Magnetic Susceptibility of different compounds
In summary, magnetic susceptibility is the measure of how easily a material can be magnetized in the presence of an external magnetic field. It is typically denoted by the symbol χ (chi) and is measured using a magnetic susceptibility balance. The electronic structure of atoms, the presence of unpaired electrons, and intermolecular interactions can affect the magnetic susceptibility of a compound. Additionally, different compounds can have varying levels of magnetic susceptibility depending on their chemical composition and structure. Magnetic susceptibility measurements have various applications in fields such as materials science, geology, and environmental science. They can be used to identify and characterize materials, study magnetic properties, and monitor changes in the environment.
physicsmonger
Can anyone link me to a table of a large amounts of different compounds with the magnetic susceptibility of each one?
Thanks.
Thanks.
Hello!
Maybe you'll find http://www-d0.fnal.gov/hardware/cal/lvps_info/engineering/elementmagn.pdf" usable.
Thanks! that was incredibly helpful. howd you find that so fast??
Had it for some time now ... enjoy your physics :)
Sure, I can provide you with a link to a table of magnetic susceptibilities for different compounds. One resource you can use is the National Institute of Standards and Technology (NIST) database, which contains a comprehensive list of magnetic susceptibilities for various compounds. You can access it here: https://physics.nist.gov/cgi-bin/MagneticPlot.pl. Additionally, there are other databases and research papers that may also have this information available. I suggest searching for "magnetic susceptibility table for compounds" on a search engine to find more resources. I hope this helps.
1. What is magnetic susceptibility?
Magnetic susceptibility is the measure of how easily a material can be magnetized in the presence of an external magnetic field. It is a dimensionless quantity and is typically denoted by the symbol χ (chi).
2. How is magnetic susceptibility measured?
Magnetic susceptibility is measured using a device called a magnetic susceptibility balance, which applies a known magnetic field to a sample and measures the resulting magnetization. The ratio of the magnetization to the applied field is the magnetic susceptibility of the material.
3. What factors affect the magnetic susceptibility of a compound?
The magnetic susceptibility of a compound can be affected by factors such as the electronic structure of the atoms, the presence of unpaired electrons, and the strength of intermolecular interactions. Temperature and pressure can also have an impact on the magnetic susceptibility of a material.
4. How does magnetic susceptibility differ between different compounds?
The magnetic susceptibility of a compound can vary greatly depending on its chemical composition and structure. For example, materials with strong intermolecular interactions tend to have a higher magnetic susceptibility than those with weak interactions. Additionally, compounds with unpaired electrons or transition metal ions tend to exhibit higher magnetic susceptibility.
5. What are some common applications of magnetic susceptibility measurements?
Magnetic susceptibility measurements are commonly used in a variety of fields, including materials science, geology, and environmental science. They can be used to identify and characterize materials, study the magnetic properties of minerals and rocks, and determine the purity of substances. Magnetic susceptibility measurements can also be used to monitor changes in the environment, such as the presence of pollutants in water or soil.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
