Register to reply
Is there a certain limit of force to a magnetic field?
by Wiz700
Tags: field, force, limit, magnetic
Share this thread:
Wiz700
#1
Apr26-13, 04:03 PM
P: 96
Heyo!
Okay, I always assumed when two "magnetic" objects attract/repel there is always a limit to how much force! Each magnetic object applies.
Say you have a ceramic magnet and a electromagnet.
You build a classic old motor. Now there is a force between the two, As you increase the (Power) fed to the electromagnet it increases the force between them.
But the magnet on the other hand is constant. It has a certain value that can not change.
I noticed that all permanent magnets have a "limit" to the amount of force it can apply to push/pull/flip any magnetic object.
Each pole of a permanent magnet, has a certain value (x) I call the limit.
The limit to the amount of FORCE that pole can apply.
Have I comprehended this correctly?
There is always a limit value of force a magnet's pole can apply to attract/repel another magnetic object?
Phys.Org News Partner Physics news on Phys.org
New study refines biological evolution model
Fiber optic light pipes in the retina do much more than simple image transfer
Production phase for LSST camera sensors nears
mfb
#2
Apr26-13, 05:25 PM
Mentor
P: 11,570
The magnetic field in permanent magnets is limited, and with realistic magnets the force between magnets is limited, too. This is not a fixed value for each magnet, however - it depends on the attracted objects and the environment.
Wiz700
#3
Apr26-13, 07:34 PM
P: 96
Quote Quote by mfb View Post
The magnetic field in permanent magnets is limited, it depends on the attracted objects and the environment.
Indeed, THUS! The magnetic force generated by that limited field is aslo limited at a constant value.
I tend to know the rate of the magnetic field of most of my magnets. However, The amount of force the poles apply is unknown... But I do know it depends on the "orientation" of the project. Many factors are involved would determine how high/low that force is applied. But I do know, that a magnet has a limited amount of force it's field can apply Im trying to figure out how much... Funky business!
I could not figure out this though...
What do you mean by the force between magnets being limited :O?
I ment that each magnet has a fixed limit to the amount of force it can apply.
For example:
A Neodymium disc magnet attracting a iron nail = force is weak, the effort needed to split them apart is low.
Now, lets replace that nail with a HUGE plate x 5 times larger than the magnet's dimensions.
The attraction force (x) is strong! The effort needed increased! (x) can go lower as you decrease the size of the plate but can never be increased as you go x5 + It stay's at that value, and that (x) is the limit of force the field can apply :)
Stunning thing really!
mfb
#4
Apr27-13, 05:49 AM
Mentor
P: 11,570
If you have two objects, there is a maximal force you will have between them.
That is what I meant: The same magnet can lead to different forces, depending on the other object (even if that is not a magnet on its own).
How do you mean that?
Wiz700
#5
Apr27-13, 05:47 PM
P: 96
The thing is, when two magnetic objects attract/repel...
The force is due to both of them, I understand that point. But I assume that each object exerts a certain force on the other and vice versa.
So that amount of force lets say from a magnet. Is limited at a certain value(x)
However, an electromagnet's value is not limited you can add more power and get a higher force easier. The magnet can't increase its value higher than (x).
A magnet will have a limit to how much push/pull it can apply to another object always :)
FOR example:
A motor has a electromagnet + magnet.
The magnet is set at the value(x) and can not change.
However, the electromagnet can increase its value thus the motion is increased! The cause? The electromagnet's force of repulsion/attraction increased and can change and has a limit but HIGHER than the magnet. While the permanent magnet is limited at a value(x) and can not change in the case of the motor.
Hope that helped :)
Wiz700
#6
Apr27-13, 05:49 PM
P: 96
Indeed, just like having a two stick's hitting each other, if you increase the force they break!
goun
#7
Apr28-13, 01:04 PM
P: 3
Quote Quote by Wiz700 View Post
Clever example,however not that correct,beacause when you have a two sticks system, you can hit them with any force size you want and as you mentioned there is a case of breaking.On the other side in a two magnets system there is a maximum force that your system can produce...and not bigger
Wiz700
#8
Apr28-13, 09:54 PM
P: 96
Quote Quote by goun View Post
Say whaaaaat?!
I DEMAND AN ELABORATION!
jeffrey c mc.
#9
Apr28-13, 10:20 PM
P: 45
How come no discussion of the distance between the two magnetic objects? It would seem that would be a vital consideration. Both when 'like' poles are set against each other, and when 'opposite' poles are set against each other? In both cases a logarithmic function needs to be elucidated, or am I wrong in this? In the case of repulsion, in magnets that are perfectly aligned, the repulsive force would increase in a curve that would 'peak,' ever higher, as the distance between the two 'like' poles, where reduced. Or, the repulsion would become stronger as the distance decreased.
goun
#10
Apr29-13, 03:36 AM
P: 3
Say whaaaaat?!
As you want. What i wanted to say is that the example of the two sticks it is not the appropriate to describe the two magnets case. Because as it was told before there is a maximum force that the system can suffer.And the force depends on the system features.However in the two sticks system the force depents on how strong WE hit them, and there is not any kind of a determination about the force size!Even if the system breaks and this is why the force reason is external.In the two magnets we are not allowed to have bigger force from the one that system can stand.Any different view accepted.
goun
#11
Apr29-13, 03:59 AM
P: 3
Quote Quote by jeffrey c mc. View Post
Of cousre the strengh depends on the distance <r> of the two magnetic poles and more specifically F=(1/μ)*((P1*P2)/(r^2))
F is the force size,
where P1 and P2 are the magnitudes of magnetic poles ,r is the distance and μ is the permeability of the intervening medium.No logarithmic function!If we guess stable all those factors except from <r> Force is a hyperbolic function.
Wiz700
#12
Apr29-13, 05:04 PM
P: 96
F= Km1m2/r^2
Will not be appropriate if the distance is for example zero...
The point of this thread is to somewhat bring awareness that if you have a permanent magnet for example
and a electromagnet that has a greater capability to apply a force.
A magnet has a certain limit to as how much force it's pole can apply a force lets put a value for example:
A magnet's pole's(N/S) Has a limit of force = 5N(Newtons, is fit for this example).
While an electromagnet's pole's(N/S) that is interacting with the magnet has a limit too of = 50N
Assuming that the distance between them is 0 so the force is at it's MAX.
pumila
#13
May4-13, 01:32 PM
P: 114
Couple of comments - the attractive force between two magnets, assuming only the field strengths but not the geometry changes, is proportional to the product of the field strengths. If one is constant (as in a permanent magnet), then the force is linearly dependent on the other's field strength.
I may be misunderstanding this limit thing, but one of the limits for a permanent magnet is associated with its remagnetisation levels and hysteresis - under high enough external fields a permanent magnet will be remagnetised to align with the external fields. This is how they are magnetised in the first place. This can be quite subtle if the alignment reinforces the existing magnetisation, when it can be just a few percent. I am not familiar with any other limit.
Wiz700
#14
May4-13, 09:43 PM
P: 96
Knowing that you would have one permeant magnet simply means there is a certain amount of force it's poles can apply. That limit can't be exceeded.
But you're right, exposing the magnet to a strong magnetic field would mean that it could change the magnetization of the magnet.
An electromagnet also has a limit. But by changing the flow of current you can control that amount of "force" the poles can apply.
With a permanent magnet, its more complicated to "control" that force. By changing the distance, or the contact area the force of a magnet's pole could be controlled. But very very very complicated business here!
OCR
#15
May4-13, 11:12 PM
P: 124
If you haven't already, take a look around in the...
National High Magnetic Field Laboratory
OCR
Wiz700
#16
May5-13, 01:14 AM
P: 96
Quote Quote by OCR View Post
OCR
I figured out the answer to my question thankfully.
Thanks for sharing though!
pumila
#17
May5-13, 02:16 AM
P: 114
I think the limit on field strength is a bit arbitrary. As the current through the coils of an electromagnet increases the relative permeability of the core drops. You can either choose that as a limit or keep increasing the current, when the magnet's field strength will continue to increase but more slowly. The only query is how hot the windings get - for pulsed use or with superconductive coils the thermal limits here are as lot higher than for steady state use.
Register to reply
Related Discussions
Finding magnetic field from magnetic force / semielliptical conductor Introductory Physics Homework 2
Magnetic field and magnetic force between wires Introductory Physics Homework 0
Magnetic force, finding angle between velocity and magnetic field Introductory Physics Homework 4
Limit to strength of electron magnetic field Special & General Relativity 10
Need help for a prove about magnetic field and magnetic force Classical Physics 3
