Thickness of Plate to withstand 100psi
In summary: The deformation under pressure will be predictable for a given cavity pressure. You will probably capture that in your shrinkage measurements and final tool sizing.
pyroknife
613
Hi all. I was wondering if anyone knows of an equation to use to calculate the thickness of a plate to withstand a pressure of 100psi. I am using an injection molding process where the walls of my mold will be subjected to 100psi, so I need to calculate a plate thickness that can withstand this pressure.
You first need to determine what you mean by "withstand", because otherwise you might design something that won't break but deforms and either leaks like a sieve or else just gives you misshapen parts.
Second, I assume the exterior of said part is at atmospheric pressure? Pressure inside of a mold will only exert a net force on the mold beyond whatever is balanced by the pressure outside the mold.
The thickness needed will be dependent on the size of the plate, it's method of attachment and the shape, is it a flat or a cylindrical surface.
Sorry for the vague info. The plate will be made of aluminum, so it will be pretty ductile. I don't want this plate deforming at all. Yes, the outside is at atmospheric pressure. The plate is flat and rectangular shaped
The mold will pretty much be a rectangular box (with all the components of interest on the interior), so there are 6 sides of aluminum plates. A rough dimension of this box is 10"x10"x4".
What do you mean by the statement "Pressure inside of a mold will only exert a net force on the mold beyond whatever is balanced by the pressure outside the mold?"
There is no way to keep it from deforming "at all" unless you've found some infinitely stiff material, which would break physics. You need to have some kind of tolerance on allowable deformation.
Hmmm, I want the deformation to be as small as possible, but our tolerance for our manufactured parts about +/-0.005".
I don't know about molds being made from plate. Most of the molds in my experience have either been cast around a part or have been machined from a solid billet.
You will have to allow for shrinkage of the injected material as it cools. You may as well allow for the flexure of the mould plate at the same time. What type of plastic are you injecting?
If the mould is held together in a 10” x 10” hydraulic clamp then the 100 psi will be opposed by the clamp jaws, not just the plate. The plate itself could then be lighter.
Again, physics doesn't work that way. You could make the plate 100 miles thick and it would still deform a little. You need to to figure out what is allowable. That's part of being an engineer.
100 bar Is very low for injection moulding. Especially for tolerances of 0.005" (I will guess over 1"). The processes I work with typically have specific pressures in the cavity between 200 and 1,000 bar. Typically 500 bar.
Aluminium will give you a mould suitable for short runs. The softness means the vents on the spilt line will last a few hundred thousand shots at most.
The deformation under pressure will be predictable for a given cavity pressure. You will probably capture that in your shrinkage measurements and final tool sizing. I.e. leave the cavity metal safe and perform final machining after you have characterised the shrinkage.
As for a safe wall thinkness. Without a detailed part design and a software package to work it out I can't say.
All I can say is that my process makes parts about 1" in diameter and nothing load bearing is less than 1" thick. And that is in hardened steel...
If you think 100 bar is low, then imagine what you think of 100 psi (6.9 bar)...
Ha :smile: Thanks for that.
Makes my point about 14.503 times more pertinent then.
I am injecting resin. The final piece will be made of carbon fiber.
Is there an equation that is used to calculate these sort of things or is it more based one experience?
Roark's is a very common handbook for stress analysis. They have a section for flat plates.
The odd's are you would be better off using FEA software, as molds are generally going to be complex shapes that don't have analytical solutions for their stress and strain fields.
1. What is the formula for determining the required thickness of a plate to withstand 100 psi?
The formula for determining the required thickness of a plate to withstand 100 psi is t = P * d / (2 * S * F), where t is the required thickness, P is the pressure (100 psi), d is the diameter of the plate, S is the maximum allowable stress of the plate material, and F is the safety factor.
2. What materials are commonly used for plates to withstand 100 psi?
Common materials used for plates to withstand 100 psi include steel, aluminum, and various alloys. The specific material chosen will depend on factors such as cost, availability, and the intended use of the plate.
3. Is the thickness of a plate the only factor that determines its ability to withstand 100 psi?
No, the thickness of a plate is not the only factor that determines its ability to withstand 100 psi. Other factors such as the material's tensile strength, yield strength, and modulus of elasticity also play a role. Additionally, the design and construction of the plate (e.g. shape, support structure) can affect its ability to withstand pressure.
4. How does the thickness of a plate affect its ability to withstand 100 psi?
The thickness of a plate directly affects its ability to withstand 100 psi. A thicker plate will have a higher resistance to pressure, as it can distribute the force over a larger area. However, it is important to consider other factors such as the material's strength and the design of the plate when determining the appropriate thickness for a given pressure.
5. Can a plate with a lower thickness than the calculated value still withstand 100 psi?
In some cases, a plate with a lower thickness than the calculated value may still be able to withstand 100 psi. This can occur if the plate is made from a stronger material or if the design of the plate is particularly efficient in distributing the pressure. However, it is generally recommended to adhere to the calculated value for safety purposes.
  • General Engineering
  • DIY Projects
