Will, Red, Green and blue lasers wen crossed create the spectrum we crossed ?
In summary, if you have three different colors of lasers, and cross them at one point, the spectrum of colors you see will be based on the mixture of the lasers.
JD1
will, Red, Green and blue lasers wen crossed create the spectrum we crossed ??
hia,
if i get red, green and blue lasers, and cross them at one point, and change the intensity of each one accordingly, will at the point of where they cross, display different colours relevant to the mixture of said lasers, ??
Thank you
Science news on Phys.org
hia JD! :smile:
yes, if you put a piece of paper where they cross, you will see white, or any other colour, the same as if they were separate dots on a photo or a tv screen
it has nothing to do with physics, it's just the way the human eye works
there are still only three wavelengths present, ie three different colours, but we see them as one colour, same as on a photo or tv screen
(if we had eye cells for each frequency, same as the ear has, then we would still see three colours!)
so if they were to cross in mid air, at that point of crossing, they wouldn't display the appropriate colour, they would have to hit something ? :-)
yes, since there's no physical change, there has to be something for a human eye to see for the effect to appear :smile:
i see, so if a given space, however big by so big, was occupied with say a transparent gaseous material, would this suffice ?? :-)
JD1 said:
… a transparent gaseous material …
?? if you mean a gas, then say so! :rolleyes:
(why use almost 30 letters when 3 will do?)
if you can't see the gas, then you can't see any colours either :confused:
If the gas was transparent, then you cannot see the lasers, as the light must bounce or scatter off of something and make its way into your eye. If you simply point the lasers at a single spot on a surface, such as a piece of paper, you can see the different colors they produce as you change the intensities of each. You could also fill a transparent container with something like fog or smoke and get a similar effect.
Thank you both, :-)
1. Will crossing red, green, and blue lasers create the entire visible spectrum?
No, crossing red, green, and blue lasers will not create the entire visible spectrum. The visible spectrum consists of all the colors that can be seen by the human eye, which includes wavelengths of light ranging from 390 to 700 nanometers. Crossing these three lasers will only create a small portion of the visible spectrum.
2. Can crossing lasers of different colors create new colors?
Yes, crossing lasers of different colors can create new colors. This is known as color mixing, where two or more colors of light combine to form a new color. This is how different colors are created on computer screens and TVs.
3. Is there a specific order in which the lasers should be crossed?
No, there is no specific order in which the lasers should be crossed. The resulting color will depend on the intensity and angle at which the lasers intersect. Crossing them in different orders may result in different colors being produced.
4. Will the resulting color be the same every time the lasers are crossed?
No, the resulting color will not be the same every time the lasers are crossed. As mentioned before, the resulting color depends on the intensity and angle of the lasers. So, even a slight change in these factors can result in a different color being produced.
5. Is it possible to create the entire visible spectrum by crossing more than three lasers?
Yes, it is possible to create the entire visible spectrum by crossing more than three lasers. By using a larger number of lasers, it is possible to cover a wider range of wavelengths and create a larger portion of the visible spectrum. However, it is not practical to use a large number of lasers for this purpose, as it can be costly and difficult to control.
  • Classical Physics
