Differentiability and extreme points question
In summary, Micromass is trying to ask if a function that only continues in the interval [0,1] has a maximum, and the person is trying to show continuity for a specific function.
nhrock3
415
2.b)
f is continues in [0,1] and differentiable in (0,1)
f(0)=0 and for [tex]x\in(0,1)[/tex] |f'(x)|<=|f(x)| and 0<a<1
prove:
(i)the set {|f(x)| : 0<=x<=a} has maximum
(ii)for every x\in(0,a] this innequality holds [TEX]\frac{f(x)}{x}\leq max{|f(x)|:0<=x<=a}[/TEX]
(iii)f(x)=0 for [TEX]x\in[0,a][/TEX]
(iii)f(x)=0 for [TEX]x\in[0,1][/TEX]
in each of the following subquestion we can use the previosly proves subquestion.
So what did you try?? If you tell us what you tried, then we'll know where to help?
i don't want solution only starting guidence.
for 1 i know the a continues function has a maximum
If you want guidance, then you'll have to show us what you've tried. You won't get a solution here...
there is a difference between solution
and starting guidence
For 1, you indeed use that a continuous function has a maximum. What continuous function do they think they're using here??
i only know about the function what was given
What function do you need to show continuity of??
Yes, that is what we are given.
But we need to prove in (1) that
[tex]\{|f(x)|~\vert~x\in [0,a]\}[/tex]
has a maximum. To show this, we must use that every continuous function on a closed interval has a maximum.
So, what will we take as our continuous function?
we can't take a spesific function
its a proof for all function
a proof for a spesific is not sufficient
You don't understand what micromass is trying to imply. He's not suggesting taking a specific function like f(x) = sinx. He means you need to choose the correct function in your proof, which has to do with f(x) (hint hint), in order to prove that {|f(x)| | 0<= x <= a} has a maximum.
The answer is pretty clear - you just need to formulate a short proof.
Get it?
ahh now i get it
we need to formulate some other functionand using it we prove about
our abstract f(x)
maybe g(X)=|f(x)|
nhrock3 said:
ahh now i get it
our abstract f(x)
maybe g(X)=|f(x)|
Yes, so prove that |f(x)| is continuous if f is.
ionly know one way
and it showing that [tex]lim_{x->x0}f(x)=f(x0)[/tex]
but its not possible
because we don't have an actual function
Can you show |x| to be continuous??
Using that, you can show |f(x)| to be continuous as composition of f(x) and |x|.
nhrock3 said:
ionly know one way
You don't need to show that, it's a given.
Like said above me, asking if the set {|f(x)| | a<=x<=b} has a maximum is just like asking "does the function |f(x)| (notice the absolute value!) get a maximum in the segment [a,b]?". You know there would be an easy answer if you'd say "|f(x)| is continuous on this closed segment and therefore gets a maximum". Therefore, you need to show that |f(x)| is a continuous.
1. What is differentiability in mathematics?
Differentiability is a mathematical concept that describes the smoothness or continuity of a function. A differentiable function is one that has a well-defined derivative at every point in its domain.
2. How is differentiability related to extreme points?
Extreme points, also known as critical points, occur when the derivative of a function is equal to zero. These points are important because they can indicate the maximum or minimum values of a function. In order for a function to have an extreme point, it must first be differentiable at that point.
3. Can a function be differentiable at an extreme point?
In most cases, a function is not differentiable at an extreme point. This is because at an extreme point, the derivative is equal to 0, which means the function is not smooth or continuous at that point. However, there are some cases where a function may be differentiable at an extreme point, such as at a point of inflection.
4. How do you determine if a function is differentiable?
A function is differentiable if its derivative exists at every point in its domain. This means that the function must be continuous and have a well-defined slope at every point. The derivative can be found using various methods, including the limit definition, the power rule, or the chain rule.
5. What is the significance of differentiability in real-world applications?
Differentiability is an important concept in real-world applications, particularly in physics and engineering. It allows us to model and analyze the behavior of systems, such as the motion of objects, using mathematical functions. Differentiable functions also have practical applications in optimization problems, where we are trying to find the maximum or minimum values of a function.
