What is the precise definition of yaw?
  • Thread starter FizicistsRool
  • Tags
    Definition
In summary, "yaw" refers to rotation around the z-axis, which is perpendicular to the x-y plane and is one of the six degrees of freedom in rigid body motion. It is typically defined based on the orientation of an aircraft's wings or a ship's beam, but can be defined in a more general sense using three mutually perpendicular axes. The direction of gravity does not necessarily play a role in this definition.
FizicistsRool
Precise definition of "yaw"
I'm googled "yaw" for the afternoon and there is a detail that I'm not finding. *One* of my understanding of yaw from my readings is that it is the angle between two /vertical/ planes, one containing the velocity of the moving object and the other containing "longitudinal" axis of the moving object i.e. the front-to-tail axis of the fuselage of an aircraft.
This is my own cobbled together idea of waht yaw could *possibly* mean. Nowhere is yaw defined exactly in these terms. Instead, yaw is explained in terms of rotation around the vertical axis, where it sometimes seems that vertical axis refers to the "longitudinal" axis, and somtimes it seems to refer the gravity vector. For now, I assumed the latter.
Even so, there is the question of precisely how to measure the angle between the velocity vector and the direction in which the moving object is facing. The possibilities that come to mind are:
1. Just measure the angle between the two.
2. Both vectors projected onto a completely horizontal plane
3. Both vectors projected onto a plane containing (1) the velocity vector and (2) the intersection of the horizontal plane with the plane that is perpedicular to the velocity vector.
4. Both vectors projected onto a plane containing (1) the "longitudinal" vector and (2) the intersection of the horizontal plane with the plane that is perpedicular to the "longitudinal" vector.
5. Both vectors are projected onto the plane containing (1) the "longitudinal" axis and (2) the wing-tip-to-wing-tip axis.
Thanks for any clarification
I did run across that...it doesn't really say, but it looks like the yaw axis is also perpendicular to the longitudinal access of the plane. This would mean it is completely unrelated to the direction of gravity (which contradicts previous material I've read elsewhere). Is that correct?
For rigid body motion, there are 6 degrees of freedom: 3 in translation and 3 in rotation.
Imagine a body like an airplane. Let's assume that the x-axis runs along the center of the fuselage. The y-axis would run perpendicular to the x-axis from wing tip to wing tip.
The z-axis is perpendicular to the x-y plane.
The 3 translational degrees of freedom are as follows
(direction of motion as indicated):
x: Surge
y: Sway
z: Heave
The rotational degrees of freedom (and the axis about which motion takes place) are:
x: Roll
y: Pitch
z: Yaw
Normally, yes, "yaw" is rotation about a vertical axis. A more general definition is SteamKing's: given an arbitrary set of three mutually perpedicular axes, which we arbitrarily call "x", "y", and "z", think of a ship or airplane aligned along the x-axis with its beam (or wings for an airplane) in the direction of the y-axis. Then "roll" is rotation about the x-axis, "pitch" is rotation about the y-axis, and "yaw" is rotation about the z-axis.
x: Surge
y: Sway
z: Heave
x: Roll
y: Pitch
z: Yaw
OK, it sure seems to me like the direction of gravity is completely removed from the definition. For airborne or space things, the z-axis by no means has to be vertical (if the definition of vertical is tethered to the direction of gravity).
I think that the source of my confusion is the word "vertical". Many airborne and space assets can at times be arbitrarily oriented, so vertical by no means has to be defined by the direction of gravity. I take that to be the distinction between the definition above that incorporates the concept of vertical versus the more general definition that only relies on the axes defined by an airplane. Also, for assets without wings (cylindrical shaped), the x-axis falls out of the picture.
its all arbitrary, however, these things are defined by convention.
1. What is the precise definition of yaw?
Yaw is the rotation of an object around its vertical axis. In other words, it is the movement of an object from side to side, perpendicular to its direction of motion.
2. How is yaw different from pitch and roll?
Pitch and roll are rotations around the horizontal and longitudinal axes, respectively. Yaw is the only rotational movement around the vertical axis.
3. Why is yaw important in aviation?
In aviation, yaw is important for controlling the direction of an aircraft. It is controlled by the rudder, which is used to adjust the yaw angle and keep the aircraft on a desired heading.
4. Can yaw be measured?
Yes, yaw can be measured using instruments such as a gyroscope or a rate sensor. These instruments can accurately measure the rotation of an object around its vertical axis.
5. How does yaw affect the stability of a vehicle?
Yaw can affect the stability of a vehicle by causing it to spin or drift off course. In vehicles with multiple wheels, yaw can also cause oversteer or understeer, making it important to control and maintain a stable yaw angle during operation.
  • Mechanics
  • Quantum Physics
  • Differential Geometry
