What happens to a photon wave packet when half out of a moving device?
In summary: If something is traveling at a high velocity in a direction perpendicular to your line of sight and emits light, what would happen to the light? Anyone know?If the source is stationary, the distribution pattern of photons might like something like a bell curve. And if the source is in motion, and we normalize the location of the photons to direction the of the source, adjusting for the speed of light, will the bell curve get wider due only to experimental error? Or will the source motion have a widening effect on the distribution of photons even after normalizing for the source direction and experimental error?
PTopper
I was wondering if there has been a study done on what happens to a photon wave packet when half out of a device while the device emitting it is moved.
If never done it would make an interesting scientific experiment to see where the influence of moving the device ends.
I'd like to see or perform an experiment showing how much of the wave packet can exit the photon source, while the motion of the photon source will still influence the location where the photon impacts a photon detector.
http://imageshack.us/a/img850/929/experimentz.png
Science news on Phys.org
That model is not useful for your experiment. Photons are emitted or not emitted, but not "50% out of something".
If the photon reaches the detector and its wave function collapses, obviously it was emitted.
In order to be emitted, it must exit the source at some time prior to striking the detector, right?
As others have mentioned, you would not be able to "catch" a photon half way out of an emitter.
Think of it this way, the absolute fastest anything can move is the speed of light. This is the speed that photons move. The photon is also one of the smallest elementary particles. The smallest thing moving at the fastest speed is as close to instantaneous as it is possible to get.
There's no chance, even with technology way beyond what we currently have, to catch a photon "half way out" of an emitter.
Not to mention that a photon is a discrete packet size. There is nothing that exists which is a semi-photon. This is one of the fundamentals of the "quantumness" of our universe. Some things cannot be subdivided.
This 'experiment' cannot be done.
You are under a misconception that a photon is made of a wave packet. This is not true. The wave function describes the photon according to our own rules and math. It allows us to make predictions about photons, such as what the probability of a photon hitting a detector at a specific location is. The wave function, or wave packet, is not "something". It is a mathematical concept.
"The wave function describes the photon according to our own rules and math. It allows us to make predictions about photons, such as what the probability of a photon hitting a detector at a specific location is. "
So, how will the predictions about the locations of the photons hitting the screen be affected by the source being in motion?
I'm not sure actually. I don't know how it would affect the direction of travel, wavelength, or what. If something is traveling at a high velocity in a direction perpendicular to your line of sight and emits light, what would happen to the light? Anyone know?
The behaviour of the system is independent of the reference frame you use to observe it. So consider the situation in a frame where the light source is stationary and you are moving, then transform the result to whatever frame you want.
Yes, that is what I am asking as I do not know what would happen in that case.
1. What is a photon wave packet?
A photon wave packet refers to the quantum mechanical description of a photon, which is a fundamental particle of light. It is a localized disturbance in the electromagnetic field that carries energy and momentum.
2. How does a photon wave packet behave in a moving device?
A photon wave packet behaves according to the principles of special relativity. This means that its energy, wavelength, and frequency may be affected by the motion of the device, but the speed of light (c) remains constant.
3. What happens to the photon wave packet when half of it is out of the moving device?
The photon wave packet will continue to move at the speed of light (c) in the direction it was originally traveling. However, the portion of the packet that is outside of the device may experience a change in its energy, wavelength, or frequency due to the relative motion.
4. Can the photon wave packet split into two separate packets when half of it is out of the moving device?
No, the photon wave packet cannot split into two separate packets. It is a fundamental particle and cannot be divided into smaller parts. However, the effects of the motion on the packet may make it appear as if it has split into two separate packets.
5. Are there any real-life applications or implications of understanding what happens to a photon wave packet in a moving device?
Yes, understanding the behavior of a photon wave packet in a moving device is crucial in various fields such as optics, telecommunications, and quantum computing. It allows us to accurately predict and manipulate the behavior of light, which has numerous practical applications in our daily lives.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
