Register to reply
World's hardest easy problem
by namanjain
Tags: hardest, world
Share this thread:
namanjain
#1
Sep3-13, 05:38 AM
P: 69
check out this question on the webpage
http://thinkzone.wlonk.com/MathFun/Triangle.htm and please give me it's solution
[THANKS FOR EVEN TRYING]
Phys.Org News Partner Mathematics news on Phys.org
Math journal puts Rauzy fractcal image on the cover
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
janhaa
#2
Sep3-13, 06:57 AM
P: 97
I haven't the solution, I get the equation x + y = 130, where x and y are angles. If [itex] x, y \in Z^+[/itex]
This is a diophantine equation. We know: x, y > 0. y > x. And y is greater than 90 degrees.
the most probable angles:
[itex] x=20^o\,\, ,y=110^o[/itex]
or
[itex] x=30^o\,\, ,y=100^o[/itex]
reenmachine
#3
Sep3-13, 02:34 PM
PF Gold
reenmachine's Avatar
P: 521
I tried a couple of things but didn't solve it yet , but there's probably a way to build your way up to the x angle using the tricks in my sketch (just don't have the patience to construct the triangles properly and doing it now):
Integral
#4
Sep3-13, 04:08 PM
Emeritus
Sci Advisor
PF Gold
Integral's Avatar
P: 7,336
Simple geometry is all that is required.
Why can't you do this for yourself? Don't give up so easy.
namanjain
#5
Sep4-13, 03:25 AM
P: 69
Quote Quote by janhaa View Post
wazz it,
i tried it hard thats why asking askin solution,
well i need an approach
i asked it to one of my faculty at coaching and he straightaway said it's wrong so i needed to check
namanjain
#6
Sep4-13, 03:32 AM
P: 69
or
Quote Quote by reenmachine View Post
whatss y in equation
x+y= 130
reenmachine i agree myself i even not have patience and doing it (doing angle sum property question) , thanks for tip of parallel lines but what benefit it does
reenmachine
#7
Sep4-13, 03:56 AM
PF Gold
P: 521
Quote Quote by namanjain View Post
I don't know since I didn't solve it.It was just a suggestion of strategy to attack the problem , maybe it's a dead end , but the parallel lines will at least allow you to chase more angles , whether or not they end up being useful to find angle x.
If you don't have the patience to try it , I suggest you do not ask others to do it for you as it's not recommended on the forum to ask for answers without showing that you tried hard before hand.I'm not a moderator , just friendly advice.Also , saying that you tried hard is not showing that you tried hard.
namanjain
#8
Sep4-13, 04:10 AM
P: 69
till here i ve done (in attchment)
one of image is inverted
so i did the mirror image from webcam toy
reenmachine
#9
Sep4-13, 04:13 AM
PF Gold
P: 521
You should draw the triangles/angles to scale if you want to try that strategy.
It should look like the picture below
namanjain
#10
Sep4-13, 09:08 AM
P: 69
Quote Quote by kingo1979 View Post
from the original figure below, y seems equal angle bde
http://thinkzone.wlonk.com/mathfun/triangle.htm
where x + y + 50 = 180
however i got that but i also meant that diophtine (whatever is name) equation
well where is it taught
namanjain
#11
Sep4-13, 09:12 AM
P: 69
you should draw the triangles/angles to scale if you want to try that strategy.
does that help, because doing any of olympiads we were never told to draw to scale and i was always of kind to do geometry of this kind mentally so it's quite difficult for me
though i think i'll print that page
namanjain
#12
Sep4-13, 09:18 AM
P: 69
Uff! After long work with a correct precise figure i bored and saw solution on one of other web pages
is it bad of me not getting it (i'm 15 yrs and preparing rmo and iit)
reenmachine
#13
Sep4-13, 10:58 AM
PF Gold
P: 521
I don't know , you should listen to your teachers before you listen to me that's for sure
You should also listen to mentors here as they are qualified to help you.
reenmachine
#14
Sep4-13, 01:04 PM
PF Gold
P: 521
Might try to prove both of these triangles (or another pair of triangles) are similar to prove x = 20 :
Register to reply
Related Discussions
Hardest logic problem! Calculus & Beyond Homework 0
What is the hardest problem you can think of? Classical Physics 0
Projectiles Problem - hardest physics problem I have ever faced Introductory Physics Homework 8
Hardest Math Problem Ever? Fun, Photos & Games 1
Hardest logic problem ever Fun, Photos & Games 14
