Single particle Interference – Photon Vs Electron Vs Buckyball
In summary, the mechanism behind single particle interference between photon, electron, and buckyball is the same. Each particle is described by a probability wave until it is measured, and this wave passes through both slits and is responsible for the interference pattern. However, the interpretation and mathematical models differ for each particle. For photons, the wave equation is described by Maxwell's equations, while for electrons and buckyballs, it is described by the Schrodinger equation or the Dirac equation. Realist interpretations like the de Broglie-Bohm theory try to explain the interference pattern by stating that the particle goes through one of the slits and is guided by a pilot wave. However, this is not widely accepted. As particles get larger
San K
911
Is the mechanism behind the single particle interference between photon, electron and buckyball different?
Reason for interference
Photon - interference caused by maxwell electromagnetic waves?
Electron - interference caused by Schroedinger probability waves?
Buckyball - interference caused by Schroedinger probability waves?
Pass through slits?
Photon - don't know (maybe through both slits?)..breaks and combines into one, perhaps
Electron - dunno...breaks and combines into one, perhaps
Buckyball - must be passing through one of the slits, else it might break?
The mechanism is the same, each of the particles is described by a probabilty wave until it is measured, the probability wave goes through both slits and is the reason for the interference pattern in all cases.
For a photon, the wave equation is described by Maxwell's equations, it is remarkable that this 19th Century model is still consistent with modern QFT model for the photon. For an electron/buckyball at slow speed a schrodinger wave eqn could accurately describe the probability wave if you could manage to solve for the boundary conditions at the slits and detection screen, for fast moving electrons maybe the Dirac eqn is needed. The easier method is a path integral calculation, Feynman shows this in his book on path integrals.
If you try to wonder about which slit the particles go through or what the particles are "doing" before they are detected you will just get confused, you have to accept the probabilistic ontology between emitter and detector, whether that probabilistic ontology is described by a field theory, wave eqn or path integral is up to you.
Some realist interpretations of QM like de broglie bohm try to say a particle does go through one of the slits and is guided by a pilot wave which cause the interference pattern to appear, but this is not so popular and maybe only useful as a heuristic model for understanding the resulting patterns.
As the particles get bigger (like buckyballs) it gets experimentally difficult to avoid decoherence effects preventing the probability wave from producing clean interference patterns at the detection screen.
I suppose that usually it is considered that the mechanism should be the same.
But photons and matter particles are rather different.
So I would rather say that no, physical mechanism is different. In case of matter particles Bohmian interpretation is closest description for that mechanism. But in case of photons it's ensemble interpretation (so it's not single photon interference).
But then it's just my viewpoint.
In Ballentine approach. He believes those destructive interference region are caused by scattering angle.. not because of intereference (he didn't believe in the wave part):
"... but anyone particle will not spread itself isotropically; rather it will be scatered in some particular direction. Clearly the wave function describes not a single scattered particle but an ensemble of similarly accelerated and scattered particles. At this point the reader may wonder whether a statistical particle theory can account for interference or diffraction phenomena. But there is no difficulty. As in any scattering experiment, quantum theory predicts the statistical frequencies of the various angles through which a particle may be scattered. For a crystal or diffraction grating there is only a discrete set of possible scattering angles because momentum fransfer to and from a periodic object is quantized by a multiple of delta p = h/d, where delta p is the component of momentum tranfer parallel to the direction of the periodic displacement d. This result, which is obvious from a solution of the problem in momentum representation, was first discovered by Duane (1923), although this early paper had been much neglected until its revival by Lande (1955, 1965). There is no need to assume that an electron spreads itself, wavelike, over a large region of space in order to explain diffraction scattering. Rather it is the crystal which is spread out, and the electron interacts with the crystal as a whole through the laws of quantum mechanics."
Can anyone pls. comment on this part which alleged explain the constructive and destructive interferences?
"For a crystal or diffraction grating there is only a discrete set of possible scattering angles because momentum fransfer to and from a periodic object is quantized by a multiple of delta p = h/d, where delta p is the component of momentum tranfer parallel to the direction of the periodic displacement d."
Is it true?
Is it true?
Better experiments have been done since, where electrons pass one at a time through a "biprism", not through a crystal, the electron has continuous range of "scattering" angles through the apparatus.
http://www.hitachi.com/rd/research/em/doubleslit.html
So this refutes Ballentine conjecture?
Yes, since to explain the Hitachi experiment you need to assume "the electron spreads itself wavelike through a large region of space"
The only difference is the energy - momentum relation for each particle. SInce the wavelength of the De Broglie wave determines the interference pattern (in the same experimental setup geometry), we have:
[tex]
\lambda_{dB} = \frac{h}{p}
[/tex]
If the particles are accelerated by gaining kinetic energy [itex]K[/itex], then:
[tex]
(K + m c^{2})^{2} = (p c)^{2} + (m c^{2})^{2}
[/tex]
[tex]
K^{2} + 2 m c^{2} \, K = (p c)^{2}
[/tex]
[tex]
p = m c \, \sqrt{\frac{K}{m c^{2}} \, (2 + \frac{K}{m c^{2}})}
[/tex]
Finally, we have the expression:
[tex]
\lambda_{dB} = \frac{\lambda_{C}}{\sqrt{\frac{K}{m c^{2}} \, (2 + \frac{K}{m c^{2}})}}, \ \lambda_{C} = \frac{h}{m c}
[/tex]
where [itex]\lambda_{C}[/itex] is the Compton wavelength of the particle.
This equation is inapplicable for massless particles. For them:
[tex]
E = K = p c
[/tex]
and:
[tex]
\lambda_{dB} = \frac{h c}{K}
[/tex]
This is the ultrarelativistic limit.
In the opposite limit when the kinetic energy is much smaller than the rest energy ([itex]m c^{2}[/itex]) of the particle, we have the approximate expression:
[tex]
\lambda_{dB} = \frac{\lambda_{C}}{\sqrt{2 \frac{K}{m c^{2}}}} = \frac{h}{\sqrt{2 m K}}
[/tex]
where the speed of light does not enter anymore. This is the non-relativistic limit.
We see that in the non-relativistic case, the de Broglie wavelength is inversly proportional to the square root of the kinetic enrgy and in the ultrarelativistic limit inversly proportional to the kinetic energy. If we plot [itex]y \equiv \lambda_{C}/\lambda_{dB}[/itex] vs. [itex]x \equiv K/(m c^{2})[/itex] on a log-log plot, we get the two asymptotic behaviors:
[tex]
[/tex]
[/tex]
Dickfore,
are you saying that the fringes in the interference pattern would different in their thickness, spacing (between fringes) etc?
San K said:
Dickfore,
If the de Broglie wavelengths turn out to be different, then yes.
1. What is single particle interference?
Single particle interference refers to the phenomenon in which a single particle, such as a photon, electron, or buckyball, behaves as both a particle and a wave, exhibiting interference patterns when passing through a barrier or slit.
2. How is the interference pattern of a photon different from that of an electron or buckyball?
The interference pattern of a photon is characterized by a series of bright and dark fringes, while the interference patterns of electrons and buckyballs are more complex and can vary depending on the experimental setup. Additionally, the wavelength of a photon is much shorter than that of an electron or buckyball, resulting in a more tightly spaced interference pattern.
3. What factors affect the interference patterns of single particles?
The interference pattern of a single particle can be affected by the wavelength of the particle, the distance between the barrier or slits, and the distance between the barrier or slits and the detecting screen. Additionally, the material and properties of the barrier or slits can also influence the interference pattern.
4. Can single particle interference be observed in everyday life?
Yes, single particle interference can be observed in everyday life in the form of diffraction patterns produced by light passing through small openings, such as the patterns seen in soap bubbles or CDs. Additionally, the double-slit experiment, which demonstrates single particle interference, has been replicated using electrons and buckyballs.
5. What is the significance of studying single particle interference?
Studying single particle interference has led to a deeper understanding of the wave-particle duality of matter and the fundamental principles of quantum mechanics. It has also had practical applications in fields such as nanotechnology, where the behavior of single particles is crucial in the design and development of new materials and technologies.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
