A quantum particle which is almost at rest but whose position is rando
In summary, the conversation discusses the concept of uncertainty in quantum mechanics and how it is demonstrated through the wave function. The example of a particle with small momentum and uncertain position is used to illustrate this principle. The conversation concludes by stating that this is a straightforward consequence of quantum mechanics and that the uncertainty principle can be simply summarized as the trade-off between precision in momentum and position measurements.
rajesh_d
I had posted this question here : http://physics.stackexchange.com/q/69003/540
I guess its appropriate to post links in here as question.
This question is really puzzling me and any suugestion/comments are much appreciated and welcome.
Yes, you can have a particle with very small momentum and a very uncertain position. A simple case in which you can work everything out analytically is the wave function
##\psi(x) = e^{-x^2/L^2}##
If you haven't done this before you should calculate various quantities for this wave function like ##\langle x \rangle##, ##\langle p \rangle##, ##\Delta x = \sqrt{\langle x^2 \rangle - {\langle x \rangle}^2}##, and ##\Delta p = \sqrt{\langle p^2 \rangle - {\langle p \rangle}^2}##. It's also enlightening to calculate the time evolution of this wave function, which isn't too hard. If you do end up doing this, make sure to do it again with the more general wave function ##\psi(x) = e^{-x^2/L^2}e^{i k x}##
You'll find that the uncertainty in position is of order ##L##. The expectation of momentum is 0, with uncertainty of order ##\hbar/L##. Taking ##L## large gives a high position uncertainty and a small momentum uncertainty.
This is not a problem with quantum mechanics; it's a straightforward consequence of it. In fact, the intuitive content of the uncertainty principle can basically be summarized as: "If you want a particle to have a certain momentum (such as zero) with high precision, then its position must be very uncertain."
1. What is a quantum particle?
A quantum particle is a subatomic particle that exhibits wave-like behavior and follows the laws of quantum mechanics. Examples of quantum particles include photons, electrons, and protons.
2. How can a quantum particle be almost at rest?
In quantum mechanics, the concept of rest is relative and not absolute. A quantum particle can be considered almost at rest when its kinetic energy is very small compared to its potential energy.
3. What is meant by a quantum particle's position being random?
In quantum mechanics, the position of a particle is described by a probability distribution rather than a definite value. This means that the exact location of a quantum particle cannot be determined, but rather, there is a range of possible positions it could occupy.
4. How is the position of a quantum particle determined if it is random?
The position of a quantum particle can only be determined through measurement. However, the act of measurement itself can affect the position of the particle, making it impossible to know both the position and momentum of a particle simultaneously.
5. What real-world applications does the study of quantum particles have?
The study of quantum particles has led to the development of technologies such as transistors, lasers, and magnetic resonance imaging (MRI). It also has potential applications in fields such as quantum computing, cryptography, and quantum teleportation.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
