the desired level of accuracy.
5. How can initial value problems be applied in real-world situations?
Initial value problems have many real-world applications, such as in physics, biology, and economics. They can be used to model and predict the behavior of various systems, such as populations, chemical reactions, and electrical circuits.
11K
