Is the higgs boson the mediator of the higgs field?
by phy_infinite
Tags: boson, field, higgs, mediator
Bill_K
Bill_K is offline
#19
Dec22-13, 04:26 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 3,853
Quote Quote by phy_infinite View Post
I guess the question really is, does the higgs boson do anything? I mean, does it do anything to other particles?
The Higgs field is a permanent feature of the vacuum, and can therefore have a permanent effect on particles. By comparison the Higgs boson is very short-lived, predicted to live about 10-22 secs, and therefore any effect it has must be brief. Like other particles it collides with other particles, decays into other particles, etc. All we can measure are its decay probabilities and decay rates.
But these reflect the properties of the Higgs field. For example the fact that the mass of a fermion is determined by how strongly it interacts with the Higgs field will be reflected in a property of the Higgs boson, namely the boson must interact more strongly with the heavier fermions, proportionally to their mass.
phy_infinite
phy_infinite is offline
#20
Dec22-13, 04:38 PM
PF Gold
phy_infinite's Avatar
P: 75
Quote Quote by Bill_K View Post
That's what I would have expected. When it comes to the higgs mechanism then, we don't need to consider the action of the higgs boson. It seems that popular press as created a confusion in portraying the higgs as an actor in the process. With that behind me, what particle exchange does occur that allows some particle to interact with the higgs field?
phy_infinite
#21
Dec22-13, 05:00 PM
PF Gold
P: 75
Would it actually be the "ziggs boson" that susskind was referring to?
Bill_K
Bill_K is offline
#22
Dec22-13, 06:28 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 3,853
None, there is no particle exchange involved. As we said earlier (post #7), the idea that particle exchange "mediates" an interaction does not apply to the interaction between a particle and a field. The particle simply interacts with the field, without any help! We listed in #7 the cases in which mediators are involved.
The mass term for a fermion is simply proportional to the value v of the Higgs field, the constant of proportionality being different for each type of fermion.
phy_infinite
#23
Dec22-13, 06:47 PM
PF Gold
P: 75
Oh that's right! A particle interacts with the higgs field and that's it since the higgs field is not a force. The higgs boson is merely excitations in the higgs field, so it's just a side effect. I think this is starting to clear up for me now!
ChrisVer
ChrisVer is offline
#24
Dec22-13, 08:50 PM
P: 368
you should look at the mathematical derivation of the higgs mechanism an interpret it...there you see everything happening and you can know what's going on and where.
phy_infinite
#25
Dec22-13, 09:01 PM
PF Gold
P: 75
Quote Quote by ChrisVer View Post
I agree, that would be the best way to understand it. I would appreciate any recommendations for any textbooks on particle physics if anyone knows of any. Thanks!
ChrisVer
ChrisVer is offline
#26
Dec23-13, 11:18 AM
P: 368
Any book that deals with Standard Model in advanced (graduate) level, will surely have what you ask. This paper
http://arxiv.org/pdf/1312.5672v1.pdf
also was the last one I read recently, and I find it nice.
But to be honest, I have never found a textbook that does the whole calculations, the most you need to do by your own...
Bill_K
Bill_K is offline
#27
Dec23-13, 11:51 AM
Sci Advisor
Thanks
Bill_K's Avatar
P: 3,853
This paper http://arxiv.org/pdf/1312.5672v1.pdf also was the last one I read recently, and I find it nice.
Thanks, that's an excellent review.
phy_infinite
#28
Dec23-13, 11:56 AM
PF Gold
P: 75
Thanks for that! I'll check it out.
StandardsGuy
StandardsGuy is offline
#29
Mar25-14, 11:10 AM
P: 61
I feel like you are too!
Almost every word you've quoted from this article is sheer baloney.
Then what is the truth (in your opinion)?
Simon Bridge
Simon Bridge is online now
#30
Mar25-14, 08:41 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 10,953
Quote Quote by StandardsGuy
Quote Quote by Bil_K
Knowing falsehood does not imply knowing the truth.
(... and physical reality is not usually a matter of opinion.)
However - we can talk about how an article misrepresents a physical model from knowledge of that model.
I'll have a go - Bill K will, probably, fill in the bits I miss. I suspect the objections go something like this:
The quote in question is from "Livescience" - a pop-science news-site not known for being scientifically accurate. To be fair on the authors, they are trying to get some subtle points of field theory across to a target audience that struggles with high-school maths. This is not easy, we can't really expect them to get everything just right.
I'll break the quote up into individual points:
"In physics, when particles interact with fields, the interaction must be mediated by a particle.
... or, indeed, when they interact with each other, or, at all.
The statement is stronger than I'd make it but it is probably fair.
Interactions with the electromagnetic (EM) field, for example, are mediated by photons, or particles of light.
It is the interaction that is "mediated" by the virtual particle, not the field.
When a negatively charged electron is pulled by the EM field toward a positively charged proton, the electron experiences the EM field by absorbing and emitting a constant stream of "virtual photons",
The picture you get here is that electrons are firing and getting hit by a constant stream of photons - this is not correct.
Compare with:
http://math.ucr.edu/home/baez/physic...particles.html
... which gives you a better idea how virtual particles mediate forces.
photons that momentarily pop in and out of existence just for the purpose of mediating the particle-field interaction.
That's quite iffy - how do these virtual photons know to "pop" into existence at just the right moment to mediate the field? (Covered in previous link.)
Furthermore, when the EM field is "excited," meaning its energy is flared up in a certain spot, that flare-up is, itself, a photon, a real one in that case.
This is so confused it is hard to know where to start: see the following -
http://profmattstrassler.com/article...what-are-they/
... and all this is before you get close to thinking about Higgs.
But like I said before, the authors are trying to explain in a single chatty sentence something that actually requires many paragraphs - and, even then, it's incomplete. Of course they got it wrong!
They got it cringe-worthily wrong.
How could they not?
StandardsGuy
#31
Mar26-14, 10:45 AM
P: 61
Thanks. I agree that we can't expect the authors to get everything exactly right. Somebody had to tell them those things. Oversimplification is highly probable, but I think they did an amazingly good job. In your first link, the authors admitted that they used gross oversimplification. In the second one they said ``virtual particle'' is a problematic term. I found the first one a little ad-hoc. They seemed to have a "two-worlds" theory with a "position-space universe" and a "momentum-space universe." Still, I appreciate the links. I was, however, more interested in the Higgs mechanism.
Simon Bridge
#32
Mar26-14, 09:27 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 10,953
Quote Quote by StandardsGuy View Post
As a basis for learning more about the standard model and the Higgs mechanism (the context in which is was quoted) - not really. As something to give a lay reader a sense of exciting things happening - better. The second is what it was written for, after all.
Both links are oversimplified - I can give you a link to the actual, unsimplified, stuff if you like: how's your maths?
Note: If those are "gross simplifications" - where does that leave the quoted passage, that was the context, which is even more oversimplified still?
... and they explained why it is problematic and addressed the problem in a way that illustrated why the associated part of the LiveScience article was "baloney"... in an accessible way.
The position and momentum spaces are fourier transforms of each other - they describe the same World.
Well, when you asked the question, you wrote that you were interested in the truth by the opinion of Bill_K. I hoped that I'd interpreted your intention correctly... you asked about a passage Bill_K had criticized which was quoted from a LiveScience article linked to earlier.
The quoted passage made no reference to the Higgs mechanism.
phy-infinite quoted it.
You asked about it.
You got an answer.
Please understand: In order to get a good idea about the Higgs mechanism, the interested student really needs a better picture of the standard model than the LiveScience article gives you.
Perhaps something like:
Bernstein J. Spontaneous symmetry breaking, gauge theories, the Higgs mechanism and all that (1974) Rev Mod Phys.
Maybe:
Organtini G. Unveiling the Higgs mechanism to students Eur. J. Phys. 33 (2012) 1397-1406
There are no end of lecture summaries:
i.e. http://www.physics.buffalo.edu/pasi/...onLecture1.pdf
Basically you'll need to pick one that is suitable to your education.
Enjoy.
Register to reply
Related Discussions
What does it mean, The Higgs boson is an excitation of the higgs field High Energy, Nuclear, Particle Physics 11
How exactly does the Higgs field and boson interact with particles? High Energy, Nuclear, Particle Physics 6
Questions about the behavior of the Higgs particle and Higgs field High Energy, Nuclear, Particle Physics 7
Help in clearing up Higgs boson/field High Energy, Nuclear, Particle Physics 1
Could it be that Higgs's boson does not exist, but Higgs mechanism does? Beyond the Standard Model 14
