Gravitational Acceleration at Different Latitudes
In summary, the rotation of the Earth affects the apparent gravitational acceleration at different latitudes, with a slight decrease in acceleration at the equator due to centrifugal force. Using the formula v=rω^2, the weight of an object at the North Pole would be 0.034m/s^2 less compared to the equator due to this decrease in acceleration. This calculation assumes a perfectly spherical Earth.
duggielanger
The rotation of the Earth affects the apparent gravitational acceleration at
different latitudes. At a location on the Equator, a man’s weight is registered
as 709.7 N on a set of very accurate scales. Assuming a perfectly spherical
Earth, determine what the same set of scales would register for the same
man’s weight at the North Pole
Not sure I have used f=ma and w=mg but don't think I need these as the Earth is perfectly spherical
So it might be a=v^2/r
As far as I can figure if Earth is perfectly spherical then there will be no change in weight due to the force of gravity. But maybe because of the rotation and Centrifugal force this might have a slight effect.
Correct.
So, how much effect ?
So if I find the angular velocity first ω=2∏rad/T and then v=rω^2
Plugged in values
2*3.14/(24h*3600s/h)=7.3x10^-5 rads
v=6.378x10^6m/(7.3x10^-5)^2rads=0.034m/s^2
So the force of gravity will be 0.034m/s^2 less
and then I can find the weight .
Dose this seem right
Plugged in values
2*3.14/(24h*3600s/h)=7.3x10^-5 rads/s2
v=6.378x10^6m/(7.3x10^-5)^2rads/s2=0.034m/s^2
So the [STRIKE]force[/STRIKE] acceleration of gravity will be 0.034m/s^2 less
Does this seem right
Yes, except for some units and saying force rather than acceleration .
(Corrected above)
Ok thanks A lot SammyS your help is appreciated
And ... I forgot to say,
Welcome to PF !
1. What is gravitational acceleration at different latitudes?
Gravitational acceleration at different latitudes refers to the varying strength of the Earth's gravitational pull at different points on its surface due to its spherical shape and rotation.
2. How does gravitational acceleration change with latitude?
Gravitational acceleration decreases slightly as latitude increases, meaning that objects will weigh slightly less at the equator compared to the poles.
3. What factors affect gravitational acceleration at different latitudes?
The main factors that affect gravitational acceleration at different latitudes include the Earth's rotation, its shape, and its mass distribution.
4. How is gravitational acceleration at different latitudes measured?
Gravitational acceleration can be measured using a variety of methods, including pendulum experiments, satellite measurements, and precise gravity meters.
5. Is there a significant difference in gravitational acceleration at different latitudes?
The difference in gravitational acceleration at different latitudes is relatively small and not usually noticeable in everyday life. However, it is an important factor to consider in scientific research and engineering projects.
