What Minimum Height Fish Must Spot Pelican to Escape?
In summary, the question asks for the minimum height a fish must spot a pelican, which starts its dive at a height of 15.9m, in order to perform evasive action in 0.19 seconds. Using the equations X = X(initial) + V(initial) * T + 1/2 * A * T^2 and X = X(initial) + [V^2 - V(initial)^2] / 2A, the minimum height is found to be approximately 3m.
stacker
If it takes a fish 0.19s to perform evasive action, at what minimum height must it spot the pelican to escape?
[Suppose a pelican starts its dive from a height of 15.9 m and cannot change its path once committed]
If it takes a fish 0.19s to perform evasive action, at what minimum height must it spot the pelican to escape? Assume the fish is at the surface of the water. (Express your answer using two significant figures.
None of the following answers are correct:
5.8
4.9
X = X (initial) + V (initial) * T + 1/2*A*T^2, which is simplified to X (initial) = 1/2*A*T^2
X (initial) = 1/2*A*T^2 = 1/2*9.8*1.9^2 = 19.6
X = X (initial) + [V^2-V(initial)^2]/2A
I'v used the equation X = X (initial) + V (initial) * T + 1/2*A*T^2, which is simplified to X (initial) = 1/2*A*T^2.
-15.9 meters = 1/2*(-9.8)*T^2 and solved for T;
T = 1.80 seconds
Total time needed for evasion is 1.80 s + 0.19 s = 1.99 s or 2.0 seconds and I used 1.80 s - 0.19 s = 1.61 s.
I plugged in 2.0 seconds into "X (initial) = 1/2*A*T^2 = 1/2*9.8*1.9^2 = 19.6" and I tried "= 1/2*9.8*1.61^2 = 12.7 or 13."
Both were found to be wrong.
If you were to determine velocity of pelican, you would use " X = X (initial) + [V^2-V(initial)^2]/2A".
-15.9 meters * 2 (-9.8)= V^2 ; V = square root of (311.64) = 17.65 m/s or ~17.7 m/s.
But I think velocity is irrelevant.
5.8
4.9
T = 1.80 seconds
All you're looking for really is the distance the pelican travels in the final 0.19 seconds of its dive.
let s be the distance pellican travel in the last 0.19s of its dive ( i assume its free fall, so a = 9.8)
so
s = ut + (1/2) at2
s = u(0.19) + (1/2) (9.8) (0.192) =====> equation 1
now to find u, which is the speed of pellican at the start of the last 0.19s of its dive,
we use
v'2 = u'2 + 2as', =====> equation 2
where now, v' is your u,
u' is initial speed = 0 , assume pellican dives from rest
s' is distance covered from start till the last 0.19s of the dive, = (15.9 - s)
a =9.8
so substituting equation 2 into 1,
s = [2a(15.9-s)]1/2 (0.19) + (1/2) (9.8) (0.192)
solving for s, i think you will get around 3m (you should get a more accurate number to 2s.f as specified by question)
What is the minimum height that a fish must spot a pelican to escape?
The minimum height that a fish must spot a pelican to escape can vary depending on the size and species of the fish. Generally, a fish should be able to spot a pelican from at least 30 feet above the water to have a chance of escaping.
How do fish spot predators like pelicans?
Fish have a lateral line system that helps them detect changes in water pressure and movement. This system allows them to sense the vibrations and movements of predators like pelicans, giving them a chance to escape.
Do different fish have different abilities to spot pelicans?
Yes, different fish species have varying abilities to spot predators like pelicans. Some fish may have better eyesight, while others may rely more on their lateral line system. The size and behavior of the fish can also affect their ability to spot predators.
Can fish learn to spot and avoid predators like pelicans?
Yes, fish have been observed learning to spot and avoid predators over time. This can be due to individual experience or through social learning from other fish in their group.
What are some other strategies that fish use to escape from predators?
In addition to spotting predators, fish may also use camouflage, speed, and agility to escape from predators. Some fish may also form schools or groups to confuse predators and make it harder for them to capture an individual fish.
