Is the Orbit of a Satellite Affected by Changes in Speed?
  • Thread starter Abhishekdas
  • Tags
    Gravitation
In summary, the speed of a satellite in a circular orbit is (GM/R)^1/2 whereM= mass of Earth and R= radius of earth. and escape velocity is root(2) times the above expression so that sorts out the second part...about 2 v0 but what about the first part...I don't get how and when a satellite moves elliptically...
Abhishekdas
208
Question on gravitation...
A satellite is revolving around a planet in a circular orbit. Its speed is increased from v0 to : (a) (1.5)1/2 v0
(b)2v0
now in the book they have given that in case (a) the orbit becomes illiptical and in case (b) the satellite will escape.
The value of v0 isn't given and nothing else is mentioned so how can one arrive to the above conclusions just like that..Is it just an error in the book? or sumthing else?
Determine a formula for the speed of a satellite in a circular orbit at some arbitrary radius. Next determine a formula for the escape speed of a satellite at the same radius. Compare. Conclude.
Hi gneill...
The speed of a satellite in a circular orbit is (GM/R)^1/2 whereM= mass of Earth and R= radius of earth. and escape velocity is root(2) times the above expression so that sorts out the second part...about 2 v0 but what about the first part...I don't get how and when a satellite moves elliptically...
Thank you for the reply ...
All you need to know is that the velocity has to be between that for circular motion and that for escape for the satellite to remain in a bound orbit (circular or elliptical). If Vo is the circular velocity, then escape velocity is √2 x Vo. Your job is to figure out where the given velocities lie...
Ya it is given in the book (without any explanation) that the velocity if lying between the escape velocity and velocity for circular motion is an ellipse...But why is it so? and is there any method to find the focus major/minor axes or anything of the ellipse?
Circles and ellipses are closed orbits; they repeat. Anything that escapes is an open orbit, and does not repeat; they pass by once and are gone for good. So if you want an elliptical orbit, it had best have a velocity that is less than escape velocity!
There are quite a few relationships between the various parameters of a given orbit, including the axes lengths, period, eccentricity, perihelion and aphelion distances, total mechanical energy, etc.
The basic equation is that of an ellipse. In polar form, where the origin is at the focus,
r = p/(1 + e*cos(ν))
where p is the semi-latus rectum, e is the eccentricity of the orbit, and ν is the angle from perihelion. p is related to the semimajor axis and the eccentricity by
p = a(1 - e2)
The perihelion distance is rp = p/(1 + e) = a(1 - e)
The aphelion distance is ra = p/(1 - e) = a(1 + e)
The total mechanical energy of an orbit is [tex]\xi[/tex] = v2/2 - μ/r
Orbit shape is determined by eccentricity or total mechanical energy
e < 1 --> [tex]\xi[/tex] < 0 --> bound orbit (elliptical or circular)
e = 1 --> [tex]\xi[/tex] = 0 --> unbound (parabolic); escape speed
e > 1 --> [tex]\xi[/tex] > 0 --> unbound (hyperbolic)
Beware, there are also degenerate orbits where the path is straight towards or away from the Sun (straight line). They may have any energy.
Hey...thanks...i think all these are new for me...
1. What is gravitation?
Gravitation is a natural phenomenon by which all physical bodies with mass are attracted to each other. It is a fundamental force of nature that explains the motion of objects on a large scale, such as planets orbiting the sun.
2. Who discovered the concept of gravitation?
The concept of gravitation was first described by Sir Isaac Newton in his famous law of universal gravitation in 1687. However, the idea of gravity has been studied and observed by many scientists throughout history, including Galileo and Kepler.
3. What causes gravitation?
Gravitation is caused by the presence of mass in objects. The larger the mass of an object, the stronger its gravitational pull. For example, the Earth's mass is what causes us to be pulled towards its center, creating the force we feel as gravity.
4. How does distance affect gravitation?
According to Newton's law of universal gravitation, the force of gravity between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them. This means that the farther apart two objects are, the weaker their gravitational attraction will be.
5. How is gravitation related to Einstein's theory of relativity?
Einstein's theory of relativity expanded upon Newton's law of gravitation by explaining that gravity is not just a force between masses, but rather a curvature of space and time caused by the presence of mass. This theory has been proven through various experiments and observations, and is now considered the most accurate description of gravitation.
