Where can I find a Potentiometer Panel-mount, single-turn, 2K linear
In summary, the conversation is about a person living in the UK looking for a Potentiometer Panel-mount, single-turn, 2K linear, 0.1 min and not being able to find it on the internet without high postage costs. They receive some advice on where to find it on eBay and the suggestion to try Maplin shops. The conversation also mentions ordering from China and Hong Kong for cheaper prices.
Kieranlavelle
Hi guys I live in the UK and I was wondering if any of you knew a place where I could get hold of a Potentiometer Panel-mount, single-turn, 2K linear, 0.1 min. And it need be no more than 0.5w. The reason for this is because I can't find one on the internet in the UK without excessive postage for some reason (on place was £16 for a couple of grams worth) thanks a lot.
:D
Try this:
http://www.ebay.com.au/itm/2-x-2K-OHM-Linear-Taper-Potentiometer-Pot-B2K-/250840505323?pt=LH_DefaultDomain_0&hash=item3a67425beb
Or this one:
http://www.ebay.com.au/itm/2-x-2K-OHM-Logarithmic-Taper-Potentiometer-Pot-A2K-2KA-FREE-SHIPPING-/260902100022?pt=LH_DefaultDomain_0&hash=item3cbefa1c36
Thanks, I hate to say this but I'm a bit of an ammature will that do the same job as the one I described above and do you know any site from a UK seller where I could get the same kind of thing.
Thank you.
Having just ordered a few minor components for a small project (all the stuff I used to own has gone), I'd agree with you that it is a real nightmare to buy specific items singly. It is always worth visiting Maplin shops (if there is one near you), who sell bags of assorted bits. They don't necessarily have just the values you want but it often is not all that critical and you can always peer into each bag of goodies to see what it has in it - they're all different.
The above is rubbish advice if you are planning never to do any more construction but you may get a taste for it.
Right then I may have found the right one, would this work for example in the image?
http://www.ebay.co.uk/itm/POTENTIOMETER-POT-SWITCH-B2K-2K-LINEAR-15MM-SHAFT-TYPE-/200707495463?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item2ebb195627#ht_500wt_949
http://imageshack.us/photo/my-images/812/dimled.png/
I notice they are 4 times the price and don't quote the postage. Ebay Australia quotes the postages all the time. This stops sellers selling the item cheap and then making it up on postage.
I order from China and Hong Kong all the time. They are very worried about getting less than a 5 star rating so they give amazing service.
I just got 20 Neodymium magnets delivered to Australia for $2.32 including postage.
1. Where can I purchase a Potentiometer Panel-mount, single-turn, 2K linear?
There are many places where you can find a Potentiometer Panel-mount, single-turn, 2K linear. Some options include electronic supply stores, online retailers, and industrial supply companies. It is important to research and compare prices and reviews before making a purchase.
2. What is the difference between a single-turn and multi-turn potentiometer?
A single-turn potentiometer has one full rotation from 0 to 360 degrees, while a multi-turn potentiometer has multiple rotations, typically ranging from 10 to 25 turns. This means that a multi-turn potentiometer offers more precise control and a wider range of values compared to a single-turn potentiometer.
3. What does the term "linear" mean in relation to a potentiometer?
The term "linear" refers to the relationship between the rotational position of the potentiometer and its output voltage. In a linear potentiometer, the output voltage increases or decreases in a consistent and proportional manner as the potentiometer is rotated. This allows for more precise and predictable control.
4. Can I use a 2K potentiometer for a different range of values?
Yes, you can use a 2K potentiometer for a different range of values by using external resistors in a voltage divider circuit. By adjusting the values of the external resistors, you can create a custom range for your potentiometer.
5. Can I mount a potentiometer on any surface?
While potentiometers can be mounted on a variety of surfaces, it is important to consider the material and size of the surface in order to ensure stability and proper functioning. Some potentiometers may also require specific mounting hardware or methods, so it is important to refer to the manufacturer's instructions before mounting.
  • STEM Career Guidance
  • Art, Music, History, and Linguistics
  • General Discussion
  • Aerospace Engineering
  • Beyond the Standard Models
  • MATLAB, Maple, Mathematica, LaTeX
