Register to reply
Electric Field problem.
by Prashasti
Tags: electric field
Share this thread:
Prashasti
#1
Apr6-14, 07:30 AM
Prashasti's Avatar
P: 27
Question : Two large, thin metal plates are parallel and close to each other. On their inner faces, the plates have surface charge densities of opposite signs and of magnitude 17.0*10^-22. What is E (Electric field) : (a) in the outer region of the first plate, (b) in the outer region of the second plate?
Answer: According to the book, answers are (a) 0 (b) 0 And the reason they've given is - "Net electric field is Zero because electric fields due to both the plates will cancel out each other".
My objection : How? How do they cancel each other's effect when that particular region is NOT EQUIDISTANT from each other, and as Electric field varies inversely with the square of distance, HOW ARE THEY EQUAL IN MAGNITUDE?
Phys.Org News Partner Physics news on Phys.org
UCI team is first to capture motion of single molecule in real time
And so they beat on, flagella against the cantilever
Tandem microwave destroys hazmat, disinfects
Simon Bridge
#2
Apr6-14, 07:56 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,067
...as Electric field varies inversely with the square of distance
... this is only correct for sherical charge distributions - i.e. a sphere or a point charge.
Why is it important that the plates are "large"?
The electric field from two sheets of charge like that is the sum of the fields due to the single sheets alone.
What is the electric field due to a single large sheet of charge?
Prashasti
#3
Apr6-14, 08:46 AM
Prashasti's Avatar
P: 27
I got it. Thank you so much. I think it is E = sigma/2×vacuum permittivity?!
Simon Bridge
#4
Apr6-14, 08:30 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
Well done - yeah: the field due to a large plate (except near the edges) is uniform.
Since the plates have opposite signs, their fields cancel everywhere except in between them (and by the edges) where they add together.
Register to reply
Related Discussions
Electric Force and Electric Field problem Introductory Physics Homework 1
Magnetic field problem: What are the magnitude and direction of the electric field.. Introductory Physics Homework 1
Electric field and electric potential for point charges problem Advanced Physics Homework 2
Electric potential in relation to electric field problem Advanced Physics Homework 1
Calculating the Electric Potential from an Electric Field problem Introductory Physics Homework 1
