Express moment / expectation value in lower order expectation values
In summary, the conversation discusses the search for a proof of the equation <x6> = <x>6+15s2<x>4, where <x> represents an expectation value and s is the standard deviation. It is mentioned that the equation is not true in general, and that it only works for first order Taylor approximation. The conversation also presents an example to illustrate the equation, but ultimately concludes that it does not work for <x6>.
flux2
Hello everybody,
I'm looking for a proof of the following equation:
where the brackets denote an expectationvalue and s is the standard deviation.
Thanks in advance!
Mathematics news on Phys.org
It is not true in general. For example if <x> = 0, <x6> will not = 0 unless x = 0 itself.
Sorry, I forgot to mention. It's a first order Taylor approximation.
Thanks for the reply,
Cheers
We have for example:
<x2> = <x>2+s2
<x4> - <x2>2 ≈ 4s2<x>2 (to first order)
Now combining both equations yields:
<x4> = <x>4+6s2<x>2
Unfortunately this doesn't work that easily for <x6>
I am happy to provide a response to this content. The equation you are looking for is known as the "moment/expectation value relationship" and is a fundamental concept in statistical mechanics. It states that the expectation value of a higher order moment (in this case, <x6>) can be expressed in terms of lower order moments (specifically, <x>6 and <x>4). This relationship is useful in simplifying complex calculations and understanding the behavior of a system.
To understand this relationship, let's first define what moments and expectation values are. Moments are statistical quantities that describe the shape and distribution of a set of data. In this case, <x6> represents the 6th moment of the data set, which is a measure of the spread of the data around its average value. On the other hand, expectation values are the average value of a quantity in a given system. In this case, <x>6 and <x>4 represent the average values of the 6th and 4th powers of the variable x, respectively.
Now, the proof of the moment/expectation value relationship is based on the definition of the standard deviation, which is given by the square root of the 2nd moment minus the square of the 1st moment. Using this definition and some mathematical manipulation, we can show that <x6> is equal to <x>6 plus 15 times the standard deviation squared times <x>4. This is exactly the equation you were looking for.
In summary, the moment/expectation value relationship allows us to express higher order moments in terms of lower order moments, making it a powerful tool in statistical mechanics. I hope this explanation helps you understand the equation and its significance. Keep exploring and asking questions, and best of luck in your research!
1. What is the definition of an express moment?
An express moment is a mathematical concept used in quantum mechanics to describe the average value of a physical quantity, such as position or momentum, in a given state.
2. How is the express moment related to the expectation value?
The express moment is equal to the expectation value when the order of the moment is equal to the order of the expectation value. However, the express moment can also be expressed in terms of lower order expectation values.
3. What are lower order expectation values?
Lower order expectation values are the expectation values of lower order moments, such as the first or second moment. They are used to express the express moment in terms of simpler quantities.
4. Why is it important to express the moment in terms of lower order expectation values?
Expressing the moment in terms of lower order expectation values allows for easier calculations and provides a more intuitive understanding of the physical quantity being measured.
5. How do you calculate the express moment in terms of lower order expectation values?
To calculate the express moment in terms of lower order expectation values, you can use the formula: Mn = ∑k=1n Cn,k ⟨Xk, where Mn is the n-th order express moment, Cn,k is a coefficient, and ⟨Xk is the k-th order expectation value of the physical quantity X.
  • Atomic and Condensed Matter
