The homogeneous strength of the Higgs field
by Mandragonia
Tags: field, higgs, higgs field, homogeneous, strength
Bill_K
Bill_K is offline
#37
Nov9-13, 06:09 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 3,853
Quote Quote by Mandragonia View Post
In quantum physics radioactive decay points to internal processes in the nucleus that occur spontaneously due to vacuum fluctuations. The strength and frequency of the fluctuations determine the transition probability of the nucleus and the decay time.
No. This is a misunderstanding common among newcomers to QM, and unfortunately it gets perpetuated in popular accounts. They attribute things to "fluctuations" where the blame should fall to "steady superpositions". Telling this fib makes things sound more classical than they really are, and therefore easier for QM novices to understand.
"The electron zips around in an orbit." - No, it's position has a steady state probability distribution.
"The electron spends part of the time within the nucleus." - No, it has a certain constant probability of being found there.
"Alpha decay happens because the alpha particle repeatedly bounces against the Coulomb barrier, and eventually penetrates it." - Again no, its wavefunction has a certain constant amplitude at the barrier.
These are all examples of an important difference between Classical and Quantum Mechanics.
Mandragonia
Mandragonia is offline
#38
Nov10-13, 01:02 AM
P: 57
You make it sound as if the only purpose of QM is to solve the time-independent Schroedinger equation (in my opinion this is not quite true). But even if you focus on the resulting steady-state probability functions, you will see that they often contain time-like parameters, for example an angular frequency or a velocity. So the static solution already hints at underlying dynamics.
Of course that is true. But it is also true that the orbiting electron has a well-defined non-zero kinetic energy and velocity. Therefore it (or something) is moving! This is one of the amusing paradoxes of QM. In fact, if the electron where non-moving, one would run into serious problems. For example, for the outer orbits (higher quantum numbers) of the atom there would be no comparison possible between the quantum orbits and their classical counterparts, where the electron moves around the nucleus in a planet-like elliptical orbit.
mfb
mfb is offline
#39
Nov10-13, 05:52 AM
Mentor
P: 10,798
The expectation value for the velocity is zero in all time-independent orbits.
I disagree.
Every classical part can be written as superposition of orbitals - and in those superpositions the electron can be moving, as the wavefunction is not static any more.
Mandragonia
#40
Nov10-13, 07:44 AM
P: 57
Quote Quote by mfb View Post
Velocity regarded as a vector quantity has zero expectation value, due to the symmetry of the system.
However its absolute value (normally referred to as SPEED) is certainly non-zero.
mfb
mfb is offline
#41
Nov10-13, 07:46 AM
Mentor
P: 10,798
That's why I said "velocity" and not "speed".
Mandragonia
#42
Nov10-13, 12:07 PM
P: 57
Why does the electron have a non-zero speed? Because in the sub-atomical realm things move! This has been recognized by countless leading physicists. It is also the insight that led Mr. Schroedinger to formulate his famous result: the time-dependent Schroedinger equation. Its key-aspect is that it is a DYNAMICAL equation. It describes the evolution (in space and time) of the wave function of a particle, in relation to its initial state (t=0). Necessarily the equation contains parameters that are associated with time, such as Planck' s constant and the inertial mass of the particle.
Technically it is very useful to consider first the solutions to the time-independent Schroedinger equation. This is a convenient simplification. This way one obtains the energy eigenfunctions. They form (mathematically speaking) a basis, and so they can be superimposed to create time-dependent functions. But my point is, that the solutions of the time-independent Schroedinger equation contain exactly the same parameters as the time-dependent version. So no wonder that inspection of the steady-state solutions reveals certain dynamical properties of the particle, such as its average speed in orbit. In my view this property is no less "physically real" than the probability density.
mfb
mfb is offline
#43
Nov10-13, 02:55 PM
Mentor
P: 10,798
No one ever questioned that particles can move in quantum mechanics in general. The main point was that they do not move around in time-independent states, which are solutions to the time-independent SE.
Mandragonia
#44
Nov10-13, 04:58 PM
P: 57
No one disputes the existence of time-independent states, which are solutions of the time-independent SE.
The discussion is how the electron can have a non-zero speed while being in a time-independent state.
mfb
mfb is offline
#45
Nov10-13, 05:11 PM
Mentor
P: 10,798
A non-zero expectation value for the speed.
It does not have a well-defined, single "speed value".
I don't see the problem.
Bill_K
Bill_K is offline
#46
Nov10-13, 06:09 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 3,853
This discussion has long ago departed from the OP, which was about the Higgs field. For answers to these questions you should start a new thread. Furthermore, the questions you are now asking are basic QM and should be asked in the QM forum.
Mandragonia
#47
Nov10-13, 06:42 PM
P: 57
Wikipedia statement: "The mean speed of the electron in hydrogen is 1/137th of the speed of light."
Therefore the electron is moving. Yet its probability distribution is time-independent.
I don't have a problem reconciling these two (seemingly contradictory) facts. For me it obvious that the electron is moving. Due to the impossibility to have information on the position of the electron, the best one can do is to assume that it is simultaneously present at the different positions allowed in the orbital. Of course with proper weighting. This leads to the time-independent solution, in which the effects of motion becomes hidden.
mfb
mfb is offline
#48
Nov11-13, 12:47 PM
Mentor
P: 10,798
Wikipedia as source? That does not work.
Anyway, Bill_K is right. Please start a new thread if you want to discuss interpretations of the wave-function as "moving" or "not moving".
Mandragonia
#49
Nov28-13, 10:42 AM
P: 57
Yet there is no guarantee that if you start a new thread in the QM forum on this subject, you will get any meaningful answers.
The purpose of Physics Forums is to promote interesting and helpful discussions, but in reality these are scarce and occur only within the inner circle of experts.
Register to reply
Related Discussions
What does it mean, The Higgs boson is an excitation of the higgs field High Energy, Nuclear, Particle Physics 11
Questions about the behavior of the Higgs particle and Higgs field High Energy, Nuclear, Particle Physics 7
Parallel Plate Capacitor: Electric field strength, flux & magnetic field Introductory Physics Homework 0
Gravity as a Goldstone-Higgs field, instead of a Gauge Field General Physics 0
the Higgs field: so gravitational field by itself cannot confer mass? High Energy, Nuclear, Particle Physics 4
