Force of friction with multiple coefficient of frictions
In summary: So the net work done by friction is W = -MgL(mu_1+mu_2)/2. In summary, the problem is to find the net work done by friction on a uniform board being pulled over two different surfaces with varying coefficients of kinetic friction. The net work is expressed as W = -MgL(mu_1+mu_2)/2, where M is the mass of the board, g is the acceleration due to gravity, L is the length of the board, mu_1 and mu_2 are the coefficients of kinetic friction in each region. The force of friction at any point depends on how much surface is on each side and can be expressed as (F_f1+F_f2)/2.
ziptrickhead
I'm working on this problem for homework. Basically it's to find the work done by friction. Now for the work it would be the force of friction times the displacement. The problem is the board being pushed is going over 2 different surfaces, with 2 different values for friction, at the same time. Assuming velocity of the board is constant, what would be the force of friction? I thought it was the normal force times the sum of the coefficients (F_friction=N(mu_1+mu_2)) but apparently it's not.
Interesting. Could you describe the problem exactly? (Why would you add the coefficients? Since any board can be thought of as two half-boards, your reasoning leads to a contradiction.)
A uniform board of length L and mass M lies near a boundary that separates two regions. In region 1, the coefficient of kinetic friction between the board and the surface is mu_1, and in region 2, the coefficient is mu_2.
Find the net work W done by friction in pulling the board directly from region 1 to region 2. Assume that the board moves at constant velocity.
Express the net work in terms of M, g, L, mu_1, and mu_2.
EDIT: The board is pulled over the boundary exactly the distance L.
Since the board is uniform, assume that the normal force per unit length is also uniform. Express the force that must be exerted on the board as a function of the position of the leading edge, which moves from x = 0 to x = L.
So basically because the board is uniform, the normal force is uniform. So if i were to divide the board into 2 separate boards then the value of the normal force would also be divided into 2? So since there are two different surfaces, it would be dividing the force by two eg. F_friction=Mg(mu_1+mu_2)/2?
Right.
That will be the average force of friction during its travel across the boundary. The actual force at any point depends on how much surface is on each side. For example, just as it begins to move all of the length (and thus all of the normal force) is on the mu_1 side, so F_friction = Mg(mu_1) at that point.
Ohhh, so since the board is basically on each surface the same amount of time, the force of friction would be the average of the force of friction for each separate surface:
F_f1=Mg(mu_1)
F_f2=Mg(mu_2)
=> (F_f1+F_f2)/2 = Mg(mu_1+mu_2)/2
1. What is the definition of force of friction with multiple coefficients of friction?
The force of friction with multiple coefficients of friction is the total resistance force experienced by an object when it is in contact with a surface and is moving or attempting to move. This force is dependent on the coefficients of friction, which are values that represent the level of friction between two surfaces.
2. How is the force of friction with multiple coefficients of friction calculated?
The force of friction with multiple coefficients of friction can be calculated by multiplying the coefficients of friction by the normal force, which is the force exerted by the surface on the object. This product will give the maximum amount of friction that can be generated between the two surfaces.
3. What are the different types of coefficients of friction?
There are two main types of coefficients of friction: static and kinetic. Static friction refers to the amount of force needed to overcome the initial resistance and start an object moving on a surface. Kinetic friction, on the other hand, is the force that opposes the movement of an object that is already in motion.
4. How do multiple coefficients of friction impact the force of friction?
When there are multiple coefficients of friction present between two surfaces, the force of friction is determined by the highest coefficient of friction. This means that the surface with the highest level of friction will have the greatest impact on the overall resistance force experienced by the object.
5. Can the force of friction with multiple coefficients of friction be reduced?
Yes, the force of friction with multiple coefficients of friction can be reduced by using lubricants or changing the materials of the surfaces in contact. Lubricants create a barrier between the surfaces, reducing the coefficient of friction and thus, the force of friction. Changing the materials of the surfaces can also reduce the coefficient of friction, as certain materials have a lower level of friction than others.
