Revisiting the Flaws of the Light Clock in Special and General Relativity
In summary, the "light clock" thought experiment is often used to illustrate time dilation in special relativity. However, the Twin Paradox and other arguments show that using special relativity alone is not sufficient to resolve this thought experiment. Instead, one must turn to general relativity and consider the effects of acceleration on the clock. However, there are still debates about the role of acceleration in resolving the paradox, with some arguing that it is not necessary and others claiming that it is crucial.
  • #106
JesseM said:
Why would you do that, though? According to my calculations (which ended up with the same equation you got), a = 2v*gamma/Ta, so that implies v*gamma = a*Ta/2, not aTa. Did I make an error?
Yes, you did, you need to think about the definition of "cruising" speed.
  • #107
JesseM said:
Care to point out the error?
Please read my answer to kev's alleged finding an error in my formula. You are both missing two periods of acceleration.
The formulas in post #80 are correct. Yours and kev's are not.
  • #108
JesseM said:
Not necessarily, what about two observers who pass one another moving inertially in space and note their ages as they pass? And even if you assume they started at rest relative to one another, if you assume acceleration was quasi-instantaneous (as is commonly assumed in these kinds of problems to make the math simpler), then the question of which one accelerated initially is irrelevant to figuring out their elapsed time.
Obviously because you measure the elapsed time between the event when they pass with a relative speed and when they return. What happens before is irrelevant.
JesseM said:
all that matters is which one accelerated to turn around once they were a significant distance apart.
Exactly, acceleration again!
  • #109
OK, so you're saying that the rocket also initially accelerated for a time Ta to achieve the cruising speed of v, and then at the end decelerated for a time of Ta as well. Still, I trust you have no objection to my and kev's equations in a different scenario where the rocket just passed by the "stationary" observer (i.e the one who remains inertial and has a velocity of zero in the frame we're considering) already moving at speed v, continues to cruise for time Tc/2, then accelerates to turn around for time Ta, then cruises back towards the "stationary" observer, passing him after another period of Tc/2 (and they compare clocks as they pass).
Anyway, given the scenario you are considering with initial acceleration and final deceleration, I have no objection to the second term, let me think about the first term...but before I do that, can you tell me if Tc represents the total cruising time in both directions, or just the cruising time in one direction?
  • #110
one direction, this is why it gets doubled in the final formula
  • #111
I think it only because you are considering a,v and gamma for half the acceleration phase while I am considering the total acceleration phase. We end up with the same results.
  • #112
starthaus said:
...which clearly contradicts your earalier claim that the contribution of the acceleration period is negligible.
I was talking about a different scenario where the acceleration phase was much more extreme and took place in seconds. With very extreme acceleration with the acceleration phase period tending to zero, the time dilation due to acceleration becomes negligable. The greater the acceleration is, the more you can ignore it.
  • #113
OK, thanks. Then the starting equation in your scenario and with your definitions would be:
[tex]d \tau=\frac{2T_c}{\gamma}+\frac{4c}{a} \, \, arcsinh(a T_a / c)[/tex]
Another equation on the relativistic rocket page says that velocity v as a function of coordinate time T would be v(T) = aT / sqrt[1 + (aT/c)2], so if we know it takes a time of Ta to go from 0 to the cruising speed v, that means that v = aTa / sqrt[1 + (aTa/c)2], so:
v2 = a2*Ta2 / (1 + a2*Ta2/c2)
v2 = c2 * a2 * Ta2 / (c2 + a2*Ta2)
v2/c2 = a2 * Ta2 / (c2 + a2*Ta2)
(1 - v2/c2) = [(c2 + a2*Ta2) - (a2 * Ta2)] / (c2 + a2*Ta2) = c2 / (c2 + a2*Ta2) = 1 / (1 + a2*Ta2/c2 )
gamma = 1/sqrt(1 - v2/c2) = sqrt(1 + (aTa/c)2)
So plugging that into the top equation,
[tex]d \tau= \frac{2T_c}{\sqrt{1 + (aT/c)^2}} +\frac{4c}{a} \, \, arcsinh(a T_a / c)[/tex]
...which agrees with what you had.
  • #114
Sorry but this is just absurd, you cannot ignore acceleration, great or small, in the twin experiment. Without acceleration there is no absolute time dilation.
I am still waiting for an example of the twin experiment without acceleration but "in terms of velocity and spacetime path lengths", which, if I understand correctly, in your view does not require acceleration.
  • #115
It is obvious that the equations given by Starthaus are symbol for symbol copied from wikipedia, so it would have have been helpful if he credited wikipedia and gave a link to where the wikipedia scenario is described less vaguely than Starthaus described it.
In the wikipedia scenario there are 4 acceleration periods and 2 cruising periods so that explains why our equations differ, because the scenarios and definitions of the periods differ.
I think you will find if you use my equations with [tex]T_a[/tex] and [tex]T_c[/tex] defined as total times for the whole journey, you can use the same equation for any of number of acceleration and cruising phases, without having to have different equations for different twins scenarios, as long as the acceleration is the same for all the acceleration phases.
  • #116
In an earlier reply to you I acknowledged that in any situation where differential ageing occurs then acceleration is involved, but you can calculate the time dilation without using the acceleration. That is not the same as saying acceleration is not required.
  • #117
I have no desire to be squeezed between Starthaus and the others in this argument but that is the situation in the standard twin "paradox", you need 4 accelerations and optionally two cruising periods..
  • #118
But if the acceleration is instantaneous, you don't actually need to consider the acceleration phase when calculating the elapsed proper time. If you know the ship cruised at speed v1 for a coordinate time of t1, then instantaneously accelerated to turn around so it had a speed of v2 in the other direction and took an additional coordinate time of t2 to reunite with the inertial observer, then the elapsed time for the observer that turned around is just t1*sqrt(1 - v12/c2) + t2*sqrt(1 - v22/c2). So in this sense, the acceleration can be ignored in your calculations.
Most textbook discussions of the twin paradox assume instantaneous accelerations.
  • #119
Acceleration is essential in the twin experiment. Without acceleration there is no absolute time dilation.
Show me a calculation where you completely ignore acceleration (proper or inertial) that shows an absolute time dilation and I show you where you made a mistake!
  • #120
Passionflower said:
Acceleration is an essential in the twin experiment. Without acceleration there is no absolute time dilation.
I don't know what you mean by "completely ignore", but by "ignore" I only mean that you don't have to consider the contribution that the accelerating phase makes to the total elapsed proper time, since you are treating the acceleration as instantaneous (I think my meaning was fairly clear from the context, especially given my comment 'you don't actually need to consider the acceleration phase when calculating the elapsed proper time'). In that sense the calculation I already gave you in my last post ignores acceleration, though of course acceleration plays a role in that it explains why v1 on the outbound leg may be different than v2 on the inbound leg (and since inertial paths are geodesics and geodesics always maximize proper time, it plays a conceptual role in understanding why the inertial twin is always the one who ages more than the one who turns around, similar to the idea that a straight line between two points in Euclidean geometry always has a shorter length than any bent path between the same points).
  • #121
JesseM said:
it plays a conceptual role in understanding why the inertial twin is always the one who ages more than the one who turns around).
Indeed, that is why it very important in STR education to stress that fact!
  • #122
The proper time of the traveling twin can be calculated using
[tex]d \tau=\frac{T_c}{\gamma}+\frac{c}{a} \, \, asinh(a T_a / c)[/tex]
Where [tex]T_c[/tex] and [tex]Ta[/tex] are total cruise and acceleration times, then when a is very large and [tex]Ta[/tex] is necessarily brief because the terminal velocity v is reached very quickly, the second term goes to zero and this is why some textbooks assume instantaneous acceleration and the error due to ignoring the the time dilation during the acceleration phase is negligible. The equation can not be reversed to consider the point of view of the accelerating twin, because it is only valid for an inertial observer.
  • #123
I know, I pointed out to you that doing so is incorrect.
Not only that your math was incorrect but your physics was unrealistic. Calculate the acceleration that woulg get your rocket to your 0.8c in 1s . What do you get?
You can't get high speeds in short time (see the exercise above)
Err, this one is in the category "not even wrong".
  • #124
No, it doesn't. Do the exercise I gave you and you'll find how false it is.
As a simple alternative, use [tex]a=10g[/tex] (a huge number) and evaluate the second term. What did you get?
This is false as well. There are papers on this subject. Try to get your facts straight.
  • #125
If you're talking about the conceptual explanation for why one twin ages less than the other, of course. But from the context of kev's comments it was clear he was just saying the acceleration phase didn't always need to be considered in actual calculations of elapsed proper time. Also, when you originally objected to "acceleration is not relevant" type arguments in post #89, it followed on the heels of a discussion I was having with starthaus where we were talking about the clock hypothesis, and there it is important to emphasize the reverse, that acceleration is indeed completely irrelevant if you want to know the instantaneous rate of a clock at a single instant, the rate is solely a function of its instantaneous velocity.
  • #126
Virtually all textbook calculations involve simplifications, and instantaneous accelerations (which imply infinite proper acceleration) are routinely assumed in textbooks on SR. Anyway this sort of simplification would be a reasonable approximation if the acceleration phase only lasted a few days or weeks while the inertial legs lasted for years, which might be realistic for an interstellar journey.
I assume kev meant that the equation you posted wouldn't accurately calculate elapsed proper time if we were using the time coordinate of a non-inertial frame, which is correct.
  • #127
Velocity with respect to what?
If your answer is with the prior instant, than it is the acceleration between the two instants that changed the rate! So what causes clock rates to change? Acceleration!
If the answer is different I am happy to await your further explanation.
  • #128
No one is disputing the "clock hypothesis". What I and passionflower are disputing is the incorrect statements made by kev.
  • #129
It would be good if you stopped defending kev's hacks for a while and you let him answer,. By stepping in for him every time you preclude him from learning.
This is not what he claimed.
  • #130
An inertial coordinate system.
How could you talk about a "velocity" with respect to an "instant"? I'm guessing you meant to ask "rate of a clock with respect to what"? If so, the answer would again be relative to the time coordinate of an inertial frame (i.e. [tex]d\tau /dt[/tex]). The clock hypothesis says that this only depends on the instantaneous velocity in that frame (it's always true that [tex]d\tau /dt = \sqrt{1 - v^2/c^2}[/tex]), it doesn't depend on instantaneous acceleration or instantaneous position or anything else.
  • #131
Well, perhaps I object to your silly arguments because you use a lot of the same type of silly arguments on me, like how the irrelevant practical concerns you raise about realistic accelerations here resemble the irrelevant practical concerns about the size of real gaps in train tracks in the train-on-a-bridge thread. If you cracked open a real physics textbook once in a while instead of thinking you can learn everything about physics from from wikipedia, you might see that it's universal to include all sorts of simplifications in order to illustrate the basic physical concepts involved.
Irrelevant practical concerns aside, can you point to a single error in math or physics kev has made in this discussion?
It isn't? What do you think he meant by "the point of view of the accelerating twin", if not a non-inertial rest frame for the accelerating twin?
  • #132
A change in velocity in an inertial coordinate system is equivalent with acceleration. Do you actually agree with me that a change in velocity in an inertial coordinate system causes a change in clock rate?
  • #133
Sure, why wouldn't I? The clock hypothesis says the instantaneous clock rate depends on the instantaneous velocity (so the instantaneous acceleration is irrelevant), which means if you're considering some extended interval of time where the clock is accelerating, the instantaneous velocity will be different at the beginning of the interval than the end, so the clock rate will be different too.
  • #134
Perhaps this is because the two of you share the same misconceptions and , occasionally, the same errors in computations.
...and the same penchant for dragging out past discussions where we disagreed.. This shows a severe smallness of character.
I happen to have a lot of books and I have cited them repeatedly, so your remark is both insulting and unwarranted. I have cited Rindler repeatedly on GR. My favorite book that I cite from is Moller precisely because he doesn't resort to any of the hacks that you and kev seem to favor.
Read the thread, I pointed them out as he made them.
It means that the calculation , in kev's incorrect opinion, cannot be made from the perspective of the accelerated twin. This is false.
  • #135
...meaning that the elapsed proper time is a function of proper acceleration, as demonstrated by the formula I've posted. To make matters even more interesting, when one does the calculations from the perspective of the accelerating twin, the elapsed time definitely depends on acceleration. There is an excellent paper by H.Nikolic (who happens to be the excellent physics forums science advisor called Demystifier) on this subject on this subject. There is another one by Minguzzi and one by Iorio, I suggest that you read them, they would go a long way in correcting your misconceptions about the acceleration role on the elapsed proper time. Here, start with the Nikolic one. I am attaching it such that you don't continue to claim that I do my learning from wiki.
  • HNikolic.pdf
  • Minguzzi.pdf
  • Iorio.pdf
  • #136
First of all I do not know why you constantly raise the clock hypothesis, as far as I see nobody is contesting this here.
Ok, good, so let me ask you this: Would you then agree that [itex]\gamma[/itex] in this case directly depends on the rate and duration of the acceleration? And if so, do you readily see that since [itex]\gamma[/itex] is a factor in the formula to calculate the absolute time dilation that effectively the rate and duration of acceleration is a factor, not the only factor, but nevertheless a factor, of the absolute time dilation?
  • #137
Point to any "misconceptions" or "errors" I have made. The only reason for the initial difference between your equation and mind (and kev's) is that we made different physical assumptions, I assumed the only acceleration was at the turnaround while you assumed (or copied your equation from a wikipedia page which assumed) an initial and final acceleration as well. If you think I have made any physical or mathematical errors aside given my physical assumptions, please point them out instead of just making vague accusations.
I just like to point out how you use the same irritating tactics in thread after thread.
And do you think that's a book that avoids simplifying assumptions, of the kind you call "hacks"?
starthaus said:
My favorite book that I cite from is Moller precisely because he doesn't resort to any of the hacks that you and kev favor.
I don't know which book you're referring to, what's the title?
I only saw you object on the basis that he made different physical assumptions than you, or that he used "hacks" (simplifications of the type that are routinely used in textbook discussions), or that you interpreted an English statement by him in a silly uncharitable way (like the one below). Again, show me a single clear error in his actual calculations.
No, he didn't say a calculation of elapsed time couldn't be made, he just said you couldn't use the same equation ('The equation can not be reversed') to calculate the elapsed time from the point of view of the accelerated twin, where I presume by "point of view" he meant a non-inertial frame (especially since he went on to say that the equation can't be reversed 'because it is only valid for an inertial observer').
  • #138
Most of the time.
C.Moller "The Theory of Relativity"
Look thru the thread, there are plenty. You can look for the "Err,no".
You tend to "presume" a lot.
  • #139
I didn't say anyone was contesting it. But starthaus brought it up in post #80, and I was just making the point in the next few posts after that that it could be misleading to both bring up the clock hypothesis and at the same time make statements like the one that the elapsed time will "depend on the acceleration a". See my summary of the point I was making in post #92
Gamma in what case? Gamma at any given instant of course is just a function of the velocity at that instant, so presumably you mean "depends on" in some other way, like that the velocity at a given instant itself depends on the clock's history of past accelerations (in that sense one could even say that gamma for a man in a rocket 'depends on' his decision 20 years earlier to enter the space academy and become an astronaut)
What does "absolute time dilation" mean? Are you talking about elapsed proper time rather than instantaneous clock rates? And by "factor", do you just mean some sort of causal factor, or do you mean something more specific like that we must include a variable representing acceleration in our calculations?
  • #140
If a formula is wrong it should be called out without fear of personal retribution, if it is called incorrectly wrong it should be called out as well again without fear of personal retribution.
Could we please get back on track and leave personal remarks out?
