From a fraction with infinite sum in denominator to partial fractions?
In summary, the conversation is discussing a course on Perturbation Methods and the use of Taylor expansion and substitution to simplify an integral with a fraction in the denominator. The resulting fraction is then further simplified using a variation of the formula 1/(1-x) = 1 + x + x^2 + ... and factoring out 1/{ε^2(1+u^2)}. The conversation also includes a correction to the second term numerator.
megzaz
From a fraction with infinite sum in denominator to partial fractions??
I am currently studying a course on Perturbation Methods and in particular an example considering the following integral [tex] \int_{0}^{\frac{\pi}{4}} \frac{d\theta}{\epsilon^2 + \sin^2 \theta}. [/tex]
There's a section of the working where, having used the Taylor expansion of sin near 0 and using sin θ ≈ θ together with substitution θ=εu, we get the following fraction for the integrand
[tex] \frac{1}{\epsilon^2 + \epsilon^2 u^2 - \frac13 \epsilon^4 u^4 + \cdots}.[/tex]
This then in both my lecture notes and a book I'm following becomes
[tex] \frac{1}{\epsilon^2}\left( \frac{1}{1+u^2} + \frac{\epsilon u^4}{3(1+u^2)^2} + \cdots \right). [/tex]
Can anyone see how these are equal?
Mathematics news on Phys.org
It looks like using a variation on 1/(1-x) = 1 + x + x2 + ... after factoring out 1/{ε2(1+u2)}.
Also second term numerator should be (εu)4
What is a fraction with infinite sum in the denominator?
A fraction with infinite sum in the denominator is a mathematical expression where the denominator consists of an infinite series. This can also be referred to as an infinite fraction or a continued fraction.
How do you convert a fraction with infinite sum in the denominator to partial fractions?
To convert a fraction with infinite sum in the denominator to partial fractions, you can use the method of partial fraction decomposition. This involves breaking down the fraction into simpler fractions with distinct denominators.
Why would you want to convert a fraction with infinite sum in the denominator to partial fractions?
Converting a fraction with infinite sum in the denominator to partial fractions can make the expression easier to work with and can help in solving certain mathematical problems. It can also provide a more accurate representation of the original fraction.
Are there any special cases to consider when converting a fraction with infinite sum in the denominator to partial fractions?
Yes, there are special cases to consider when converting a fraction with infinite sum in the denominator to partial fractions. For example, if the infinite fraction is a repeating decimal, a different method may need to be used to convert it to partial fractions.
What are the applications of fractions with infinite sum in the denominator and partial fractions in science?
Fractions with infinite sum in the denominator and partial fractions have many applications in science, particularly in fields such as physics and engineering. They can be used to solve complex equations, model physical systems, and analyze data. They are also commonly used in signal processing and control systems.
  • General Math
  • General Math
