Heat treatment of steel and the effect on it's hardness
In summary, a user named mrfoxy asked a question on the forum about the effects of heating steel on its hardness. He asked if heating steel to 200C and then allowing it to cool back to room temperature would result in the hardness rising to its previous level or staying at its lower value. Another user named Ian welcomed mrfoxy to the forum and suggested showing their own attempts at answering the question. Mrfoxy clarified that the question was not for homework but rather a real-life problem at work. They also mentioned a theory about physical material properties and expressed their wish for it to be homework. Another user then explained that heating steel to 200C should not have a significant effect on its hardness, and provided additional information on
mrfoxy
Newbie to the forum, so forgive me if I post this in the wrong place!
If I heat steel (a bearing outer race to be exact) from room temperature to approx 200C, the hardness of the steel will reduce. If the temperature is then allowed to reduce back to room temperature, what will happen to the hardness? Will it rise to what it was previously, or will it stay at its lower value? Thanks
Ian
Science news on Phys.org
Hi mrfoxy, welcome to PF. For homework-style questions, we ask that you show how you've tried to answer them first. Then you'll likely get useful comments.
Nothing to do with homework, but every question on this forum could indeed be classed as homework?! It's actually a problem we're having at work that's costing us thousands and I had a theory about classic physical material properties. wish it was homework, thanks I'll look elsewhere...
Going up to 200C shouldn't have much effect on bearing race hardness. 150C is a base value for tempering after hardening, but according to the annealing (re-softening) wiki page:
The temperature range for process annealing ranges from 260 °C(500 °F) to 760 °C(1400 °F), depending on the alloy in question.
Once annealed the metal will remain softer, but tempering just reduces stresses in hardened materials such that they are less brittle.
Heat treating is a big, and fascinating if you are a metal-geek, subject. This wiki article and subsequent links are a good place to start:
http://en.wikipedia.org/wiki/Heat_treating
Welcome to the forum!
I can tell you that the hardness of steel is greatly affected by its heat treatment. When steel is heated, its internal structure changes, which in turn affects its physical properties such as hardness. When heated to 200C, the steel undergoes a process called tempering, which results in a decrease in hardness. This is because the heat allows the steel to release internal stresses and become more ductile.
As for your question about the hardness returning to its previous value after cooling back to room temperature, it depends on the specific steel and the temperature it was heated to. If the steel was heated to its critical temperature (the temperature at which its internal structure changes), then cooled slowly, the hardness may return to its original value. However, if the steel was heated beyond its critical temperature, the change in internal structure may be irreversible and the hardness will remain at its lower value.
I hope this helps answer your question. Keep exploring and learning about the fascinating world of steel and its properties!
1. What is heat treatment of steel?
Heat treatment of steel is a process in which the metal is exposed to high temperatures and then cooled in a controlled manner. This process alters the physical and mechanical properties of the steel, such as its hardness, strength, and ductility.
2. What are the different types of heat treatment for steel?
There are three main types of heat treatment for steel: annealing, tempering, and hardening. Annealing involves heating the steel to a high temperature and then slowly cooling it to make it softer and more ductile. Tempering involves heating the steel to a lower temperature and then cooling it quickly to increase its toughness. Hardening involves heating the steel to a high temperature and then quenching it in a liquid, such as oil or water, to increase its hardness.
3. How does heat treatment affect the hardness of steel?
Heat treatment can significantly impact the hardness of steel. Annealing and tempering can decrease the hardness of steel, making it more malleable and easier to work with. Hardening, on the other hand, increases the hardness of steel, making it more resistant to wear and tear.
4. What factors influence the effectiveness of heat treatment on steel?
The effectiveness of heat treatment on steel depends on several factors, including the composition of the steel, the temperature at which it is heated, the cooling rate, and the duration of the treatment. Additionally, the type of heat treatment used and the quality of the equipment and materials can also impact the effectiveness of the process.
5. What are the benefits of heat treatment for steel?
Heat treatment offers several benefits for steel, including increased hardness, strength, and resistance to wear and corrosion. It also allows for the customization of the steel's properties to suit specific applications. Additionally, heat treatment can improve the overall quality and performance of the steel, making it more valuable and versatile for various industries.
  • Thermodynamics
  • Thermodynamics
