Is 37 Celcius Really the Perfect Body Temperature?
  • Thread starter Manraj singh
  • Tags
    Hot
In summary, heat flows from higher temperature to lower temperature. The body temperature is 37 celcius, but if the surroundings have the same temperature, it can still feel very hot. This is because the body continuously produces heat and needs to release it in order to maintain a stable internal temperature. At 37 degrees, the body's thermoregulatory mechanisms are not as effective in dissipating heat, making it feel hotter. This is why 37 celcius is not considered the perfect temperature for the environment, as the body needs to be able to shed excess heat in order to function properly.
Manraj singh
66
Heat flows from higher temperature to lower temperature. The body temperature is 37 celcius, but still if that's the surrounding's temp., it is very hot. Why so? Shouldn't 37 celcius be the perfect temp?
Biology news on Phys.org
I don't have specific expertise here, but I've always thought that since it is harder to cool a system with a small temperature gradient, humans prefer lower temperatures for the passive cooling effect.
To be pedantic, I wouldn't call it "harder," but rather say that it takes longer to cool: the rate of heat flow to the surroundings depends on the difference in temperature.
Otherwise, I think your explanation is correct. The body continuously produces heat, and some of it must be dumped into the environment to maintain 37°C inside.
You are mixing objective temperature with subjective feeling. It never works.
Core body temperature averages 37 degrees with minor fluctuations, peripheral body temperature can vary a bit more. But the reason why 37 degrees is not a perfect environment temperature and is in fact dangerous is because at that temperature your body cannot shed excess heat. Your metabolism creates a lot of waste heat that is damaging to cells and tissues, because of this you have thermoregulatory mechanisms to get rid of head through sweating, vasodilation etc.
It feels hot because the body cannot lose heat to the environment but it keeps generating heat internally.
1. Why does 37 Celcius feel hot?
37 Celcius feels hot because it is close to the average body temperature of 37 degrees Celcius. This means that our bodies have to work harder to regulate our internal temperature, leading to a feeling of discomfort or heat.
2. Is 37 Celcius considered a high temperature?
Yes, 37 Celcius is considered a high temperature for most people. It is above the average body temperature and can cause discomfort or heat-related illnesses if exposed to for too long.
3. Can humidity affect how hot 37 Celcius feels?
Yes, humidity can greatly affect how hot 37 Celcius feels. When the air is humid, it is harder for our bodies to cool down through sweating, making 37 Celcius feel even hotter.
4. How does our body perceive 37 Celcius as hot?
Our bodies have thermoreceptors that detect changes in temperature. When the temperature is close to or above our internal body temperature, these receptors send signals to our brain, making us feel hot and uncomfortable.
5. Can different individuals have different perceptions of 37 Celcius as hot?
Yes, different individuals can have different perceptions of 37 Celcius as hot. Factors such as age, health, and physical activity can affect how our bodies perceive and respond to temperature changes.
  • Materials and Chemical Engineering
  • Biology and Medical
  • Other Physics Topics
  • Classical Physics
  • Mechanical Engineering
