Exploring Electrical Voltage U between Parallel Flat Plates
In summary, the conversation discusses the relationship between electrical voltage, electric field strength, and force in a parallel plate capacitor. The calculations show that the voltage between the plates is directly proportional to the electric field strength, and that the force on the surface unit is determined by the charge and electric field strength. Doubling the distance between the plates results in a halving of the voltage and force. The final part discusses the effect of maintaining a constant voltage on the electric field strength and force between the plates.
mmoadi
157
- How much is the electrical voltage U between two evenly electrified parallel flat plates, distanced d = 1 cm, if the strength of electric field between them is E = 1 V / m?
- What is the strength of electric field to the left and to the right of each plate?
- What is the force on the surface (area) unit between the two plates?
- What are the voltage between the plates and the force on the surface unit as a result of doubling the distance between the two plates?
- How is the strength of the electric field and force between the two plates altered (changed), if the voltage is maintained constant?
Influencing constant is ε(0) = 8.85 × 10^-12 As / Vm.
V= E*d
F= Q*E
V= Qd/ Aε(0)
E= Q/ Aε(0)
Q= CV
First part: How much is the electrical voltage U between two evenly electrified parallel flat plates?
V= 1 V/m* 0.01 m= 0.01 V
Second part: What is the strength of electric field to the left and to the right of each plate?
E= V/ d
E= 0.01 v/ 0.01 m= 1 V/m
Third part: What is the force on the surface unit between the two plates?
E= ½ Q*V → Q= 2E/ V
Q= 200 C
F= Q*E= 200 N
Fourth part: What are the voltage between the plates and the force on the surface unit as a result of doubling the distance between the two plates?
d= 2 cm= 0.02 m
V= d*E= 0.02 V
Q= 2E/ V= 100 C
F= Q*E= 100 N
ARE MY CALCULATIONS CORRECT?
Fifth part: How is the strength of the electric field and force between the two plates altered (changed), if the voltage is maintained constant?
I need some help with this part. Any hints?
Thank you for helping!
The second part: The field between the plates is 1 V/m, but the field outside the plates isn't
Third part: The E in [itex] E = \frac{1}{2}QV [/itex] is energy, the E in [itex] F = Q E [/itex] is the strength of the electric field, so this calculation is wrong. You need the force per square meter anyway. It's easiest to assume the area of the capacitor is 1 [itex] m^2 [/itex] and then to compute the capacity and the charge and then use [itex] F = Q E [/itex]
Fourth part: wrong for the same reason as third part.
Fifth part: if the voltage is the same, the electric field strength, which is volt/meter must change
if the distance changes. use V = E * d.
Thank you for helping, I will just have to do additional :smile:calculating!
1. What is electrical voltage?
Electrical voltage, also known as electric potential difference, is the difference in electric potential between two points in an electric field. It is measured in volts (V) and is the force that drives the flow of electric current.
2. How is electrical voltage calculated?
Electrical voltage is calculated by dividing the energy (in joules) by the charge (in coulombs) between two points in an electric field. It can also be measured using a voltmeter.
3. What are parallel flat plates?
Parallel flat plates refer to two flat, parallel conducting surfaces that are placed close together. They are often used in experiments to study electrical voltage and electric fields.
4. How is electrical voltage explored between parallel flat plates?
To explore electrical voltage between parallel flat plates, a voltmeter can be used to measure the voltage at different points between the plates. The separation distance between the plates and the charge on the plates can also be varied to observe the changes in voltage.
5. What is the significance of exploring electrical voltage between parallel flat plates?
Exploring electrical voltage between parallel flat plates is important in understanding the behavior of electric fields and how voltage is affected by different factors such as distance and charge. This knowledge can be applied in various fields, including electrical engineering, physics, and telecommunications.
