What is the Mass of a Thunderhead?
by EskWIRED
Tags: mass, thunderhead
EskWIRED
EskWIRED is offline
#1
Jan24-14, 05:19 PM
P: 97
ISTM that large clouds hold a lot of water, and that water is fairly heavy.
Which got me to wondering just how "heavy" all the water in a large thunderhead would be? I'm assuming that many, many tons of water are floating around up there, but how many?
Phys.Org News Partner Earth sciences news on Phys.org
Bobbywhy
Bobbywhy is offline
#2
Jan24-14, 05:28 PM
PF Gold
P: 1,852
What does "ISTM" stand for?
Do you have any idea or sources that you've already checked?
Every thunderstorm is different, so I would say no one can say the amount of water, in tons, that a thunderhead contains.
If you stand on your paved street during a thunderstorm, gather up all the rainwater running off in buckets, and then weigh it, what could you infer? Would those measurements tell anything about the total amount that the thunderhead contained?
Bandersnatch
Bandersnatch is offline
#3
Jan24-14, 05:29 PM
P: 551
There's a "what if" touching on this subject:
http://what-if.xkcd.com/12/
klimatos
klimatos is offline
#4
Jan24-14, 10:51 PM
P: 403
Quote Quote by EskWIRED View Post
Rogers and Yau, "A Short Course in Cloud Physics" on page 235 give the mean precipitation content of an isolated thunderhead as on the order of 109 kilograms. They also point out that the actual output during the life of a thunderhead can be more than five times that amount due to the fact that a thunderhead is a process, and not just an object.
Does this answer your question?
Enigman
Enigman is offline
#5
Jan25-14, 03:20 AM
Best Humor
Enigman's Avatar
P: 545
Quote Quote by Bobbywhy View Post
It seems to me that ISTM stands for It Seems To Me.
Bobbywhy
Bobbywhy is offline
#6
Jan25-14, 05:00 AM
PF Gold
P: 1,852
Quote Quote by Enigman View Post
Enigman, thank you for your translation. Since I am an "OF" (Old Fart) I needed your help.
EskWIRED
EskWIRED is offline
#7
Jan25-14, 08:35 AM
P: 97
Klimatos that is exactly what I
was wondering. Thanks. I find it amazing that so much mass can just float on air.
Evo
Evo is offline
#8
Jan25-14, 01:02 PM
Mentor
Evo's Avatar
P: 25,928
This is why TSINA (text speak is not allowed) at PF, EskWIRED, please type out text speak.
AlephZero
AlephZero is offline
#9
Jan25-14, 04:31 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,344
The density of water vapor is much less than the density of air, at the same pressure. Molecular weight of water = 18, compared with 28 for nitrogen, and 32 for oxygen.
If water vapor was not light enough to "float on air", thunderheads would never form.
klimatos
klimatos is offline
#10
Jan25-14, 05:16 PM
P: 403
Quote Quote by AlephZero View Post
Water vapor is certainly lighter than dry air. However, the source that I was quoting was referring to the liquid condensate (cloud droplets) content of the thunderhead, not the water vapor content. These droplets are kept aloft by the force of the rising air balancing the downward gravitational force.
This is easier to picture if you think of the thunderhead (and all clouds) as the visible tops of invisible masses of rising air.
Register to reply
Related Discussions
Mass-spring-mass system rotating about its centre of mass relativistically Advanced Physics Homework 0
Doubts regarding Atomic mass,relative atomic mass and mass number. Chemistry 1
Chemistry - isotpic mass, atomic mass, mass number Biology, Chemistry & Other Homework 1
reduced mass for an infinite mass and a finite mass? Introductory Physics Homework 1
Help with problem of Center of mass, linear mass density and total mass Introductory Physics Homework 1
