Can the proper time interval be < the coordinate time interval?
In summary: So in summary, the proper time is a physical quantity that you cannot change arbitrarily, whereas the coordinate time is simply a mathematical construct that can be chosen to fit your needs.
kmarinas86
979
In general relativity, we have a gravitational time dilation of:
[tex]\frac{d\tau}{dt} = \frac{1}{\sqrt{1 - \frac{2GM}{rc^2}}}[/tex]
The term [itex]- \frac{2GM}{rc^2}[/itex] appears to be based on the fact that gravity is attractive. If I understand correctly, if the curvature of space-time leads to attraction, then the curvature of space-time is positive. Alternatively, some parts of space-time could be curved the other way. It could have negative curvature instead of positive curvature. Instead of only bending paths inward as in elliptical geometry, we could have variations in space-time curvature that permit bending of paths outward as in hyperbolic geometry. Why isn't this normally discussed of? I mean, in serious physics people already talk about wormholes, multiverses, parallel dimensions, and time machines, so is there some reason why we ignore the possibility that space could be curved the other way, which in many respects, sounds a lot less like science fiction than what is being entertained right now? Couldn't the curvature of space time in the hyperbolic sense result in a sign change of the effective potential? Couldn't this correspond to a [itex]\frac{d\tau}{dt} < 1[/itex], suggesting the possibility of time acceleration - time dilation's opposite?
You have it backwards, kmarinas86. Take another look at the Schwarzschild solution - it starts off ds2 = (1-2M/r) dt2 - ... Which means that for a particle sitting still, ds/dt = √(1 - 2M/r), which is less than 1. Elapsed proper time is less than elapsed coordinate time, not greater. The Schwarzschild field is attractive, however the terms positive/negative curvature and elliptical vs hyperbolic don't really apply.
I'm afraid this is a false impression. Topics like these are more typically found in articles in Discover magazine. The kindest term for them is "highly speculative". Most physicists do not sit around talking about wormholes and multiverses.
Coordinate time is just a choice of coordinates. Of course it's possible to make it's relation with the proper time anything you'd like. Just change your coordinate system.
In general relativity (difference in the time interval due to influence of the gravitational field), just how arbitrary is it? Surely you couldn't just make the proper time interval zero, or something arbitrarily close to it, could you? There has to be some limit - right?
So do you think scientists even know what hyperbolic curvature of spacetime would do to time dilation? Is the idea of there being the opposite of time dilation ruled out by GR, or does GR technically allow it?
Can the proper time interval be > the coordinate time interval?
Oh ya, that's right. ds/dt is the derivative of s with respect to t. Clearly that value would be less than one when considering time dilation. So in reality:
[tex]\frac{d\tau}{dt} = \sqrt{1 - \frac{2GM}{rc^2}}[/tex]
The proper time is the time measured by some clock and so you can't change that one arbitrarily given some process (i.e. proper time for an item to go from one place to another through some path is an invariant and not something that we can change). The coordinate time is purely arbitrary, you can make it essentially anything you want. Of course, you should choose your 4 basis vectors to at least span the 4-dimensional tangent space to the space-time you are considering, and so your time basis vector should, generally, be time-like. But it doesn't always have to be. For example, inside the event horizon of a Schwarzschild black hole, the Schwarzschild time coordinate basis vector becomes space-like.
1. Can you explain the difference between proper time interval and coordinate time interval?
The proper time interval is a measure of time between two events that occur at the same location in space, while the coordinate time interval is a measure of time between two events that occur at different locations in space. The proper time interval is calculated using the laws of special relativity, while the coordinate time interval is calculated using the laws of classical mechanics.
2. Is it possible for the proper time interval to be less than the coordinate time interval?
Yes, it is possible for the proper time interval to be less than the coordinate time interval. This can occur when the two events being measured are separated by a large distance and are moving at different speeds relative to each other. In this case, the effects of time dilation, predicted by special relativity, can cause the proper time interval to be shorter than the coordinate time interval.
3. How does time dilation affect the proper and coordinate time intervals?
Time dilation, as predicted by special relativity, states that time slows down for objects that are moving at high speeds. This means that the proper time interval, which is measured by an observer who is at rest with the events being measured, will be shorter than the coordinate time interval, which is measured by an observer who is moving with respect to the events being measured.
4. Can the proper time interval ever be greater than the coordinate time interval?
No, the proper time interval can never be greater than the coordinate time interval. This is because time dilation always results in the proper time interval being shorter than the coordinate time interval. However, the proper time interval can be equal to the coordinate time interval in certain situations, such as when the two events being measured occur at the same location and at the same time.
5. How is the concept of simultaneity affected by the proper and coordinate time intervals?
The concept of simultaneity, which refers to two events occurring at the same time, is affected by the proper and coordinate time intervals. This is because, according to special relativity, the concept of simultaneity is relative and can differ for observers in different frames of reference. Therefore, the proper and coordinate time intervals can result in different measurements of simultaneity for different observers.
