Integral forms of Momentum and Energy Equations
In summary, the momentum and energy equations involve various terms including mass flux, time rate of change of momentum, body and surface forces, heat transfer, work, and energy flux. Each term has a specific physical meaning and can be represented in different forms, but ultimately all contribute to the understanding of momentum and energy in integral forms.
Red_CCF
532
Hi
I was reading a book that introduced momentum and energy in integral forms and I had some confusion regarding what the terms meant. All integrals below are closed integrals
For the momentum equation, the result was:
F = d(mV)/dt = ∫∫ρ(V[dot]dS)V + ∫∫∫∂(ρV)/∂tdV
From product rule, d(mV)/dt = dm/dt*V + mdV/dt. I can see how dm/dt*V is reflected in ∫∫ρ(V[dot]dS)V but I do not see how mdV/dt is reflected in ∫∫∫∂(ρV)\∂tdV?
For the energy equation, the result was:
∫∫∫qdotρdV - ∫∫pV[dot]dS + ∫∫∫ρ(f[dot]V)dV = ∫∫∫∂(ρ(e+V^2/2))/∂t + ∫∫ ρ(e+V^2/2)V[dot]dS. p is pressure, e is specific internal energy, f is body force per unit mass
, V is velocity, and qdot is heat transfer per unit mass
from another book, another form of this equation was:
Qdot - Wdot = dEcv/dt + mdotout (hout+V^2/2) - mdotin (hout+V^2/2)
I'm basically wondering, is the mdot*h (the enthalpy term) reflected in the terms ∫∫ ρ(e+V^2/2)V and ∫∫pV[dot]dS or in other words is mdot*(e + V^2/2)-> ∫∫ ρ(e+V^2/2)V and mdot*p*v -> ∫∫pV[dot]dS?
Thanks
In the momentum equation, the terms are as follows:
[tex]\iiint\rho\vec{v} (\vec{v}\cdot d\vec{s})[/tex]
represents the mass flux across the surface of the control volume.
[tex]\iint\dfrac{\partial (\rho\vec{v})}{\partial t}dV[/tex]
is the time rate of change of momentum in the control volume. Usually there is also a body force term and a surface force term (pressure and viscosity if you are doing viscous flows).
For your energy equation, the terms are as follows:
[tex]\iint\dot{q}\rho\;dV[/tex]
is the rate of heat added to the control volume.
[tex]-\iint p \vec{v}\cdot d\vec{s}[/tex]
is the rate of work done on the fluid in the control volume by pressure forces.
[tex]\iiint\rho(\vec{f}\cdot\vec{v})\;dV[/tex]
is the rate of work done on the fluid in the control volume by body forces.
[tex]\iiint\dfrac{\partial}{\partial t}\left[ \rho\left( e + \dfrac{|\vec{v}|^2}{2} \right) \right]dV[/tex]
is the the time rate of change of energy inside the control volume.
[tex]\iint\rho\left( e +\dfrac{|\vec{v}|^2}{2}\right)\vec{v}\cdot d\vec{s}[/tex]
is the net energy flux across the surface of the control volume.
1. What is the significance of integral forms of momentum and energy equations in physics?
The integral forms of momentum and energy equations are fundamental equations in physics that describe the behavior of fluids and other physical systems. They are used to calculate the total amount of momentum and energy within a system, and can be applied to a wide range of real-world problems, from fluid flow in pipes to the motion of planets in space.
2. How are integral forms of momentum and energy equations derived?
Integral forms of momentum and energy equations are derived from the fundamental principles of physics, such as Newton's laws of motion and the conservation of energy. They involve the integration of infinitesimal quantities over a given volume or surface, and can be solved using mathematical techniques such as the divergence theorem and Stokes' theorem.
3. What are the main assumptions made in the derivation of integral forms of momentum and energy equations?
The main assumptions made in the derivation of integral forms of momentum and energy equations include the conservation of mass, the absence of external forces, and the absence of viscous forces. These assumptions allow for the simplification of the equations and make them applicable to a wide range of physical systems.
4. Are integral forms of momentum and energy equations applicable to all types of fluid flow?
Yes, integral forms of momentum and energy equations can be applied to all types of fluid flow, including incompressible, compressible, and turbulent flow. However, the specific equations used may differ depending on the properties of the fluid and the type of flow being studied.
5. How are integral forms of momentum and energy equations used in practical applications?
Integral forms of momentum and energy equations are used in practical applications to solve real-world problems in various fields, including engineering, meteorology, and astrophysics. They are used to predict the behavior of fluids and other physical systems, and can also be used to optimize designs and improve the efficiency of systems.
9K
  • Classical Physics
