| New Reply |
Logarithms - Show that the expression is true |
Share Thread | Thread Tools |
| Dec14-12, 04:26 PM | #1 |
1. The problem statement, all variables and given/known data
Show that the following expression is true: 0.2*0.8 = -14dB + (-1.94dB) 2. Relevant equations 1 dB = 10log10(x) (where x is a ratio of two quantities) 10log10(ab) = 10log10(a) + 10log10(b) 3. The attempt at a solution 0.2*0.8 = -14dB + (-1.94dB) 0.16 = -15.94dB ___________________________ 10log10(x)=-15.94 x=10-15.94/10=0.0255 ___________________________ 0.16 ≠ 0.0255 (so either my math is wrong or the expression is not true...) |
| Dec14-12, 04:45 PM | #2 |
Mentor
Is this actually how the problem is presented? |
| Dec14-12, 04:49 PM | #3 |
| Dec14-12, 05:00 PM | #4 |
On your note about units... Decibels are unitless (dimensionless)... So aside from that, am I missing something else?
| Dec14-12, 05:12 PM | #5 |
Mentor
I guess that the idea is to convert each dB value using the conversion formula, and see if the two dB values add up to .16.
| Dec14-12, 09:16 PM | #6 |
JJBladestr, let's start with the logarithm of 0.2. What do you get for that?
What do you get for the logarithm of 0.8? Now let's multiply each of those by 10, not 20. Add the dB values together. and take the anti-log of the sum. |
| Dec15-12, 08:04 AM | #7 |
10log10(0.8) = -0.9691 dB -6.9897 dB + -0.9691 dB = -7.9588 dB 10-7.9588/10=0.16 But that has not proven anything about the left side equaling the right side. It has merely manipulated the left side and we are back to the original question. |
| Dec15-12, 12:36 PM | #8 |
You're right. Where did the -14 dB and the -1.94 dB come from? If they are part of the problem then either they are not equal or you should have used 20*Log instead of 10*Log, but I see nothing in the problem to indicate that.
| Dec15-12, 04:06 PM | #9 |
I asked the professor what was going on with the problem and he said that the math I did was right but the problem was not formed properly.
The thing with online schools is some of them have a group of staff members who create the homework/labs/tests and a separate group who instructs. This is an ABET-accredited school, which is good because I'm going to be an Electrical Engineer at the end of it all. I see what you mean about 20*log(something). The "20" would indicate that two voltage levels were being compared because the formula for voltage gain has a "20" in it. |
| New Reply |
| Tags |
| decibel, expression, logarithm, true |
| Thread Tools | |
Similar Threads for: Logarithms - Show that the expression is true
| Thread | Forum | Replies | ||
| show that x is a square expression | Precalculus Mathematics Homework | 8 | ||
| Simplifying Expression using Logarithms | Calculus & Beyond Homework | 34 | ||
| Simplifying an Expression using Logarithms | Calculus & Beyond Homework | 6 | ||
| Is it true that the derivative of 1/(random polynomial expression) is 0? | Calculus & Beyond Homework | 3 | ||
| why this expression is true.. | Calculus & Beyond Homework | 4 | ||
