Designing an Efficient RC Circuit for Linear Ramp Control
In summary: I went back and read what the question was and am now confused.You might want to tell us what you are trying to do. Otherwise, we're just guessing.In summary, the individual is trying to activate a solenoid with a linear ramp in voltage of 0 - 24VDC in 2 seconds and is looking for a circuit that can achieve this using resistor and capacitor elements without the use of an expensive proportional amplifier. They have received suggestions such as using a constant current source and a PNP and NPN transistor circuit to achieve this.
eegeek
Hello!
I'm trying to activate a solenoid with a linear ramp in voltage of 0 - 24VDC in 2 seconds. An RC series circuit helps achieve soft start but in an exponential way (with 63% of supply voltage in 1 time constant). Can I use a single circuit for charging and discharging? (linear ramp down also preferred). Ideal ramp down time should be less than 1 second. Trying to figure out if this circuit is possible with resistor/ capacitor elements and without the use of an expensive proportional amplifier.
Any help is much appreciated!
eegeek said:
Hello!
Hello. A constant current source will charge/discharge an RC circuit to have a linear voltage.
Here is a derivation I did for it a while ago.
  • linearcharge.pdf
Thanks DragonPetter for the quick response! This equation looks more like the one for RC discharging circuit. And to achieve constant current source, I connect a resistor between voltage source and capacitor?
How much is your maximum current?
The coil can take upto about 1.6A..
eegeek said:
Thanks DragonPetter for the quick response! This equation looks more like the one for RC discharging circuit. And to achieve constant current source, I connect a resistor between voltage source and resistor?
It is for the voltage on a capacitor as it is charged or discharged by a constant current. Forget the R component, I eliminated that when I made the current constant.
One possible way to do what you want is to charge a capacitor up to the desired start voltage, and then to put a current source in series between the capacitor and the solenoid, where the current source's supply is from the capacitor. I don't know what problems you may have doing this in a practical circuit tho. I see a problem in that the voltage at the inductor would be 0 if it is given a constant current, which defeats your goal to have a ramp voltage across the solenoid. You could still use the linear V discharging cap as a reference voltage.
@DragonPetter: You're right. I actually have to use a 8Ω resistor anyway to have a current of 1.6A at the solenoid coil (7Ω) from a 24V DC source. So my circuit currently has a 24V source in series with an 8 ohm resistor, a .056 F capacitor and the coil. Of course linear ramp is difficult here. Don't have much experience with op-amps, will they help?
What are you using the solenoid for, eegeek, and why do you want a soft-start?
@NascentOxygen: The solenoid is used for steering a large equipment and a sudden step input might result in jerk resulting from force needed to overcome the moment of inertia (infact an exponential voltage coming from series RC circuit might do the same). Hence the soft start..Do you have a solution?
A true linear voltage ramp requires a linear op amp current integrator. See http://www.wisc-online.com/Objects/ViewObject.aspx?ID=SSE5303
I concur. Cool little display animation with the integrator amp there Bob S.
To add to what Bob s is saying:
The TRANSFER FUNCTION you are looking for is -1/JωRC.
The gain of the amp shown is -RF/RA
(1/JωC)/R = -1/JωRC.
Test your limits at max frequencies. When ω=0...gain will be infinite or saturated in steady state...The time it takes to get there is the RC constant...
When ω=infinity....gain will equal zero.
Reminder: db is 20 log |Gain|...that's how that peske minus sign goes away as far as gain goes...as far as output voltage, it absolutely plays a part.
Look at this (-1/JωRC) in regards to sin and cosine.
We know that sin is the intregal of cosine.
Take your cosine and flip it across the horizontal acces according to the minus sign in the formula.
Now phase shift it -90 according to the J in the denominator. You now have the Sin.
To someone smarter than me...Does what I just wrote make sense? I kinda made it up as I went along...lol.
Thanks all for the helpful replies...
A constant current source needed to be use with a capacitor to create a linear ramp. A constant current source can easily be implemented by just a transistor.
I still don't quite know what you are trying to do. Do you mean you want to achieve a soft start by using a linear Ramp to ramp the voltage from 0 to 24V across the solenoid to create a soft start. Then when you want to turn off the solenoid, you want to ramp down the voltage to achieve soft turning off?
This is a circuit I whipped out quickly and see whether it works for you:
151550[/ATTACH]"]
I have two constant current source by the PNP and NPN. The PNP is always on. The current is about 3V/R3. The NPN is a switchable current source where it is controlled by the switch on the left. When the switch is closed, the NPN is off so the ramp is generated by the current source of the PNP charging C1. When the switch is open, the NPN current source turns on. R3 is 3 times the value of R4, so current by NPN is 3 times the current of PNP. With that, you achieve charging up at a current called I1, but the discharge current is I2-I1=-2I1. You adjust the ramp by adjust the I1 and C1 to get 2 second ramp up and 1 second ramp down.
The N channel enhancement mode MOSFET is the buffer. I use 30V supply to get 24V at the output. I'll let you work out the detail values. Remember the input capacitance of the MOSFET is quite high, so you need to take that into consideration. This is not a precision circuit in any stretch, but it should do what I understand from you post. This is a cheesy circuit, but you are only driving a solenoid! The only formula need is C1V=It as it is constant current and ramp is linear( well roughly).
R1 and R2 is just to bias the zeners on with very low current.
Let me know is that what you want.
I see. This is specifically when you want to convert a DC voltage to a ramp voltage, as the integration of a constant is a sloped line? I never thought about using the integrator opamp, but that seems like a really good way to do it.
I believe a constant current charge or discharge from a capacitor also gives a truly linear voltage ramp as well, but in this case you don't use a control voltage, but rather a control current.
http://www.maxim-ic.com/app-notes/index.mvp/id/3655
http://www.ti.com/lit/ds/symlink/lm555.pdf (page 10)
http://www.vk2zay.net/article/196 (about a third down)
Those circuits are using a constant current charge/discharge on a capcaitor to generate their ramps. What would make them not truly linear (within their operating ranges)?
@yungman You were quick off the mark with that circuit. :smile: A couple of things as I understand it: his supply is 24V, and the solenoid requires a max drive of 11.2V (1.6A into 7Ω). So possibly include a resistor in the drain of the MOSFET to allow a lower power device.
Oh yeh, anything to lower the power. In fact I am kind of concern with the power dissipation also. I just throw the circuit out as an idea, definitely need some messaging.
@yungman: Thanks! Would you mind a quick sketch for this novice?
"I still don't quite know what you are trying to do. Do you mean you want to achieve a soft start by using a linear Ramp to ramp the voltage from 0 to 24V across the solenoid to create a soft start. Then when you want to turn off the solenoid, you want to ramp down the voltage to achieve soft turning off?"
Yes, this is what I want to do.
That was the schematic, You mean you want the value of the components? Do you understand how the circuit works? I rather you understand the circuit so you can put in the value yourself.
The key is the PNP and NPN transistor setting up as constant current source. You understand the emitter of the NPN is about 0.7V lower from the base ( 0ne diode drop). I use a 3.6V zener to put +3.6V on the base of the NPN, so the emitter is about 3V( don't need to be exact). So you can set up any emitter current by choosing R4. Say if you want Ie=3mA, you put R4=1KΩ. Assume β>100, so collector current Ic≈3mA also.
Same idea as for the PNP where R3=3R4 to get 1mA current from the PNP. So R3=3KΩ.This is just an example, you have to choose your own value and choose C1 to get the ramp time. Remember no need for fancy formula, CV=It is good enough where I is the charging current, t is time, C is capacitance of C1, V is the voltage of the ramp.
R1 and R2 is just to set up the minimum current to bias the zener to operating voltage. Look at the spec of the zener to determine the resistance.
Also include a diode (normally reverse biased) across the coil terminals to protect the electronics against flyback when/if power is accidently disconnected.
If you went with a PWM design (say 2 NE555s and an emitter follower) it would do away with the need to dissipate that unwanted power as heat.
Yes, flyback diode is good. There are so many way to design this, mine is only one of many. Also the Drain resistance to take some power load off the MOSFET.
1. What is an RC circuit for linear ramp?
An RC circuit for linear ramp is an electrical circuit that uses a combination of a resistor (R) and a capacitor (C) to produce a linearly increasing or decreasing voltage over time. It is commonly used in electronic circuits for applications such as signal processing and waveform generation.
2. How does an RC circuit produce a linear ramp?
An RC circuit produces a linear ramp by charging or discharging the capacitor at a constant rate through the resistor. As the capacitor charges or discharges, the voltage across it increases or decreases linearly over time.
3. What is the formula for calculating the time constant of an RC circuit?
The time constant (τ) of an RC circuit is calculated using the formula τ = RC, where R is the resistance in ohms and C is the capacitance in farads.
4. How can the time constant of an RC circuit be adjusted?
The time constant of an RC circuit can be adjusted by changing the values of the resistor or capacitor. A higher resistance or capacitance will result in a longer time constant, while a lower resistance or capacitance will result in a shorter time constant.
5. What are some common applications of RC circuits for linear ramp?
Some common applications of RC circuits for linear ramp include signal processing, waveform generation, and pulse generation in electronic circuits. They are also used in various timing circuits, such as in clocks and timers.
  • Electrical Engineering
  • Classical Physics
