Accurate phase measurement with relativly low sampling frequency
by Phat
Tags: adc, dsp, micro controller
Phat
Phat is offline
#1
Feb19-13, 07:52 AM
P: 5
Hello.
To give some more information on what I am to use this for: I have two signals. Both are periodic sine waves with the same frequency, but with a constant phase difference. Let's call one of the signals for ref (reference) and the other sig (signal). They can look like this:
ref(t) = sin(2*pi*f*t)
sig(t) = sin(2*pi*f*t + θ)
where f = 300 000 Hz.
I sample the two signals simultaneously, multiply them and low pass filter in the micro controller. This way I get the in-phase component. To get the out-of-phase component I shift ref with θ = 90, multiply ref with sig and low pass filter to remove the high frequency component.
I understand how this works when having a sampling rate that is for example 360 times the signal frequency (in this case 360*300 000 = 108MSPS), which would give close to 1 accuracy over one period.
I am trying to understand how I can do accurate phase measurement of a signal with a sampling frequency that is for example only 5 times the signal frequency. I have been doing some reading and have found that this is to be possible by sampling more than one period of the periodic sine wave signal and do some averaging, but I am struggling finding a good explaination/examples on this.
So far I have figured out that to do this over several periods I have to satisfy the equation:
fs/fsig = N/M
where fs = sampling frequency, fsig = signal frequency, N = total number of samples, M = periods.
For my example fs could be 2.5MHz, N = 25 and M = 3. This will give a phase difference between each sample of:
Φ = 2*pi * (fsig/fs) = 2*pi * (M/N) = 43.2
So for 3 periods we have 25 samples with a constant phase difference of 43.2.
From this point I need some help what to do next. I want to know if someone can point me to a link, book, ebook or anything that explains this technique, tell me if this technique has a name (that would help my googling a lot) or can take some time explaining this in a short or long text.
Thanks!
Phys.Org News Partner Engineering news on Phys.org
A smart prosthetic knee with in-vivo diagnoses
Old tires become material for new and improved roads
Students take clot-buster for a spin
berkeman
berkeman is offline
#2
Feb19-13, 05:59 PM
Mentor
berkeman's Avatar
P: 39,683
Quote Quote by Phat View Post
Hello.
fs/fsig = N/M
Thanks!
This may not address your question, but there is a lot easier way to get the phase shift for your signals. Have you considered using 2 zero-crossing detectors (with crossing direction information) to accomplish this task?
jim hardy
jim hardy is offline
#3
Feb19-13, 09:57 PM
Sci Advisor
jim hardy's Avatar
P: 3,146
In my day computers were not fast enough to do what you propose at your frequency.
They might be now, i don't know.
In 1975 i did exactly what you describe but with analog, as Berkeman suggested.
My frequency was more modest - 1800 hz.
Here's a rundown from memory of what i did, should you decide to go analog.
We squared up the sinewaves with comparators - National LM710 was a fast comparator back then, 40 nsec. Newer & faster LM360 looks more suitable for your speed.
We then applied the two square waves to an AND gate, plain old 7400 TTL. That effectively multiplies them.
Output of AND gate we lowpassed with a sharp four pole filter to provide DC proportional to phase. 5V = inphase, 0V = 180 out.
Inverting one of the squarewaves would reverse the signal direction, ie give 0V = in phase, 5V = 180 out. We may have done that, i just dont recall.
Now, that leaves you not knowing which side of zero degrees phase difference you are on; are you in the 0 to +180 or the 0 to -180 half cycle?
So we applied both square waves also to a D flip-flop, one as clock and one as data.
Output of Flip-Flop tells you which sinewave is leading, ie what is sign of your phase difference..
Comparators are fast high gain devices prone to oscillate so board layout is real important.
I learned that the hard way.
At the speeds you intend to measure, i'd use newer parts for they're superior to what i had way back then. 1 at 300khz = only about 9 nanoseconds?
A google led me to linear's AN 13, which is 'words to the wise designer' for using fast comparators,
http://cds.linear.com/docs/en/applic...note/an13f.pdf
and to their LT1116 datasheet. It looks nice, being single supply.
http://cds.linear.com/docs/en/datasheet/1116fb.pdf
I'm obsolete as to slecting the best parts, but there's an analog approach.
Doubtless there's a DSP chip to do what you want.....
jim hardy
#4
Feb19-13, 10:04 PM
Sci Advisor
jim hardy's Avatar
P: 3,146
PS: A search on terms 'radar dsp phase' returned some links that looked promising to me.
http://jocoleman.info/pubs/papers/SkolnikCh25.pdf
Phat
Phat is offline
#5
Feb20-13, 07:41 AM
P: 5
Thank you for the answers and suggestions! I have considered a bunch of analog approaches and digital ones, but the one I mentioned above I want to know more about.
The comparators is ok, but the micro controller would not be fast enough detecting the lo/hi hi/lo transitions within reasonable time I think. (running at 72MHz, with max pin speed 50MHz I think) meaning I would get less than 2 degrees, probably a lot less accuracy.
I want to measure impedance/admittance and phase. If I were to choose an analog approach I would consider using the AD8333. This is a quadrature demodulator that (if I have understood this chip correctly) I can feed with my signal and reference signal and it will compute the in-phase (I) and out-of-phase (Q) component. The I and Q output will be currents so I would have to use a current-to-voltage converter and a low pass filter as I assume the output is not a constant current?
This way I have the real and imaginary part and can calculate the phase θ = arctan(I/Q).
What I don't know about this chip is if I can feed it with a reference signal that has a higher amplitude than the signal. This will also be the case since my signal will go through and unknown impedance and be attenuated. I can't seem to find any information about the amplitudes. Do they have to be equal?
Here is a link to the chip on Analog Devices webpage:
AD8333 Quadrature Demodulator
the_emi_guy
the_emi_guy is offline
#6
Feb20-13, 07:58 AM
P: 580
Phat,
Regarding your original post, synchronous sampling is not helping you. It is better to have your sampling clock asychronous to your sampled sine wave. You can then define your accuracy using your low pass filter. For example, if you are willing to allow a couple seconds of settling time, you can have a low pass filter of 0.1Hz and have excellent phase accuracy.
This is taking advantage of the fact that the sampled signal is repetitive and averaging over many cycles to obtain your accuracy. (Also assumes there is no jitter).
Regarding the 8333, its LO input is (or can be) a digital signal. Its amplitude does not effect measurement.
Phat
Phat is offline
#7
Feb20-13, 08:34 AM
P: 5
the_emi_guy: Thanks for the help on the AD8333 amplitude question.
I was thinking maximum 100-300ms, but I think I can accept the trade-off with phase accuracy.
What you are explaining with the averaging is similar to what I would do with the AD8333. Here I would just low pass filter the alternating voltage at each output (I and Q) and sample this value for a time (100ms) and calculate the average.
I think I might do this with the AD8333 as I can get the resistance/conductance and reactance/suspectance and easily calculate the phase as well.
I was thinking of using a DDS as the sine wave signal generator. Splitting this signal to a reference signal and an excitation signal. The reference signal will go directly to the LO input while the excitation signal will go through a "black box" with an unknown impedance (RC, no L), and then to the RF input. The signal out from the "black box" will probably be attenuated and phase shifted. I am interested in getting the phase shift phi = arctan(Q/I) and amplitude A = sqrt(I^2 + Q^2). This way I can know what to expect in the "black box" (or some equivalent circuit).
Register to reply
Related Discussions
HUB & accurate single measurement Quantum Physics 6
Methods of Accurate Dynamic Mass Measurement? Mechanical Engineering 0
How to obtain the sampling frequency of frequency data General Engineering 1
Accurate Height(above sea level) Measurement Device Mechanical Engineering 9
Accurate Measurement Classical Physics 14
