When a free proton captures a free electron
In summary: The collision of an electron with a quark changes the nature of the quark so that behaves this way. I'm still not sure what's going on.What's "the Standard Model"?Is this something that has been experimentally observed?The Standard Model is the prevailing theory of particle physics, which explains the observed properties of the fundamental particles. It's still being developed, so it's possible that further observations would lead to changes that would invalidate it.In summary, the electron is "scattered" when it collides with a quark within the proton, and sometimes a neutron and neutrino are created as a result.
Buckeye
165
If we shoot a single low energy proton directly into the path of a single low energy electron, both being truly free in space, what theory describes the change in the spatial distribution of the free electron as it changes from a "focused" point-like particle into a "cloud-like" point particle that envelops the proton?
It's position is not perfectly defined before it's captured either. Also a photon of the ionization energy must be released for the capture to take place.
Proton and electron are anti-particles of each other . The result may end up being complete annihilation with energy being radiated in terms of radiation.
BJ
BJ
The anti-particle equivalent of the electron is the positron, the anti-particle equivalent of the proton is the anti-proton. A fundamental particle such as an electron cannot not have a composite particle as its anti-particle even though the charge is different.
I recall this was discussed recently in these forums.
By "this", do you mean my original question? If so, please point me in that direction. Thanks!
Didn't know that. Where can I read more about photon emission when a proton captures an electron?
Capturing an electron is just ionization in reverse: http://hyperphysics.phy-astr.gsu.edu/hbase/chemical/ionize.html
Since the electron loses energy by being in a lower energy level around the proton, a photon has to be emmited as it falls from it's initial energy to the new energy. Even if you assumed the electron had no kinetic energy in the unbound state, it gains energy falling into the electric potential well.
Or (for completeness) several photons whose sum is the ionization energy.
I'm puzzled. When I read HyperPhysics about Electron Capture I am reading about Radioactivity wherein (7)Be captures and electron and converts into (7)Li with a photon emitted.
That is a different kind of capture. You are converting one of the protons into a neutron. I'm not sure if "capture" is even the most correct name for what we are talking about. Electron recombination? I don't know.
If by "capture" you mean the electron joins the proton in a new Hydrogen atom, that can certainly happen. But it only happens at extremely low energies. Just a handful of eV, no more. And the energies and directions of the two particles need to be just right.
But if you're talking about some kind of absorbsion going on, things are different.
Let's say you shoot an electron directly at a proton, so that they collide. They do this at the HERA lab. It's not going to be like two billiard balls colliding, because the proton is really made of smaller things. At sufficient energies, the electron is going to collide with one of the quarks or gluons that the proton is made of, if it collides with anything at all.
There have been observations at HERA of electrons colliding with something OTHER THAN a quark or gluon. Quarks and gluons have "color" attributes, but sometimes you see an electron interacting with something "colorless" within the proton. The electron appears to be "scattered" when this happens. I have no clue what's going on when that happens.
Sometimes, what happens in this kind of collision is that the proton and electron reassemble into a neutron and a neutrino. A heck of a lot of energy gets released. Sometimes, you wind up with an electron again, plus a lot of hadronic junk.
The coolest observations, however, are when an electron dives into the interior of a proton, and gets reflected straight back out the way it came. As if there was a mirror deep inside a proton. This seems to contradict the Standard Model (which would require such a reflecting object to be very very massive and also have very strong interactions with leptons), but further analysis is required before any conclusions are drawn. It may well be that the collision of an electron with a quark changes the nature of the quark so that behaves this way (some call that hypothetical creature a "lepto-quark"). Or it could be something not yet dreamt of in our philosophy.
1. What is the process of a free proton capturing a free electron?
The process of a free proton capturing a free electron is known as electron capture. It involves a proton in the nucleus of an atom binding with a free electron, resulting in the formation of a neutron and a neutrino.
2. Why does a free proton capture a free electron?
A free proton captures a free electron in order to achieve a more stable state. By combining with the electron, the proton can become a neutron, which has a lower energy state and is more stable.
3. How does the capture of a free electron affect the atom?
The capture of a free electron can result in the atom becoming a different element. This is because the number of protons in the nucleus changes, which determines the identity of the element. Additionally, the atom may also become more stable due to the reduction of a positively charged proton.
4. What are the implications of free proton capture in nuclear reactions?
The process of free proton capture is important in nuclear reactions as it can lead to the formation of new elements and can also release energy. It is also a key component in the formation of neutron stars, which are extremely dense objects in space.
5. Is the capture of a free electron by a free proton a common occurrence?
No, the capture of a free electron by a free proton is not a common occurrence. It usually only happens in extreme conditions, such as in high-energy particle collisions or in the cores of stars. In everyday life, this process is not observed as protons and electrons are usually bound together in atoms.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
