Binomial expansion comparison with legendre polynomial expansion
In summary, when taking the n-th derivative of binomial expansions, the last terms are not always the same. One series has last term, (-n)! on the bottom, while the other has first term, (n+1)!. You need to leave out the first n/2 terms of the series in the n-th derivative, since they are all zero.
linda300
61
Hi,
I've been working on this question which asks to show that
[itex]{{P}_{n}}(x)=\frac{1}{{{2}^{n}}n!}\frac{{{d}^{n}}}{d{{x}^{n}}}{{\left( {{x}^{2}}-1 \right)}^{n}}[/itex]
So first taking the n derivatives of the binomial expansions of (x2-1)n
[itex]{{({{x}^{2}}-1)}^{n}}=\sum\limits_{k=0}^{n}{{{(-1)}^{k}}\frac{n!}{k!(n-k)!}{{x}^{2n-2k}}}[/itex]
[itex]\frac{{{d}^{n}}}{d{{x}^{n}}}...=\sum\limits_{k=0}^{n}{{{(-1)}^{k}}\frac{n!}{k!(n-k)!}(2n-2k)(2n-2k-1)...(2n-2k-n+1){{x}^{2n-2k}}}[/itex]
[itex]=n!\sum\limits_{k=0}^{n}{{{(-1)}^{k}}\frac{(2n-2k)!}{k!(n-k)!(n-2k)!}{{x}^{2n-2k}}}[/itex]and comparing it with[itex]{{P}_{n}}(x)=\sum\limits_{m=0}^{M}{{{(-1)}^{m}}\frac{(2n-2m)!}{{{2}^{n}}m!(n-m)!(n-2m)!}{{x}^{n-2m}}},\,\,\,\,M=\frac{n}{2},\frac{n-1}{2}[/itex]
[itex]=\frac{1}{{{2}^{n}}}\sum\limits_{m=0}^{\frac{n}{2}}{{{(-1)}^{m}}\frac{(2n-2m)!}{m!(n-m)!(n-2m)!}{{x}^{n-2m}}}[/itex]
I'm having trouble with the final part,
It's clear that there's a factor of 1/n!2n difference between them but also
the Pn(x) series has m=0...n/2, and also xn , where as the n'th derivative series has k=0...n and x2n.
How can you rewrite one in terms of the other so they both have the same sum limits?
I've tried setting k=2s in the n'th derivative series and a bunch of other similar changes, but non will change the n'th powers of x.
The reason I noticed this was because the last terms of the series arn't the same,
the first series has last term, (-n)! on the bottom, means 1/infinity right?
[itex]n!{{(-1)}^{n}}\frac{0!}{n!0!(-n)!}[/itex]
and the second
[itex]\frac{1}{{{2}^{n}}}{{(-1)}^{\frac{n}{2}}}\frac{n!}{n!(\frac{n}{2})!0!}{{x}^{0}}[/itex]
Have I made a mistake early on or is there a clever way to combine the two series?
Thanks,
Linda
Hi linda300! :smile:
The factor 1/n!2n is already present in your first equation, so that is not a difference.
When you took the n-th derivative, you didn't lower the power of x by n, so you should have xn-2k instead of x2n-2k
Finally, when you take the derivative of x0 you should get zero, and not a negative power of x.
So you should leave out the first n/2 terms, since they are all zero.
Thanks heaps for taking the time to find my silly mistakes!
=D
1. What is the difference between binomial expansion and Legendre polynomial expansion?
Binomial expansion is a mathematical technique used to expand the binomial expression (a+b)^n into a polynomial. On the other hand, Legendre polynomial expansion is a series expansion technique used to express a function as a sum of Legendre polynomials. The main difference between the two is that binomial expansion deals with binomial expressions while Legendre polynomial expansion deals with functions.
2. Which one is more commonly used in scientific research, binomial expansion or Legendre polynomial expansion?
It depends on the specific application and the type of function that needs to be expanded. Binomial expansion is more commonly used in probability and statistics, while Legendre polynomial expansion is used in physics, engineering, and other scientific fields to solve differential equations and express functions in terms of orthogonal polynomials.
3. Can binomial expansion and Legendre polynomial expansion be used interchangeably?
No, they cannot be used interchangeably. Both techniques have their own specific applications and limitations. While binomial expansion is used for binomial expressions, Legendre polynomial expansion is used for functions that can be represented by a series of Legendre polynomials.
4. What are the similarities between binomial expansion and Legendre polynomial expansion?
Both techniques involve expanding a function into a series of terms. They also both use mathematical formulas and techniques to determine the coefficients of each term in the expansion. Additionally, both techniques are used to approximate a function in a specific form.
5. How do binomial expansion and Legendre polynomial expansion compare in terms of accuracy?
Binomial expansion is more accurate for binomial expressions, while Legendre polynomial expansion is more accurate for functions that can be represented by a series of Legendre polynomials. However, the accuracy of both techniques depends on the number of terms used in the expansion.
