Calculating apparent positions of sun and moon
  • Thread starter jamadagni
  • Tags
    Moon Sun
In summary, To accurately calculate the geocentric apparent positions of Spica, the sun, and moon, you will need to apply proper motion, precession, rotation of the ecliptic, stellar aberration, and nutation corrections. For the specific time period of 1800 to 2200, the annual parallax correction can be neglected. The importance of gravitational deflection correction will depend on the proximity of the star to the sun.
jamadagni
I would like to calculate with high-accuracy the apparent geocentric positions of this three: Spica, the sun and moon. I will apply the following corrections for Spica:
1. proper motion
2. precession
3. rotation of ecliptic
4. stellar aberration
5. annual parallax
6. gravitational deflection
7. nutation
My questions:
1. Is there any particular order in which these corrections must be done?
2. Do I correct for gravitational deflection for sun and moon too?
3. Do I correct for light-time movement and aberration for moon?
Thank you.
Astronomy news on Phys.org
my guesses:
1. No
2. Depends on your time scale and your desired accuracy.
3. how high is high-accuracy? It's not too hard to test the speed of light by comparing over the course of a few months the positions of Jupiter's moons (or any planets' moons). But if you simply want to know where to point your telescope to observe Spica, the Sun, or the Moon, you can comfortably ignore the speed of light.
Hello and thanks for replying. I need geocentric apparent positions of the sun, moon and planets to the nearest tenth of an arc-second. So please indicate which corrections of the seven listed I can drop. Thank you.
Gravitational deflection will be negligible unless they lie on top one another. The others will depend on what data you're working from and how far in advance you need them calculated.
I need geocentric positions for Spica, sun and moon from 1800 to 2200 (or so) to the nearest tenth of an arc-second. "What data I am working from" -- I do not understand this.
Stellar aberration, proper motion, parallax, and gravitational deflection are all effects that appear in data, so in order for them to be important you have to be working from something. If, instead, you want to calculate the positions theoretically or with empirical fits (given certain initial conditions), then you only have to make sure you're considering precession, nutation, and other physical changes in the coordinate system and planetary orbits.
For the sun and moon I will be using the JPL and VSOP/ELP (the latter for the users who do not have the JPL files). For Spica of course I have ICRS coordinates and proper motion from Simbad.
Now I am wondering which of these various corrections can be neglected because I do not require a precision less than 0.1"... That is what I am asking the guru-s here.
OK let me try something here:
  1. proper motion -- in the period 1800 to 2200 (400 years) the proper motion changes the equatorial coordinates by at least 12 arcseconds so I have to do this corrections.
  2. precession -- certainly I have to calculate
  3. change of longitude due to rotation of ecliptic -- I have to do some calculations -- since Spica lies pretty close to the ecliptic, I wonder if the 47" /cy (=188" in 4 cys) change creates a significant change in the ecliptic longitude
  4. stellar aberration is of the order of 20" so I have to do this for Spica and the sun but do I have to do this for the moon?
  5. annual parallax for Spica is 12.44 milliarcseconds. So this can be neglected.
  6. nutation -- yes I need to calculate as it can be of the order of several arcseconds.
So are my above judgments correct?
Now how about gravitational deflection? If a star is right behind the sun, then how much would its light be deflected?
1. How do you calculate the apparent positions of the sun and moon?
The apparent position of the sun and moon can be calculated using a combination of astronomical data, such as their right ascension and declination, as well as the observer's location and time of observation. These calculations can be done manually using formulas or through computer software.
2. What is the difference between the apparent position and the true position of the sun and moon?
The true position of the sun and moon refers to their actual location in the sky, taking into account the Earth's rotation and orbit around the sun. The apparent position, on the other hand, takes into account the effects of atmospheric refraction and the observer's location, which can cause the sun and moon to appear slightly higher or lower in the sky than their true positions.
3. Can the apparent positions of the sun and moon change?
Yes, the apparent positions of the sun and moon can change throughout the day due to the Earth's rotation and the changing position of the observer. Additionally, the apparent positions can also vary slightly due to atmospheric conditions and the location of the observer on the Earth's surface.
4. How accurate are the calculations for the apparent positions of the sun and moon?
The accuracy of the calculations for the apparent positions of the sun and moon can vary depending on the method used and the precision of the data used. However, these calculations are generally very accurate and can be relied upon for astronomical observations and calculations.
5. Can I calculate the apparent positions of the sun and moon for any location on Earth?
Yes, with the right data and calculations, you can determine the apparent positions of the sun and moon for any location on Earth. However, keep in mind that the further away you are from the equator, the more the apparent positions of the sun and moon will vary throughout the year.
  • Astronomy and Astrophysics
