Combined rotational and translational motion
In summary, the total kinetic energy of a long thin rod relative to a laboratory frame rotating around an axis with angular velocity w and translational velocity Vaxis can be calculated using the formula: Total KE = 1/2 M (Vaxis sq) + 1/2 I (w sq), where M is the mass of the rod, L is the length of the rod, and I is the moment of inertia (1/3 M (L sq)). The endpoint velocity of the rod can affect the maximum kinetic energy, with a maximum velocity of one mach when L*w is equal to Vaxis.
e2m2a
354
I need to determine the total kinetic energy of a long thin rod relative to a laboratory frame which rotates around an axis at an angular velocity w and the axis moves at a constant translational velocity. The mass of the rod is M and the length of the rod is L. The translational velocity of the axis is Vaxis.
Moment of Inertia, I, of rod is: 1/3 M (L sq) (This is because the rod rotates at one end).
I believe the total kinetic energy should be: Total KE = 1/2 M (Vaxis sq) + 1/2 I (w sq).
Is this correct?
e2m2a said:
[Moment of Inertia, I, of rod is: 1/3 M (L sq) (This is because the rod rotates at one end).
Is this correct?
Hello e2m2a
The moment of inertia is correct and addition of energies too. Is there some relation of the tangential and the rotational velocities. Remind that the endpoint velocitie for a whip is one mach. The maximum is there when the endpoint of the rods velocity L*w adds up to Vaxis.
greetings Janm
1. What is combined rotational and translational motion?
Combined rotational and translational motion is when an object is simultaneously moving both in a straight line (translation) and rotating around a fixed axis (rotation).
2. What is the difference between rotational and translational motion?
Rotational motion is when an object moves around a fixed point or axis, while translational motion is when an object moves from one location to another in a straight line.
3. How is combined rotational and translational motion calculated?
The combined motion is calculated by combining the equations for rotational motion (using angular velocity and acceleration) and translational motion (using linear velocity and acceleration).
4. What is the relationship between rotational and translational motion?
In combined motion, the two types of motion are interdependent and affect each other. For example, an object's rotational motion can affect its linear velocity and vice versa.
5. What are some real-life examples of combined rotational and translational motion?
A spinning top, a car driving around a curve, and a planet orbiting around a star are all examples of combined rotational and translational motion. Other examples include a rolling ball, a spinning coin, and a swinging pendulum.
