- #36
Pythagorean
- 313
ZachHerbert said:I know that they aren't fundamental in the same way, but it seems that Jammer's critique still applies. If "quark color" can't be meaningfully isolated from "the symmetry of rotations in SU(3)" - and it seems that it can't - then doesn't that fall into the same circular mess as force/mass? The strong force wasn't invented arbitrarily. It was introduced to explain the behavior of physical systems - just like force/mass was used to explain why some things "weigh more" than others (I know, oversimplified again). I agree that the symmetry route is much cleaner. But it still doesn't make it through the field of play unscathed.
Well, yes, I noticed that you meant charge/mass in general, which is why I thought the other paper was relevant (speaking about structure on the sub-planck scale).
I actually agree with ZapperZ that it's not so circular really. For me, it's merely a matter of infinite regress. If you keep breaking matter up into smaller and smaller parts, how can you ever be confident that you've reached the "bottom"?
We seem to have found a bottom limit with quantum systems, and dispersive quantum systems (that can exchange with their environment) are still an open problem; this leaves open an informational approach. For many, the 2nd law of thermodynamics and quantum chaos seem like good ways to approach the system. (i.e. you trace the phase state of a classical system back to it's original state with such high precision that you must suddenly now consider the Heisenberg Uncertainty. But since it's a classical system, it's potentially chaotic (so small changes to the initial condition will evolve into large changes), but since we can't define the systems original state with infinite precision, it puts a significant weight on the importance of the inherent loss of information in the universe: or entropy.
My point is that if the value must demonstrate variation initially (to individuate it from the environment), and then change (to be considered dynamic) - and do both from a relative context (and not from a static absolute) - then even the initial value requires information to model. And if that value never changes, then by what criteria do we claim that time has passed? (Unless, like Newton, we assign time to a static, absolute point of reference. But then we're back to unobservable metaphysics.)
I'm not sure what difference you assign between "demonstrating variation" and "changing".
So then, you would say we can't individuate c or G from the environment, since they don't change?
This is where I depart a bit. I don't believe there is "definiteness" outside of a metaphysical (unobservable) ideal. Merely citing "macroscopic objects" is not sufficient. The observing system (as frame of reference, means of interaction, and consciousness interpreting the result) can not be ignored in any philosophically viable description of reality. (We don't experience true "definiteness," we experience "information" that has been pre-molded by unseen cognitive structures.) And I don't see that we have any established mechanism to adequately integrate an "observer" into a "system" without succumbing to Jammer's trap and preserving the gap between kinematics and dynamics - and thus (at least to my mind) failing to establish a truly adequate model of unification. (Yes, Jammer was partly a ruse to initiate the conversation, but the reference is still both valid and applicable to the topic of discussion. In case anyone forgot, it was to talk about the role of dynamical qualities in a potentially unified, informational model of reality. :tongue:)
I don't see how this is a departure; this seemed to be precisely the point to me. I can see how you might take the one sentence you quoted out of context if you didn't read the rest of what I provided...
