Titration method to determine HCl concentration in a mixture
In summary, the author is discussing how to determine the concentration of hydrochloric acid in a solution containing dissolved ferric chloride. The author suggests using a titration method with NaOH, and if the solution still contains acidic elements, adding a small amount of NaOH to determine the end point. The author also mentions that the ferric chloride may have a significant influence on the reaction, and that Monitoring the H+ concentration with a pH electrode may be necessary.
Bluetheice
I have a solution which contains unknown amount of dissolved ferric chloride (FeCl3) and hydrochloric acid.
Can I use the titration method with NaOH to determine the concentration of HCl?
I was concerned since dissolved FeCl3 is also acidic, and the fact that NaOH will try to neutralize it as well. Thus the titration result may not be accurate.
Further more the solution is a brown to begin with, what indicator should I use to clearly tell the end point?
Chemistry news on Phys.org
Some of this response is a little vague, so you would need to do an information search:
The Fe(III) can either be titrated with EDTA or some chelator; you might not need to adjust the pH too much; or you might try(?) an ion specific electrode for measurement. The acidity to pH 6 or 7 should be possible, but I'm not sure how much interference would occur from the Ferric chloride. You could either try a titration for total chloride (Mohr or Fajans method), or use a chloride specific ion electrode to measure chloride. Check a good quantitative book for finding how to do some of these. (Maybe there is a precipitation method for ferric?)
Shouldn’t the excess HCl be neutralized first by the NaOH, before the FeCl3?
If the solution is still acidic and you add a small amount of NaOH solution, one of two possible reactions could occur. The OH- ions could react with the excess H+ ions and simply form water, or the OH- ions could react with the Fe+3 ion and form an Iron Hydroxide precipitate. But I would think that if Iron Hydroxide is formed and the solution is still acidic, then the excess H+ ions should react with the Fe(OH)3 and take it back to FeCl3 and water.
Hi, first of all thank you both for the reply.
Perhaps I should have describe the problem in more detail, the mixture is used for etching steel. We know that the initial solution is 40%w/w FeCl3 and 1.7% w/w HCl.
During etching Fe3+ is consumed, the reaction is
2Fe3+ + Fe -> 3Fe2+
and Fe2+ react with hydrochloric acid and oxygen in the air to regenerate Fe3+
The reaction is
3FeCl2 + 3HCl + 3/4 O2 -> 3FeCl3 + 3/2 H2O
So basically we want to know the HCl concentration in order to ensure the regeneration takes place.
To: symbolipoint
I think the ferric chloride will have significant influence, because we know the content of FeCl3 is so much higher than HCl. As you can see from the reaction above, the chloride is not involved in the reaction and thus is does not represent the HCl content.
To: mrjeffy321
I am not sure which will be neutralize first. Lets' assume that there are no HCl present in the solution, then how could I determine the end point? Wouldn't I end up neutralizing just Fecl3?
This reaction produces additional FeCl3 (and you know where the extra chloride comes from...). You need to replace the chloride (as HCl) that is consumed in the regeneration step. Analyze the concentration of Fe+3 and F3+2 before and after the process and account for the amount of chloride before and after. The difference will indicate the amount of HCl consumed.
The total reactions:
[tex]Fe^0 + 2FeCl_3 \xrightarrow~ 3FeCl_2[/tex]
[tex]2FeCl_2 + 2HCl + \frac{1}{2}O_2 \xrightarrow~ 2FeCl_3 + H_2O[/tex]
You can monitor the H+ concentration with a pH electrode.
To: chemisttree
Yes, the problem is figuring out how much HCl to add. To do that we first need to know how much is in the mixture.
Finding difference of Fe3+ and Fe2+ should work, but I was concerned that it may only work IF HCl is added AFTER the etching process. Our mixture contains 1.7% w/w of HCl before etching, this means HCl is consumed in 2 ways:
1: Reaction with steel during the etching
Fe+ 2HCl -> Fe2Cl
2: The regeneration after etching
This means some HCl is already consumed before the regeneration, so that the difference is not really the HCl consumed. I don't know if FeCl3 dissolve steel more rapidly than HCl. If it does then only a small amount of HCl would be consumed during etch and the difference should give fairly accurate estimate of HCl consumed. Could you give me more details, what do I need to find the concentration of Fe3+ and Fe2+?
I have tried to measure pH with a pH meter, however the change is very small. Perhaps the content of HCl is too low, and/or the change is too small to make a difference?
2Fe3+ + Fe -> 3Fe2+
The reaction is
To: symbolipoint
To: mrjeffy321
Here is another idea which might still be too crude for what you want. It assumes (maybe wrongly) that the ferric chloride is like weakly acidic. You can experimentally determine the acidity of ferric chloride, and you already know the acidity of HCl. Choose two different endpoints for an acidity titration. Maybe choose pH 4 and pH 7. When you then know the acidity of HCl and the acidity of ferric chloride, you can use this information when you titrate your sample to both endpoints. You can choose whatever acidity units that you like; best suggestion is either as HCl, or as milliequivalents or equivalents per unit volume.
Bluetheice said:
To: chemisttree
Fe+ 2HCl -> Fe2Cl
You can think of this reaction (it should be FeCl2 rather than Fe2Cl... a minor typo) as the operative one if you wish but hydrogen is produced in this reaction as well. I don't believe that much hydrogen is produced from your process but it is possible I suppose. Regardless, the additional iron salts come from the zero valent steel and are associated with the chloride that ultimately comes from consumption of HCl if all of the Fe+2 salts are converted to Fe+3 in the following reaction:
To do this properly, you will need to determine the total iron content (both Fe+2 and Fe+3 separately) and calculate the total chloride associated with that. Determination of the amount of chloride (from some previous determination/speciation) will tell you how much HCl was consumed since ALL additional chloride will come from the HCl.
What is the titration method used for?
The titration method is used to determine the concentration of a substance in a mixture. In this case, it is used to determine the concentration of HCl in a mixture.
What equipment is needed for a titration?
The equipment needed for a titration includes a burette, a pipette, a beaker, a conical flask, an indicator, and a titration stand.
How does the titration method work?
The titration method involves adding a known volume of a solution with a known concentration (titrant) to a known volume of a solution with an unknown concentration (analyte) until a chemical reaction between the two is complete. The volume of titrant added is then used to calculate the concentration of the analyte.
What is the purpose of using an indicator in titration?
An indicator is used in titration to signal when the reaction between the titrant and analyte is complete. It changes color at the endpoint of the titration, indicating that the reaction is finished and no more titrant needs to be added.
What are the sources of error in titration?
The sources of error in titration include inaccurate measurements of volumes, improper mixing of solutions, and misinterpretation of the endpoint. Other factors such as the purity of the chemicals, temperature, and atmospheric pressure can also affect the accuracy of the results.
15K
  • Chemistry
14K
