Why is exit wound in a rifle gun shot injury bigger than entry wound?
  • Thread starter sameeralord
  • Tags
    Gun Wound
In summary, the larger wound is caused by the bullet exiting the body. This is due to the bullet's spin being disrupted and the increased kinetic energy.
sameeralord
662
Hi,
Generally if u see a post mortem skull after a rifle shot injury, exit wound is bigger than entry wound. Shouldn't the bullet lose lots of its energy when coming out, hence smaller wound. Maybe it is spinning or something, but I want to get others views. Thanks :smile:
Well I'm no expert on ballistics but I think it's actually the other way round , when a bullet or any sharp edged small projectile come in with a high speed it places huge stresses on a very small point on the surface of the target (human body for example) that's why because flesh is usually not the strongest material around it makes a very small hole because penetration at those speeds is easy for the bullet , when coming out the bullet has lost some of it's kinetic energy (speaking about rifle ammo not some pistol one) with lower speeds the stress that the bullet now exerts is smaller on the same surface area.
It's like puncturing a paper with a sharp pen or something the faster you do it the more chance of making a precise point hole the slower you do it the more the chance of ripping the whole paper sheet apart.Also even though at those speeds it is not common but the bullet can turn and change it's trajectory while between the two sides of the skull after the first initial impact, also it can change it's shape after the impact and the next impact would be with a slower bullet that has a more dull edge rather than a sharp one as before the first impact.
In other words it has to do with mass/size or shape rather and speed.
Here is an article discussing the basics:
http://en.wikipedia.org/wiki/Ballistic_trauma
The damage caused by a rifle bullet will depend on the weight, caliber, and striking velocity. There will be added damage depending on whether the bullet fragments or mushrooms on impact. Dum-Dum bullets have been banned because they are explicitly designed to mushroom on impact and increase internal injury. Bullets can also tumble inside the would, creating a larger amount of injury than if they passed straight through the body. Small, low velocity bullets may not even have enough energy to pass through the body, especially if they strike bone and ricochet inside the body.
If a bullet passes through the cranium, the high velocity passage of the bullet will set up a shock wave inside the skull. If the bullet has enough energy on exit, the skull itself may be shattered around the exit.
Yes, rifle bullets are spin-stabilized, but after striking something hard like bone, their path becomes unpredictable.
As SteamKing said...
Plus... you can never discount secondary projectiles. A lot of the damage of a gunshot wound, including the exit hole, is due to pieces of bone that are broken off and carried along with the bullet. (A perfectly effective bullet, by the bye, doesn't exit the body.)
I use only non-chemical explosive bullets myself.
I believe the answer is that the bullet creates a shock wave and that shockwave travels outwards much like the waves caused when you throw a stone into a pond.
In this video the bullet comes out more or less in one piece but deformed. The hole continues to expand after the bullet has passed through..
http://splodetv.com/video/hollowpoint-vs.-ballistic-gel-0
Compare with shock wave shape...
http://goo.gl/WGdfF
I reckon that's got to be one good reason for a large exit hole. There could be a lot more 'stuff' going out than going in. I always wonder about the 'shock wave' explanation and what it really means, bearing in mind that a shock wave is defined as what is generated when an object travels through a medium faster than sound in that medium. Are there many bullets that travel through air at Mach 4?
i suspect the bullet has lost its spin and tumbles outthis is why the beginning of Saving Private Ryan was wrong in the Normandy landings it showed soldiers being shot by bullets penetrating the water
nonsense a bullet loses its spin and therefore its stability immediately upon entering water and will start to tumble
I seem to remember reading a James Bond book in which they shoot bullets into a tub of water to match the rifling marks in the ballistics lab. They dissipate in not much depth. (I would still poo my pants if I saw bullets coming in my direction, even through the water!)
There are plenty of videos showing a bullet going through gell without fragmenting or tumbling but you still get a big hole.
I'm not clear why some bullets go through blocks of gell without tumbling yet others fragment in water. Myth busters fired various weapons into a swimming pool to work out how deep Mr Bond would have to dive to escape. The answer was just 14" even when the gun is a 50 calib...
I think its more about the projo expanding or tumbling. Any decent hunting bullet is designed to expand(or fragment violently if youre after varmints). The big cavity you see in ballistic gel(and human flesh for that matter) is only temporary, as gel/flesh are very flexible. Hence why I doubt the temporary cavity causes the exit to be bigger. You mainly want the bullet to have a nice ballistic efficient so itll hold its velocity better along with performing reliably. In essence, you want the bullet to expand reliably but at the same time penetrate the shoulder bone reliably without fragmenting too much and give a nice big exit for an easily visible blood trail that you can see especially if in the dark(or hopefully no trail at all and for it to drop where its at). Though the main thing is consistency, if you know your favorite bullet fragments on bone, adjust your aim. Thats the main challenge with bullets; consistency. It used to be that bullets with good BC`s(target shooting bullets) and hence good for long range were strictly not meant for hunting and vice-versa. Berger has done a great job in fixing that nowadays though.
1. Why is the exit wound in a rifle gun shot injury bigger than the entry wound?
The size of exit wound in a rifle gun shot injury is generally larger than the entry wound due to the high velocity and energy of the bullet. When a bullet enters the body, it creates a temporary cavity that stretches the surrounding tissues. As the bullet passes through the body, it creates a permanent cavity which is typically larger than the temporary cavity. The energy of the bullet is transferred to the tissues, causing them to burst and create a larger exit wound.
2. Does the size of the exit wound depend on the type of rifle used?
Yes, the size of the exit wound can vary depending on the type of rifle used. Rifles with higher muzzle velocities and larger caliber bullets will generally create larger exit wounds compared to rifles with lower muzzle velocities and smaller caliber bullets. This is due to the increased energy and force of impact that these rifles have on the tissues.
3. Are there any factors that can affect the size of the exit wound?
Aside from the type of rifle used, there are other factors that can affect the size of the exit wound. These include the distance from which the rifle was fired, the angle at which the bullet enters the body, and the type of tissue that the bullet passes through. For example, a bullet passing through soft tissue will create a larger exit wound compared to a bullet passing through bone.
4. Why does the size of the exit wound matter in a rifle gun shot injury?
The size of the exit wound can provide important information to forensic scientists in determining the type of weapon used and the direction from which the bullet entered the body. This information can also help in identifying the cause of death and reconstructing the events that led to the gunshot injury.
5. Is it possible for the entry wound to be larger than the exit wound in a rifle gun shot injury?
Although it is rare, it is possible for the entry wound to be larger than the exit wound in a rifle gun shot injury. This can occur if the bullet is tumbling as it enters the body, causing it to create a larger entry wound compared to the exit wound. However, this is not common and the exit wound is typically larger due to the reasons mentioned earlier.
  • General Discussion
20K
  • Other Physics Topics
9K
  • Astronomy and Astrophysics
