Calculating Solutions w/w: Beginner Question
  • Thread starter Delicieuxz
  • Tags
    Beginner
In summary, the conversation is about creating solutions using 95-98% H2SO4 and 28-30% NH4OH. The calculations for making 100ml of 5% H2SO4 w/w and 100ml of 10% NH4OH w/w are discussed, with the use of molarity and w/w ratios explained. The method for calculating solutions based on w/w is also mentioned. It is recommended to use a balance and the densities of the final solutions. Pouring the acid into the water is also emphasized. The conversation ends with a confirmation that the method is straightforward and thanks for the help.
Delicieuxz
Hi! I've got a beginner question. I'd like to know what quantities are required to make a couple solutions, but I'd also like to understand how the calculations are made.
I have 95-98% H2SO4 and 28-30% NH4OH, and I'm attempting to figure out the values to make 100ml of 5% H2SO4 w/w and also 100ml 10% NH4OH w/w. I previously didn't know what w/w meant, but I looked it up and saw that w/w stipulates that the ratio is to be based on mass.
If this means that I need to calculate based on the H2SO4 and NH4OH molarity's of 98.079 g/mol and 35.04 g/mol respectively, then I really am lost. But then, it might be as basic an issue as ensuring that my H2SO4 makes up 5% of 100ml, and then topping the remainder up with H2O until I hit the 100ml mark.
I'm guessing that my mind is making this out to be more complex that it really is.
Can someone please tell me the amounts of H2SO4, NH4OH, and H2O to use for both solutions, and also maybe crash course me on the method used to calculate solutions based on w/w? Thank you.
Chemistry news on Phys.org
I would rather consider using a balance. You also need the densities of the final solutions.
As long as you are dealing with %w/w both before and after dilution, you don't need molarity. But you need masses.
Consider adding 35g of water to 20g of 95%w/w sulfuric acid. Final solution will have a mass of 55g (sum of masses), and it will contain 95%/100%*20g = 19g of sulfuric acid. Thus its concentration will be 19g/55g*100%=34.5%.
You can't do the same with volumes, as volumes are not additive. Mixing 20mL of the mentioned acid solution with 35mL of water yields 51.8mL of solution (checked with the - it has built in density tables, so it can convert volumes to masses, do calculations using masses, then convert them back to volumes).
Ok, thanks. Is it standard that the concentrate solution, which is to be diluted, will be already calculated in w/w? It's 500ml ~18M.
If I take 5g of the concentrated HS2O4, count 0.175ml of it as being H2O content (averaging 95-98% as 96.5%), then add 91.5ml H2O, will I then have a ~5% HS2O4 w/w solution?
To get 100g of a 5% solution (which is not exactly 100 ml) take 5/0.965 g=5.18 g of 96,5% H2SO4 and 100g-5,18g of water. Not so complicated.Mind to pour the acid into the water, not the other way round.
Will work, but gives you less than 100g of solution.
OK I get that now, it's pretty straight forward. Thanks.
1. How do I calculate solutions w/w?
To calculate solutions w/w, you will need to know the mass of the solute (substance being dissolved) and the mass of the solvent (liquid or gas the solute is being dissolved in). The solution w/w is expressed as a percentage, so you will need to divide the mass of the solute by the total mass of the solution (solute + solvent) and multiply by 100. This will give you the solution w/w percentage.
2. Can I use any units for the masses of the solute and solvent?
It is important to use consistent units when calculating solutions w/w. Typically, mass is measured in grams (g) or kilograms (kg). Whichever unit you choose, make sure to use the same unit for both the solute and solvent in your calculation.
3. What is the difference between solutions w/w and solutions w/v?
Solutions w/w (weight/weight) and solutions w/v (weight/volume) are both ways of expressing concentration, but they use different measurements. Solutions w/w express the ratio of the mass of the solute to the total mass of the solution, while solutions w/v express the ratio of the mass of the solute to the volume of the solution.
4. How do I convert between solutions w/w and solutions w/v?
To convert between solutions w/w and solutions w/v, you will need to know the density of the solution. This can be found on the solution's label or by looking it up in a reference book. Then, you can use the formula: solutions w/v = (solutions w/w) x (density of solution).
5. Can I use solutions w/w to calculate dilutions?
Yes, solutions w/w can be used to calculate dilutions. To do this, you will need to know the desired concentration of the diluted solution and the concentration of the original solution. Then, you can use the formula: (desired concentration) = (original concentration) x (volume of original solution) / (volume of diluted solution).
  • Biology and Chemistry Homework Help
  • Thermodynamics
