Angular momentum and orientation of electron orbit with l = 0
In summary, in the Bohr model of the atom, an electron in the n=1 orbit has an angular momentum determined by its principal quantum number and orientation given by the angle θ. However, in the modern view of quantum mechanics, the electron state is described by an orbital, which is spherically symmetric for L=0 and has a zero angular momentum, making its orientation meaningless. This is different from the traditional concept of well-defined circular orbits and orientations in the Bohr model.
apr
Let an electron is orbiting in a orbit with the principal quantum number n =1. According to wave mechanics its angular momentum is √ l(l+1) h/2∏ and angle : cosθ = ml/ √ l(l+1)
How one can explain the electron angular momentum and its possible orientations for l =0?
Off course for n =2, l = 0& 1. For l = 1 we can get the angles θ, however, it is not possible for l=0.
How one can explain the zero angular momentum for the electron in the innermost orbit ie., n = 1? How to explain the possible orientation of the orbit for l =0?
apr, I'm afraid you're thinking in terms of the hundred-year-old Bohr model of the atom, in which electrons travel in well-defined circular orbits with certain orientations. This theory was replaced by Schrodinger's quantum mechanics in 1925. In the modern view, an atomic electron state is described not by an orbit but by an orbital, which is a function that gives the probability of finding the electron at a particular location.
For L = 0, the orbital is spherically symmetric.
... and the magnitude of the orbital angular momentum is zero, so it's meaningless to talk about its orientation.
Thanks for the reply .. got the idea.
1. What is angular momentum?
Angular momentum is a physical quantity that describes the rotation or spinning motion of an object around a fixed point. It is a vector quantity that is dependent on the mass, speed, and distance of the object from the fixed point.
2. How is angular momentum related to electron orbit with l = 0?
In quantum mechanics, the angular momentum of an electron in an atom is described by the quantum number l. When l = 0, it means that the electron is in an s orbital, which has zero angular momentum. This means that the electron is not rotating or spinning around the nucleus, but rather it is in a spherical shape around it.
3. What is the significance of the orientation of the electron orbit with l = 0?
The orientation of the electron orbit with l = 0 plays a crucial role in determining the electronic properties of an atom. It affects the energy levels and stability of the atom, as well as the shape of its electron cloud.
4. How does the orientation of the electron orbit with l = 0 change in different atoms?
The orientation of the electron orbit with l = 0 can vary in different atoms due to the different number of protons and electrons present. This leads to variations in the energy levels and stability of the atom, as well as the shape of its electron cloud.
5. Can the orientation of the electron orbit with l = 0 be changed?
In quantum mechanics, the orientation of the electron orbit with l = 0 is determined by the laws of physics and cannot be changed by external factors. However, it can be altered through interactions with other particles or by applying external fields to the atom.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
