What is a Standard State or Reference State of an element?
In summary, a standard state or reference state of an element is its thermodynamically most stable state at 1 bar at a given temperature. This information is useful for thermochemistry calculations, in which reactions are involved.
marc32123
Can someone please give me a simple explanation of what a standard state or reference state is? I don't quite understand the way wiki describes it which is -
The standard state, also known as reference state, of an element is defined as its thermodynamically most stable state at 1 bar at a given temperature (typically at 298.15 K). In thermochemistry, an element is defined to have an enthalpy of formation of zero in its standard state. For example, the reference state for carbon is graphite, because the structure of graphite is more stable than that of the other allotropes.
Chemistry news on Phys.org
If you are going to be doing thermochemical calculations in which reactions are involved, you are going to want to be able to determine changes in enthalpy between reactants and products and changes in free energy between reactants and products (the latter to calculate equilibrium constants). You can't have a table of these changes for every possible reaction under all possible conditions (because it would require too much paper), but, because enthalpy and free energy are state functions, you can tabulate the enthalpy and free energy of the individual chemical species, and then use this to determine the changes in reactions. If you are doing this for individual species, it is very convenient to specify the enthalpies and free energies of the species only in a specific reference state (this requires very little data), and then determine the values of these parameters at other temperatures and pressures using, say, integrals of heat capacities over temperature. This approach allows you to calculate heat of reaction and free energies of reaction at a wide range of conditions, based on only a minimum amount of tabulated data. The reference state that is usually used is 25 C and 1 atm. The values specified for the elements under these conditions are zero. But, if a chemical compound is involved, the values specified are those required to go from the elemental species to the chemical compound at the reference state. This gives you what you need to solve thermochemical problems.
chet
1. What is a standard state of an element?
A standard state of an element refers to the specific physical state (solid, liquid, gas) and conditions (temperature, pressure) that are used as a reference point for measuring and comparing the properties of that element.
2. How is a standard state determined for an element?
The standard state of an element is determined by the International Union of Pure and Applied Chemistry (IUPAC), which sets internationally recognized standards for the physical properties of elements. These standards are based on a combination of theoretical calculations and experimental data.
3. Why is a standard state important in chemistry?
A standard state is important because it provides a consistent reference point for comparing the properties of different elements and compounds. It allows for accurate and meaningful comparisons between different measurements and experiments, and it helps to ensure that scientific data is reliable and reproducible.
4. Can the standard state of an element change?
Yes, the standard state of an element can change if the IUPAC revises its standards or if new experimental data becomes available that warrants a change. However, these changes are rare and are usually only made after thorough review and discussion within the scientific community.
5. How is a standard state different from a reference state?
A standard state and a reference state are similar concepts, but they are not exactly the same. A standard state is a specific set of conditions used as a reference point for measuring the properties of an element, while a reference state is a set of conditions used to define a standard state. In other words, a standard state is a reference state, but a reference state may not always be a standard state.
  • Chemistry
  • Chemistry
  • Chemistry
  • Astronomy and Astrophysics
