Figuring power dissipation increase w/ heatsink
In summary: Interesting point. It got me thinking, though... It's not exactly true for heatsinks of semiconductor devices. Not sure what you mean by that. Is there some variation in how they work if there are large temperature variations? Or is it different for different kinds of semiconductors? Typically, if you take a PC processor (for example) and put a bigger heat sink on it, you get a lower operating temp, but its heat dissipation remains the same. If the "load" is everything, then your comment is still correct, I think. But if the load is being supplied by a transistor on a heat sink, then the total power consumed depends on the heat sink and
applefat
Hello!
I'm trying to make sense of what is probably simple. Imagine I have an IC package that is rated to dissipate at most 1 Watt. The thermal resistance from case to ambient is not known (could maybe be generalized).
I have a heatsink that has a thermal resistance of 20°C/W. Can I estimate what the new power dissipation of this package is?
I've looked at the wiki page on thermal resistance and it compares a source of power to a current source, a temperature differential to a voltage differential, and thermal resistance to a resistor. That analogy confuses me in this scenario however, because wouldn't adding a heat sink put another thermal resistance in series with the junction-case resistance, thus increasing the overall thermal resistance of the system?!?
You are correct. Thermal resistances add in series. Wikipedia.org is helpful for some things, but can be confusing (and wrong) sometimes.
You would add Theta(junction-to-case) plus Theta(case-to-ambient via heatsink) to get your total Theta(junction-to-ambient), in general.
Note that the power dissipated doesn't change, just the temperature gradient.
Quiz Question for the Original Poster (OP) -- Why not? Does it matter if the semiconductor device is a bipolar transistor versus a MOSFET? Does the circuit topology matter?
If the sinked transistor is supplying the current for the load, and the load stays constant while the efficiency of the supplying transistor varies with temperature, then the power dissipated by the supply plus load vaies with the sinking thermal resistance. That efficiency has opposite temperature coefficients for bipolar versus MOSFET transistors.
If the "load" is everything, then your comment is still correct, I think. But if the load is being supplied by a transistor on a heat sink, then the total power consumed depends on the heat sink and type of transistor (slightly).
Different Quiz Question for anybody -- how can you tell qualitatively when a heat sink is sized correctly?
So a cooler BJT will output less heat at cooler temperatures due to an increase of efficiency while the opposite is true for MOSFETs?
There are only small to no variations in temperature with increased current loading?
I did not know that their efficiency varied with temperature - how much/over what temparature range?
Vbe has the same temperature coefficient as a diode, so about -2mV/degreeC. As the junction temperature increases, the bipolar transistor becomes more efficient, so it dissipates less heat for the same power transferred. MOSFETs look mostly resistive, so their Vds voltage drop increases with temperature, and their efficiency drops at high temperatures.
Pretty small effects, but they do enter into sizing and margin calculations for circuit power calculations.
1. What is power dissipation and why is it important to consider?
Power dissipation refers to the amount of energy that is converted into heat when a component or device is in use. It is important to consider because excessive heat can damage components, leading to malfunction or failure. Additionally, high power dissipation can also affect the overall efficiency and performance of a system.
2. How does a heatsink help to reduce power dissipation?
A heatsink is a device designed to dissipate heat by increasing the surface area for heat to escape from a component. It works by transferring the heat from the component to the surrounding air, allowing it to dissipate more efficiently. This reduces the overall temperature of the component, helping to prevent damage and maintain optimal performance.
3. How do I calculate the increase in power dissipation with a heatsink?
To calculate the increase in power dissipation with a heatsink, you will need to know the thermal resistance of the heatsink and the power dissipation of the component without a heatsink. The increase in power dissipation can be calculated using the formula: P increase = (T junction - T ambient) / thermal resistance. This will give you the increase in power dissipation in watts.
4. Can any heatsink be used to reduce power dissipation?
No, not all heatsinks are created equal. The effectiveness of a heatsink in reducing power dissipation depends on its design, material, and thermal resistance. It is important to choose a heatsink that is specifically designed for the component and has a low enough thermal resistance to effectively dissipate heat.
5. Are there any other factors that can impact power dissipation with a heatsink?
Yes, there are other factors that can impact power dissipation with a heatsink. These include the ambient temperature, air flow around the heatsink, and the contact between the heatsink and the component. It is important to consider these factors when designing and implementing a heatsink to ensure optimal performance and heat dissipation.
  • Electrical Engineering
  • Mechanical Engineering
