Register to reply
DC-DC Converter for Gate Driver Circuitry (Electric Motorcycle)
Share this thread:
jegues
#1
Dec22-13, 11:34 AM
jegues's Avatar
P: 1,089
Evening all,
I'm trying to pick out a suitable DC-DC Converter for our low power gate driver circuitry and I'm unsure about a number of different things.
First some background on the circuitry and what the DC-DC Converter is needed for.
To date, we've designed, built and tested a low power gate driver circuit similar (almost identical) to the one shown in the figure below. The end goal is to use such a circuit to drive a Power MOSFET Module for an electric motorcycle.
Anyways, we built and tested this circuit on a lab bread board that has its own variable 15V and fixed 5V supplies, and everything seems to work fine. However, the final product must have its own low voltage supplied via a DC-DC converter fed by battery bank of the motorcycle which is ~55V.
Thus we need a DC-DC converter capable of supplying us with an isolated 12V(or 15V) and 5V supplies. The 12V(or 15V) supply is used to power the gate driver IC (IR2110) as well as the power buffer circuitry,(i.e. VCC = 12V or 15V) while the 5V supply will act as the logic supply for the chip. (i.e. VDD = 5V)
One simple option would be to find a DC-DC converter that will provide the 55V to 12V(or 15V) needed and simply feed the 12V(or 15V) into a regulator such as the LM7805 and obtain our 5V logic supply from there.
It seems straightforward enough to find a suitable DC-DC converter that will meet our input/output voltage requirements, but I am uncertain as to what our output current requirements are.
According to the application note for our gate driver, the power buffers in the schematic shown above (i.e. the circuitry shown to the right of the IR2110) are needed to provide a higher gate drive current and lower gate drive impedance than what a typical gate driver IC can provide. (Application note is attached below)
They mention that the one shown in the figure above is capable of providing 8A peak output current, which is sufficient for driving Power Modules. (We are using a MOSFET power module, I've attached its data sheet below)
So does this imply that the 12V(or 15V) output from DC-DC Converter (i.e. VCC = 12V or 15V) must be capable of supplying 8A peak output current? The current needed to the drive the gate must be supplied by VCC, right? Or does the power buffer somehow amplify or boost the current?
Thanks for reading!
Phys.Org News Partner Engineering news on Phys.org
New filter technology uses inert gas to bore holes in high-quality steel
Augmented reality helps in industrial troubleshooting
How wireless technology can dramatically improve ship safety
Baluncore
#2
Dec22-13, 06:40 PM
Sci Advisor
Thanks
P: 1,911
Firstly you should convert the 55volt supply down to the +12V using an isolated switching converter. Then use a linear regulator such as a 7805 to produce the +5Vdc.
Take a look at things like this:
http://www.allelectronics.com/make-a...NVERTER/1.html
Use selection systems like these to find suitable converters.
http://www.digikey.com.au/product-se...DC%20converter
http://au.mouser.com/Power/DC-DC-Con...erters&FS=True
Jony130
#3
Dec23-13, 10:58 AM
P: 409
Quote Quote by jegues View Post
No, in proper design circuit this extra current needed for driver should be supply by a "big" capacitor. In your case it is a bootstrap calculator. Vcc current will be equal to the average current.
jegues
#4
Dec23-13, 12:27 PM
jegues's Avatar
P: 1,089
Quote Quote by Jony130 View Post
Hi Jony130!
So are the decoupling capacitors for the high side switch also functioning as the bootstrap capacitor? Or is a separate bootstrap capacitor needed?
Also, what is the purpose of the leftmost 100uF capacitor? It seems to be connected between Vcc and Vss, but I'm not sure what's there for.
Jony130
#5
Dec23-13, 02:14 PM
P: 409
Its looks like this 10uF act as a bootstrap capacitor for high side also.
This capacitor "provide a current" for IRF210 and for this 10uF caps also.
jegues
#6
Dec23-13, 02:25 PM
jegues's Avatar
P: 1,089
Isn't the 100uF used to stablize the VCC supply, not necessarily supply current like the decoupling capacitors?
Jony130
#7
Dec23-13, 02:42 PM
P: 409
It's all depend on the point of view. This capacitor don't serve only one role.
Also this circuit looks strange, do you really need all this mosfet do drive a singe IGTB?
Register to reply
Related Discussions
Wiring a gate driver correctly (keeps burning out) Electrical Engineering 11
Alert driver vs Sleepy Driver distance traveled Introductory Physics Homework 1
XOR gate to XNOR gate boolean algebra Engineering, Comp Sci, & Technology Homework 6
Sychronous buck converter (SBC) with compensator and adaptive gate drive (AGD) cct. Electrical Engineering 17
Electric Motorcycle General Discussion 21
