What gives the charge of particle?
In summary, the Standard Model does not have a fundamental explanation for the origin of charges, something which is also true for other fundamental quantities in our universe.
us40
29
why some particles like proton and electron have positive and nagetive charge while neutron and neutrino are electrically neutral??
Charge is a fundamental property of certain particles. There is no underlying reason why these charges exist. We simply observe that they do.
Also, protons and neutrons are made up of quarks. Up quarks have +2/3 charge, while down quarks have -1/3 charge. Since protons have 2 up quarks and 1 down quark they have +1 charge. Neutrons have two down quarks and one up quark, leading to no net charge. Electrons and neutrinos are fundamental particles and simply have -1 and zero charge respectively.
but we can say same thing for mass but we can find higgs mechanism by raising this type of question why some particle have mass and other are massless.and since wimps are electrically neutral we can understand their nature by charge giving mechanism and so nature of dark matter.
The higgs mechanism does not explain why particles have the masses they have, it only explains how it works. Much like electromagnetism explains how charges interact but not why each particle has the charge that it has.
Just so you know, a "proton" and a "neutron" are not elementary particles, while electron and neutrino are. So there is a "reason" why proton and neutron have the charges (or lack of charges) that they do (quark content). But then, you can always ask why the quarks have those charges, very much like the electron and neutrino.
The short answer is, we do not know. The Standard Model of elementary particles currently does not have an origin or a mechanism for the origin of charges, the same way it doesn't explain the origin of spins quantum number. There are many things in our universe in which the quantities have no underlying or more fundamental explanation (speed of light, fine structure constants, etc.. etc.).
Zz.
What is the charge of a particle?
The charge of a particle is a fundamental property that describes the amount of electric force a particle has. It is measured in units of Coulombs (C).
How is the charge of a particle determined?
The charge of a particle can be determined through various experiments and calculations. For example, the charge of an electron is determined by measuring its effect on other particles through the use of a device called an electrometer.
Why do particles have different charges?
Particles have different charges because of the different number of protons and electrons they possess. Protons have a positive charge while electrons have a negative charge, and the overall charge of a particle is determined by the balance between these two.
What are positive and negative charges?
Positive and negative charges refer to the two types of electric charge that particles can possess. Positive charges are associated with protons, while negative charges are associated with electrons.
What is the significance of the charge of a particle?
The charge of a particle is significant because it allows for the interaction between particles and the creation of electric fields. It also plays a crucial role in many physical phenomena, such as electricity, magnetism, and chemical reactions.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
