Is Every Point in The Universe a Microcosm of the Whole of Creation?
In summary, the theory of special relativity is based on the concepts of a constant speed of light and the universality of the laws of physics in any inertial frame. This leads to the conclusion that natural space-time is not Euclidean, as the Minkowski metric equation shows a minus sign in front of the T term. Light cones in Minkowski space-time collapse to a single point, but in the real world, they radiate out from a light source forming a cone. This suggests that the source contains everything on the surface of the light cone, making it a microcosm of creation. However, this does not explain the experience of space and time, which seems to be a subjective experience and dependent on the state
Bilbo
One of the great theories of physics is the theory of special relativity.
This theory is based on two concepts: -
1. The speed of light is constant.
2. The laws of physics are the same in any inertial frame, regardless of position or velocity
Given the validity of these concepts and a little analysis of their implications we can conclude that natural space-time is not Euclidian. By that we mean that when time is taken into consideration the theorem of Pythagoras does not apply. The square of the interval between two events is given by: -
Delta s^2 =Delta X^2 + Delta Y^2 + Delta Z^2 - Delta cT^2
This equation is known as the Minkowski metric.
The important distinction between this equation and the Pythagorean equivalent is the presence of the minus sign in front of the T term. If the geometry of the real world was Euclidian then this would be a plus sign. This is a very important result from special relativity and gives space-time characteristics which are not predictable through our normal intuitive view of the world.
One such characteristic is the path of light beam. When light radiates out from a light source the path i, when represented on a space-time diagram, forms a cone known as a light cone. The curious thing is when we try to represent a light cone in the geometry defined by the Minkowski metric; it collapses to a single point. In the real world geometry the light hasn’t gone anywhere. The light energy is instantaneous transferred from one place in the universe to somewhere else without experiencing any time or traversing any distance. The light cone has collapsed to the source In Minkowski space-time everything on the surface of the light cone must be contiguous (next to) with each other. The location of the light source contains not only the source itself but the entire contents of the perceived surface of the light cone radiating from it; both future and past. The source is therefore a microcosm of everything existing on the light cone.
But this not all! Light cones radiating out from any location in space-time must always intersect each other. This means there are zero interval paths connecting everything that has happened, everything that is happening, and every thing that will happen. Making every event a microcosm of the whole of creation.
This begs the question if this was true then why do we experience space and time and why doesn’t everything happen at once? From the perspective of The Minkowski geometry the universe is just there and does not experience the evolution of time. Time seems to be a subjective experience and depends amongst other things on the state of motion of the observer. Although the entire world seems connected by zero interval paths, there are many other paths in the world which have finite extensions and an observer is limited to traveling these, we are forbidden to travel along a zero interval path; to do so would require infinite energy.
Space news on Phys.org
from what i can perceive, yes . everything is/or is a part of/ energy cycles/progressions. a cycle within a cycle is a microcosm, due to the variance in size.
from what i can perceive, yes . everything is/or is a part of/or both.. energy cycles/progressions. a cycle within a cycle is a microcosm
just because we named the phenomena time, doesn't mean we understand it, but it does exist, it's very observable.
It seems to me that no one has ever observed time. One only observes motion. The time component of motion is a mental construct consisting of arbritary units such as 'a second' or 'a minute'. Watching a clock is really not observing time. You are just observing motion which is the only empirical component of time.
It seems obvious that a clock or the rotation of a planet are artificial and arbitrary measurements. The only other place time seems to exist is in the mind. As such time can only be viewed as an abstract concept. :bugeye:
When I first saw this posted twice, I thought it was a mistake. Then I realized it was a cycle!
To Bilbo:
Could we then conclude from application of the Minkowski metric that "that which is an intermediate interval between events of existents is Minkowski space-time" --thus making Minkowski space-time an objective experience for those existents ? Just an abstract thought that comes from reading your post.
It has always amazed me that some seem to think that the actions of photons (both real and imaginary) somehow control what happens in the quark world, which is the foundation of the REAL world we live in.
It is not the photons that connect everything. It is the gravitons.
There is no real or empirical evidence at all that "every event is a microcosm of the whole of creation". Sometimes it is best to step back from the equations and observe what is really happening.
sd01g said:
...It is not the photons that connect everything. It is the gravitons...
I have a question. It is known that force carrier particles cannot be classified as either matter or antimatter. But, consider the force carrier particles called pions. While each matter pion is the antimatter of itself, each individual pion is composed of more fundamental matter + antimatter entities called quarks.
So, now my question--is it "in theory" possible that the graviton as a force carrier has fundamental matter + antimatter entities of which it is composed (using the pion as an analogy) ? If yes, what are these called, if not, why not possible--what law(s) of physics would be violated. Thanks.
Mesons are unstable and the graviton is probably vey stable so I would not expect the graviton to be composed of any quark-antiquark combinations. The graviton is also so weak that it is probably not composed of any combination of any known subatomic particles.
I speculate (at current knowledge levels, it is more speculating than theorizing) that the quark is not a fundmental particle. The quark is probably a composite particle composed of some configuration of sub-sub atomic particles (let's call them the subG Particles) that interact to form the various forms of quarks, and in the process generate the graviton particle. Because the graviton is such a weak force it would likely be generated by sub-sub atomic particles.
If one were to ask Leucippus or Democritus what they knew about atoms, they would probably say that about all they knew was that atoms were very, very small. Today, we know about the same about gravitons.
Lets say the universe (the whole of creation) is a cycle - there is a valid model for this, as I'm sure you're aware - then there is indeed empirical evidence that "every event is a microcosm of the whole of creation (the universe)".
Energy is measured in cycles per second. Seconds are also cycles, therefore energy is measured in cycles within cycles. Frequencies are also measured in cycles. Any system you care to mention is a conglomeration of cycles.
Therefore, if we can make an empirical study of cycles ... need I say more.
:bugeye:
:bugeye:
Lets say that the Empirical Universe is a very large collection of all matter and energy that exist and moves in something (or nothing) called space. That is IT--the Empirical Universe.
The concepts of cycles and seconds and frequencies and measurements are all constructs of the mind and are part of the rational universe. It is OK to attempt to construct a rational description of "every event is a microcosm of the whole of creation" but empirical verification requires empirical evidence, not rational constructs.
Obviously, the 'concept' of anything is a construct of the mind. I agree, seconds, frequencies and measurements are indeed constructs of the mind. However, cycles (not the concept of them) are as 'objective' as anything gets. I would urge you to check out www.cyclesresearchinstitute.org or simply Google 'study of cycles'. Once you have accepted the objective reality of cycles you will see that the empirical verification you seek is , in fact, possible. :bugeye:
mosassam said:
sd01g;1220573 Obviously said:
www.cyclesresearchinstitute.org[/url] or simply Google 'study of cycles'. Once you have accepted the objective reality of cycles you will see that the empirical verification you seek is , in fact, possible. :bugeye:
True empirical verification is done in real time and is always required to be reverified in real time in the future if it is challenged. Rational constucts are necessary to assist in real time empirical verification but they can never stand alone or replace empirical verification.
Empirically we detect motion and then use rational constucts to assist in evaluating it. The concept of cycles can be useful in helping to understand and predict future movement. Movement is an intrinsic component of matter/energy, cycles are not. Cycles come and go but movement never stops. Movements are microcosms of the Universe but cycles are not. Cycles are verified rationally because they are defined rationally.
Bilbo said:
Given the validity of these concepts and a little analysis of their implications we can conclude that natural space-time is not Euclidean.
If we assume the theory of relativity is correct, and I think that is a reasonable assumption, then yes, space-time is not Euclidean. It is not Euclidean because of the lack of a metric, instead it has a pseudo-metric, and also it is not Euclidean because it is intrinsically curved.
But strictly speaking this is not a metric, since it violates the triangle inequality, at most you can say it is a pseudo-metric.
So we have to conclude that natural space-time violates the triangle inequality.
I would not use the term collapse though, since nothing really collapses here.
No, the light did not transfer at all in Minkowski space-time.
But I understand what you are trying to say.
You can find this idea reflected in for instance twistor space, twistors were developed by Roger Penrose. In twistor space the path of a light beam is represented by a point and an event is a Riemann sphere.
Sounds a bit mystical here, not quite sure what you mean. I think that many are quickly turned-off by teminology like "microcosm" and "creation".
Conceivably for the same reason we observe quantum state reductions instead of quantum state space.
A measurement is what a system X asserts about itself, so obviously there are limits, both in QM, in the form of the uncertainty principle, and in SR, in the form of indeterminism of "whose clock is really slowing down".
Well there are more than just null paths to consider with regards to causal connections. Null paths simply demarcate the boundaries, and "boundaries" is a rather confusing word when it comes to a space-time that has a Minkowski, or more generally, a Lorentzian pseudo-metric. For instance consider the 4-volume with a constant distance in a Minkowski space-time, you will notice that this volume is infinite.
Well in classical theory that is correct. But in QM it is not forbidden for a mass particle to travel at c.
For instance Dirac has argued that while the average velocity of an electron, which obviously has mass, is < c, the speed, with all the "quantum zigzagging" is c. But he may be wrong.
But in this topic one important factor is missing, space-time is not Minkowskian, since Minkowskian space-time is flat. We have to extend the causal structures of Minkowskian space-time onto curved space-time, which is called a Lorentzian space-time. It is far from obvious, at least to me, how this is straight forward. For instance, standard path integral methods simply do not work on a Lorentzian curved space-time. Wick rotations do not work either.
Now try to think one step further and assume that the null paths on a Lorentzian manifold are subject to the Heisenberg uncertainty principle. Then we could not even determine if something is time- or space-like!
I am a complete layman trying to form his own 'model' of reality. I would like to know how space-time can be flat.
Isn't what your saying about cycles implying there is no time? is there any space that can contain no time/all time? If there is no linear time from point a to b, but only a cycle of time 2 pi r (?)--a rotation--and, space is a linear measurement (i.e. angle, depth, length, breadth, etc.) then there is no space and no time right? there is only infinity, and only one infinity can ever exist so there is only 1.
Then there is only cycles within cycles (part-icles) existing as ebb and flow, sort of a rhythm, a sine curve. There is no beginning and no ending. It is all indeterminate. But, all matter has a beginning and an ending.
Penrose tiling will help some of the questions I think. Also check out a penrose tiling in conjunction with L-systems and Koch curve, and the fibonacci series. This will link you to the only spectrum of energy (life force), the infinite EM spectrum from 0 (absence), 1-infinity. Only 1, you see not linear, but everywhere in all directions. right? indeterminate energy. A koch curve represents itself within itself indefinitely. 1. Everything in the universe is nothing more than a representation of 1 or the absence of 1(0) which actually doesn't exist either because infinity is 1. Also check out experiments by Alain Aspect and Holograms, the division of a hologram specifically contains all the parts of the whole it was divided from. You see--still infinity, right, still only one image.
Man, I must have hit my head pretty hard.
Infinity is like a ruler. The markings are arbitrarily set, and they are time/distance. They are essentially imaginary, because each marking can be divided down to infinity (therefore the markings don't exist). This is why there is no smallest particle (because they can continue to be divided to infinity). And from anyone of those markings to infinity, the ruler becomes infinitely long and infinitely wide. The term 'universe' is just an arbitrary marking of the ruler. This is also why there is no need for a big bang. because if whatever was the singularity that existed 'in the beginning' contained all of the energy of infinity, there is no need or such a thing as expansion (since everything in it would have merely been smaller increments of the singularity to infinity)--it is imaginary. right? I mean, if something could possibly contain infinity (1, all) why is there a need to expand? can you shrink infinity? Can you grow infinity? No it simply is, be, now. Energy can neither be created no destroyed, simply take new form, and that form is microscopically similar to the whole --hence hologram, and incarnation of matter. Therefore if there was a big bang, energy would have been created, or if not then energy would have had to come from some external source by absorption (endothermically). right?
Energy can neither be created nor destroyed: in a closed system? in an open system? is infinity open or closed? Energy is itself indeterminate. If we measure it, then we go back to the ruler of infinity above, the measurement is arbitrary, and can always be subdivided, renamed, reconfigured, etc. It is malleable depending on your view.The ruler of all energy is the EM spectrum.
The only being that is omnipotent and omniscient is God right? The only 'ruler' by which we can know him is Christ, or Light, right? Then that makes everything that exists a EL-ment (God-part-icle) of the All or Him, right? Hey, I'm not preaching just taking this thread to the hilt.:shy:
Then menkowskian space-time cannot be flat, right? It is also just an observation of a part-icle an apportionment, a mark on the ruler of the ALL.
What is meant by "Is Every Point in The Universe a Microcosm of the Whole of Creation?"
"Is Every Point in The Universe a Microcosm of the Whole of Creation?" is a philosophical and scientific concept that suggests that every individual point in the vast expanse of the universe contains within it a reflection or representation of the entire universe. This idea is often associated with the concept of fractals, where patterns and structures repeat themselves at different scales.
How is this idea supported by scientific evidence?
While this concept may seem abstract, there is scientific evidence that supports the idea that the universe operates on a similar pattern at different scales. For example, the structure of a human brain resembles the structure of the universe with its interconnected networks and clusters. Additionally, the distribution of galaxies in the universe follows a similar pattern to the distribution of neurons in the brain.
Does this mean that every individual is a microcosm of the universe?
While it is intriguing to think that we are all connected to the vast expanse of the universe in some way, it is important to note that this concept does not suggest that every individual is a literal representation of the entire universe. Rather, it highlights the interconnectedness and similarities between different scales and levels of existence.
What implications does this concept have for our understanding of the universe?
This concept challenges our traditional view of the universe as a collection of separate and disconnected entities. It suggests that everything in the universe is connected and that there is a fundamental unity and order that governs the functioning of the universe. This can have profound implications for our understanding of the world and our place in it.
Are there any criticisms of this concept?
As with any philosophical or scientific concept, there are criticisms and differing opinions about the idea that every point in the universe is a microcosm of the whole of creation. Some argue that this concept is too abstract and lacks empirical evidence, while others believe that it oversimplifies the complexity of the universe. Ultimately, the validity of this concept is still a topic of debate in the scientific community.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
